2006 quad cab Short box 4x4, has 6" ProComp Lift need to lower it
Old 01-07-2013, 05:53 PM   #1
Hoozel [OP] Hoozel is offline
Hoozel is one of the sharper tools in the shedHoozel is one of the sharper tools in the shedHoozel is one of the sharper tools in the shedHoozel is one of the sharper tools in the shedHoozel is one of the sharper tools in the shedHoozel is one of the sharper tools in the shedHoozel is one of the sharper tools in the shedHoozel is one of the sharper tools in the shedHoozel is one of the sharper tools in the shedHoozel is one of the sharper tools in the shedHoozel is one of the sharper tools in the shed
Hoozel's Avatar
Hoozel's Tacoma Gallery
posted this in 2nd gen area, but no response yet so reposting here.
Wondering if i could get some help. I bought a Used Tacoma that the guy put the ProComp lift on it. I live in a Condo with Underground parkade, it wont go under. I thought it was gonna work but it doesnt quite make it.
has 275 70r18's on it.
Cross Member has been cut so i cant remove the Lift Kit...
Has extended Knuckles, and Giant spacers above Coils, and Blocks under Leafs in Back
wondering if i can modify it in someway. For the Front my ideas are smaller block above Coils by maybe an inch, cut the coils a bit to get a drop.
In the Rear, Remove the Blocks and get an OME Dakar set which will drop it about 2" from where it is now.
then Maybe follow up with OME suspension in front which gives a 3" lift, then a 1.5" or 2" spacer above Coil to get it closer to what the The truck is setup for. I was thinking this way the knuckles can stay and the angles wont be too bad maybe for the axles.
Thanks in advance, I am real new to trucks. I can build a Supercharged Gixxer, but trucks I don't know jack.
Old 01-07-2013, 07:28 PM   #2
XREILLYX is on a distinguished road
XREILLYX's Avatar
XREILLYX's Tacoma Gallery
if you only have a one inch block up front your lift will be dragging on the ground.
Old 01-07-2013, 07:34 PM   #3
This is my derpawayinator!!!!!
NelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shed
NelsonTacoma's Avatar
NelsonTacoma's Tacoma Gallery
I would change the lift blocks front & rear. You can change the spacers to a smaller size to decrease the lift. Whatever you do DO NOT cut the coils, it will change the spring rate and will ruin the springs.
Old 01-07-2013, 09:16 PM   #4
Hoozel's Avatar
cool thanks. i did the rear today 1" smaller block. Have some OME Dakar springs on order till then. I am gonna look around for a smaller block up front or fab something with existing.
Old 01-07-2013, 09:17 PM   #5
nofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shed
nofords08's Tacoma Gallery
You can take the 6" lift off and go down to a 3" lift or whatever floats your boat.
2006 quad cab Short box 4x4, has 6" ProComp Lift need to lower it Hoozel 2nd Gen. Tacomas 0 01-06-2013 06:03 PM
2006 Toyota Tacoma Double Cab TRD Sport 4X4 - Short Bed - $20,195 OBO wolverine8 Buy / Sell / Trade 8 10-30-2012 06:03 PM
6" ProComp lift HELP me find some info on box size and weight please! CCFBERG 2nd Gen. Tacomas 0 04-15-2011 03:12 PM
2006 tacoma sub and amplifier in quad cab takaya49 Audio & Video 3 04-13-2010 02:55 PM
Average price of a 2006 4x4 Quad cab whi30 New Members 1 08-04-2009 03:30 PM
