Old Man Emu: Questions, Answers & Pictures
Old 09-29-2013, 07:54 PM   #2921
Stay Calm, and Fire For Effect
YOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shed
YOTA LOVER's Avatar
Army: Training NCO, B Btry, 3-197th FA
YOTA LOVER's Tacoma Gallery
Originally Posted by OZ-T View Post
255/85/16
X3. Wish I had gone a tad skinnier on mine.
Old 10-01-2013, 05:49 PM   #2922
B4nn3d
jetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant future
jetta.the.hut's Avatar
jetta.the.hut's Tacoma Gallery
Ok finally got the funding to get the struts mounts so I can just pull out the old stuff and put these in. But from the kit I see no nuts included, wonder what size and thread I need.
http://www.autopartsnetwork.com/sm56.../ad8_egaXuJnEZ
I've got a friend who has a hydraulic spring compressor so he said he compress them and install the caps but I'll need new nuts for it. I guess I could buy some from advance but I'd rather have the black coated nuts to prevent rust
Old 10-01-2013, 11:34 PM   #2923
bastard
DoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shed
DoorDing's Avatar
DoorDing's Tacoma Gallery
If you're referring to black oxide coated nuts, that coating isn't very corrosion resistant. A Grade 8 nut has better plating, and will be more than strong enough for the application.
Old 10-02-2013, 06:28 AM   #2924
m.reed.1 has a brilliant futurem.reed.1 has a brilliant futurem.reed.1 has a brilliant futurem.reed.1 has a brilliant futurem.reed.1 has a brilliant futurem.reed.1 has a brilliant futurem.reed.1 has a brilliant futurem.reed.1 has a brilliant futurem.reed.1 has a brilliant futurem.reed.1 has a brilliant futurem.reed.1 has a brilliant future
m.reed.1's Avatar
Air Force:
m.reed.1's Tacoma Gallery
is anyone running OME 885's on a prerunner DCSB?
Old 10-02-2013, 09:40 AM   #2925
B4nn3d
Getting ready too. If i can get someone to answer my other thread about strut mounts. The 885's with a 1/4 spacer will give me the height i want but i also plan on changing my UCA's as soon as my stuff sells. If i had to do it all over and hadn't bought the OME's i'd be doing a spindle lift instead.
Old 10-02-2013, 09:44 PM   #2926
a name known to all
luka has much to be proud ofluka has much to be proud ofluka has much to be proud ofluka has much to be proud ofluka has much to be proud ofluka has much to be proud ofluka has much to be proud ofluka has much to be proud ofluka has much to be proud of
Air Force: Jet Mech / Metals Tech
luka's Tacoma Gallery
seemed to have run into an issue...with dual batteries, my bumper, skids, sliders, and fullsize(255/85) spare, looks like my driver side lean has returned even with the 5mm trim packer.
would adding a 1/4" spacer or making a custom larger trim packer be a potential fix?
I have 886x springs and it doesn't look like it's been done.
Old 10-03-2013, 10:21 AM   #2928
tacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shed
tacoma16's Avatar
tacoma16's Tacoma Gallery
How much lean ?
Curious as well since going to have a similar set up...
Old 10-03-2013, 03:20 PM   #2930
a name known to all
I moved my spare to the passenger side in the bed, so ~80lb shift,
front right is ~23 1/8
front left is ~ 22 7/8 - 23
both rears were ~ balls on 25
also, going into driveways and such, my driver side rubs the plastic where the mud flaps used to be, passenger side does not.
so i'm looking for probably 1/4" correction to account for my weight while driving.
Old 10-03-2013, 07:40 PM   #2931
OZ-T's Avatar
OZ-T's Tacoma Gallery
Hows your alignment ?
IDK why you couldn't stack another trim packer on the driver's side to gain 1/4" - 3/8"!
Old 10-03-2013, 08:03 PM   #2932
a name known to all
like another 5mm? i could make a 10mm packer at work next time I go back in.
my alignment is good thanks to my LR-UCAs, its all within factory spec.
