Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Mar 18, 2013 at 9:02 AM
    #901
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    yep, I was shocked as well. 2" rake. so if I remove just the 3rd leaf down, should that bring me down an inch in the rear?
  2. Mar 18, 2013 at 9:07 AM
    #902
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Only have the fronts right now but ordering the b110's when the time comes.
  3. Mar 18, 2013 at 9:40 AM
    #903
    4Wheelin4Banger
    4Wheelin4Banger [OP] Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    OK.
    I got billies in back & the 5100s are limiting my droop. I need to get the extenders for them.
  4. Mar 18, 2013 at 11:02 AM
    #904
    nj636
    Kev
    Jersey
    plenty of droop with 5100's in mine :confused:
  5. Mar 18, 2013 at 11:04 AM
    #905
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    OME literature says about 3/4" reduction
  6. Mar 18, 2013 at 6:57 PM
    #906
    nj636
    Kev
    Jersey
    before measurements front and rear:
    LF - 20.0 RF - 20.50
    LR - 21.50 RR - 21.50
  7. Mar 19, 2013 at 12:47 AM
    #907
    4Wheelin4Banger
    Randy
    Standard or extended length?
    I had to lift my rear axle several inches to put the top bolt on.
    So I know mine will droop a lot more with the 3" shock extenders.
  8. Mar 19, 2013 at 2:15 AM
    #908
    skygear
    skygear                    
    SO I went ICON, since a little money came available. Still took all the advice given here and am applying it to my ICON setup. 700# springs, etc.
    Really wanted to stick with the OME since it is a cost effective setup. All my deals were falling through on the suspension that I was making. I ended up getting impatient, and betting money where I should not. Came out on top and am getting all my gear in the next couple weeks.
    OZ and the rest of the crew in here, Thank you for answering my inexperienced questions. I am learning through experience.
  9. Mar 19, 2013 at 2:36 AM
    #909
    skygear
    skygear                    
    Anyone that is currious, Here is where my suspension will be very soon. Paid for and very appreciative to Metal Tech 4x4. Brandon, your the man.
    5-8735 - Remote resi Extended travel Coilovers with the Click to Adjust and 700# Icon Springs
    5-7805 - 2.5 remote resi shocks.
    5-8550 - Billet UCA's
    5-6101 - LCA Skid Plates
    All Pro EXPO leafs
    5" Steel Break Lines
    Aluminuim Sway Bar relocation Kit.
    And I still cannot decide what to do with my Firestone kit.
  10. Mar 19, 2013 at 5:13 AM
    #910
    nj636
    Kev
    Jersey
    agreed
    extended length
  11. Mar 19, 2013 at 9:39 AM
    #911
    4Wheelin4Banger
    Randy
    I thought so when I saw the pic.
  12. Mar 19, 2013 at 9:36 PM
    #912
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Any of y'all running an ARB front bumper, 886s, ome struts w/ factory UCAS?
  13. Mar 20, 2013 at 4:10 AM
    #913
    nj636
    Kev
    Jersey
    we all have cheapo OME lifts, we can't afford steelz bumperz
  14. Mar 20, 2013 at 5:06 AM
    #914
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I was. I just put on LR-UCAs.
  15. Mar 20, 2013 at 6:50 AM
    #915
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    How was it? Why'd you put em on
  16. Mar 20, 2013 at 6:52 AM
    #916
    Sandman614
    Tim
    '06 SR5 Off Road
    My adjusters were about maxed out with stock UCAs, the alignment still wasn't right and was chewing up my tires. Money was the only factor for not putting them on with the lift. You can wait a while if you need to but I decided I needed them. I still need to find an alignment tech that is worth something and can read.
  17. Mar 20, 2013 at 10:39 AM
    #917
    Cwpick76
    Cwpick76 Well-Known Member
    CW
    Wichita, KS
    2013 Double Cab Xsp-X
    Blacked out badges.
    I am not a suspension guy and only recently got my first 4x4 truck. I do know stock susp wont hold up to much and I want to make sure i get the right stuff to replace factory. I am wanting to be able to do more fast-paced off-roading. Other threads said I should get MT, MT thread said get OME suspension.
    This is what I saw on toytec and the options I chose for what I "think" I will need, but have some questions:
    Front coil options: Heavy_886_coils_(200+_lbs_add_front_weight)
    Top plate spacers: No_top_plate_spacers
    Rear Options: Complete rear OME CS047R springs with U bolts (+ $469.00)
    Front Diff drop kit: 4X4
    Add Rear shock stone guards (Pair): Yes (+ $26.00)
    NEW! Assemble front shocks/coils with new bushings: NO
    Do I need front diff drop kit? (what does it do?)
    Should I get top plate spacer? (what does it do?)
    Do I need to replace UCA? or lower? or both?
    (I looked at my factory UCAs and realized that they arent much more than plate steel bent into a tube shape, so I know I should replace those)
    Most kits have said get longer rear brake lines, is that true here?
    $100 for them to assemble front shocks/coils with new bushings...Is it worth it?
  18. Mar 20, 2013 at 10:49 AM
    #918
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    if you are going to do a lot of fast paced driving offroad, i'd say to go with King/Icon/Fox that have the remote reservoirs.
  19. Mar 20, 2013 at 12:31 PM
    #919
    4Wheelin4Banger
    Randy
    Save up buy the whole lift at once (with extra $ for UCAs) get it aligned & see if you need new UCAs.
  20. Mar 24, 2013 at 8:23 AM
    #920
    George Wimpleman
    George Wimpleman Active Member
    07 SR5 DCLB 4x4
    Noob question here. After reading through tcBob's sticky on suspension tips, I'm still wondering how difficult it will be (tools, techniques) to install the D29XL leaf set to Dakars before putting them on the axle? Thanks for the help.
