My theory... any advice?
Discussion in 'Suspension' started by davidjmay, Jan 14, 2013.
  1. Jan 14, 2013 at 6:09 PM
    davidjmay
    davidjmay [OP] Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    I have an '00 prerunner that I want to lift, I have OME 9004's with 883 coils already but nothing for the back. I need a new leaf pack, since mine is frowning. BUT, when I jacked my truck up the other day, I noticed that even though the jack was at the front of the frame, the rear lifted about 2 inches. MY THEORY is that if I just put the OME coilovers on the front, that it will take some pressure off of my leaf packs, therefore giving the rear an inch or two of "lift". ("Lift" because in reality it would just be the stock height of the rear). When I jacked it up, the leaf packs were no longer frowning, but as soon as I lowered it I watched as the leafs returned to their frowny state. Any opinions on if this would work??
    Normal:
    After I jacked up the front end:
    Maybe a better angle (from the front side)
    before/after:
    This is where I put the jack:
  2. Jan 14, 2013 at 6:17 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I think that is just because you are cantilevering (is this a word) the weight of the engine over the jack. Someone correct me if i am wrong
  3. Jan 14, 2013 at 6:17 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    The placement of the jack is probably right at if not a bit further back than the center of gravity. You lifted up the entire truck.
  4. Jan 14, 2013 at 6:20 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yep. What they said.
  5. Jan 14, 2013 at 6:21 PM
    taco terror
    taco terror 1st gen = best gen
    North Carolina
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Nope, gravity wont work like that. If you put the jack under the "special spot" on the skid plate, you will have more accurate results.
    You might actually lose a little height in the rear by just lifting the truck, IDK but you wont gain any in the rear.
  6. Jan 14, 2013 at 6:39 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Thanks for the input!
  7. Jan 14, 2013 at 6:49 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    davidjmay,
    Look at "4WD"s post on "refurbishing leaf springs". You may find your solution there.
  8. Jan 14, 2013 at 6:57 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    You deff need new springs! Rising the front will put more pressure on the rear if anything, but not much!
  9. Jan 14, 2013 at 7:11 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    I've read it before, but considering I dont have access to that kind of leaf pack and I don't have the time, resources or know-how to accomplish a job like that, it'd be easier for me to just pick up some dakars. Haha
  10. Jan 14, 2013 at 7:33 PM
    wolftree
    Rick
    Ohio
    davidjmay,
    "4WD" also will build and install for you at a much cheaper price than Dakars. You will have a much better product.
  11. Jan 14, 2013 at 7:34 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    your leafs look like poo
  12. Jan 14, 2013 at 9:39 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Hmmm. Pm'd him. Thanks for the input!
  13. Jan 14, 2013 at 9:39 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    indeed