Old 10-04-2013, 04:35 PM   #2933
JCRD is on a distinguished road
JCRD's Avatar
JCRD's Tacoma Gallery
I received my OME kit this morning, I plan to install it next week without aftermarket UCA and analyze my alignment numbers. If it's not good I will buy LR UCA. ARB Canada guy said that it will not be necessary to change, my wallet hopes that he is right...
Old Man Emu: Questions, Answers & Pictures-img_0456_small.jpg   Old Man Emu: Questions, Answers & Pictures-img_0458_small.jpg
Old 10-04-2013, 04:45 PM   #2934
Mama says Tacoma World is da devil!
bjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shed
bjboucher's Avatar
Air Force:
bjboucher's Tacoma Gallery
Sweet, good luck!
Old 10-05-2013, 08:55 PM   #2935
usmcmax is on a distinguished road
Marines:
usmcmax's Tacoma Gallery
Ordered
Just placed my order with Wheelers Offroad for my OME setup with 886 coils and LR UCA's. Dan was a big help- now I just need to get back from Afghanistan so I can put this shit on my truck!
Old 10-05-2013, 10:07 PM   #2936
sodoscott has a brilliant futuresodoscott has a brilliant futuresodoscott has a brilliant futuresodoscott has a brilliant futuresodoscott has a brilliant futuresodoscott has a brilliant futuresodoscott has a brilliant futuresodoscott has a brilliant futuresodoscott has a brilliant futuresodoscott has a brilliant futuresodoscott has a brilliant future
sodoscott's Avatar
sodoscott's Tacoma Gallery
ok here is some pic i have i got my full suspension from wheelers offroad . left one is bone stock.i got OME Complete 2005-Current Tacoma Lift System with NitroCharger Sport Shocks
Old Man Emu: Questions, Answers & Pictures-2013-09-07-18.29.30.jpg   Old Man Emu: Questions, Answers & Pictures-2013-09-07-18.28.36.jpg
Old 10-05-2013, 11:58 PM   #2937
evanmb31's Avatar
evanmb31's Tacoma Gallery
Nice! Good luck, make it home safe and post pics after the install,
Old 10-06-2013, 06:32 AM   #2938
bjboucher's Avatar
Air Force:
Nice! Good luck man, stay safe over there so you can get back and enjoy that nice new suspension!
Looks good!
Old 10-06-2013, 06:59 AM   #2939
Digger2 is on a distinguished road
Digger2's Tacoma Gallery
Hey guys I have a full ome 886 and dakar lift on my truck. It's got a arb bumper sliders,full armor. I'm running 285/70R17 Duratracs on stock trd sport rims with spidertrax spacers and stock UCAs. My problem is that my steering wheel shakes pretty bad left to right while driving around 55mph,but then tends to smooth out at like 75mph. The truck tracks perfectly straight when u let go of the wheel, but tends to be a little "darty" when lane changes are made. I don't really feel a shake in the truck just in the steering wheel. I've had the wheels balanced 2x and the alignment checked 2x. The alignment numbers are all at 0 including caster as the shop said that's the best they could get. I've ordered camburg balljoint UCAs hoping this will resolve the shaking with getting some caster back. Am I on the right track or am I missing something. Any input would be appreciated.
Old 10-06-2013, 07:09 AM   #2940
bjboucher's Avatar
Air Force:
You need caster to be at about 3 degrees, not zero. That's probably a lot of your problem. The new UCAs will definitely help you get there.
I don't think it'll fix the shake though. My truck has always had a bit of a shake, pretty sure it's my wheels just being VERY difficult to get a good balance on.
old man emu.. nastyblowpop 2nd Gen. Tacomas 13 04-08-2014 09:41 AM
Old Man Emu Justin Suspension 52 02-27-2014 03:32 AM
Newbie, old man emu installed questions cheap99 Suspension 3 11-01-2012 05:37 PM
WTB: Old Man Emu N91s & N85 tundrafan05 1st Gen Tacoma Marketplace 0 10-24-2012 04:40 PM
Old man Emu c0b2a Suspension 7 10-06-2008 06:25 PM
