Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Apr 8, 2013 at 6:25 PM
    #1081
    Kevoh
    Kevoh Well-Known Member
    Kevoh
    Yorba Linda, CA
    '12 Taco
    a few goodies here and there!
    Gotcha. So I would want to set it back to zero and I would still have the same lift, just a better ride?
  2. Apr 8, 2013 at 6:38 PM
    #1082
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Yes you would want to set it to zero. I cant tell you much about the ride but i would assume it would be better. My 885s on OME nitrochargers ride very nice, more firm than stock. I cant conpare though because i never ran 5100s with stock coils.
  3. Apr 8, 2013 at 8:23 PM
    #1083
    lodi781
    lodi781 Alexander Supertramp
    shelton CT
    '16 4runner trail
    ARB by-51’s, dobinson springs, Gobi Rack, Black Oak single row LED roof bar
    OME with nitros, dakar pack no aal and 885x springs. Total chaos UCA's.....I have to check on the measurements.
    Before...
    After
  4. Apr 9, 2013 at 7:10 AM
    #1084
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    What kind of lift are you getting with the 885s and spacer? I run the 886s (no spacer, no added weight for a year) on my 2011 DCLB. I left the sway bar in place. Never did I feel I was maxing out the travel of the struts.
    Did you put in the diff drop? Once you go over 2" in lift, you really risk trashing your CVs at full extension if you haven't taken precautions to ensure you do not violate safe working geometry.
    I suppose you could install a nicer unit like the Fox remote reservoirs, with a little more travel built in. All that high-speed stuff is way over my head. :confused: I'm not sure about the Gen 3, but Gen 1 A-Arms didn't have a "maximum extension". They would keep rotating down until something broke, generally the strut bottomed out or the ball joints got thrashed.
  5. Apr 9, 2013 at 11:36 AM
    #1085
    Whitelightning8
    Whitelightning8 Well-Known Member
    Lemoore, California
    '11 TRD 4X4
    Leveling kit, bedcover, grillcraft grill, cooper 265/70, black XD addict rims, short antenna, front brow tint and side windows, magna flow exhaust, Hella 500s mounted behind grille, TRD CAI.
    Yes i do have the diff frop in. When i first put in the lift i was a full three inches in front and rear but both have settled a little bit
  6. Apr 9, 2013 at 6:25 PM
    #1086
    YOTA LOVER
    NH
    Hmmmmmmm..... leads me to believe you need a strut with more (the right) travel.
  7. Apr 9, 2013 at 6:33 PM
    #1087
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Consensus here is diff drops on 2nd Gens do nothing beneficial
  8. Apr 9, 2013 at 8:51 PM
    #1088
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Anyone running Billy 5160's with the Dakar pack?
  9. Apr 10, 2013 at 12:40 PM
    #1089
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I think there is/was a guy that did it, had a speedway blue, can't remember his username.
    I might change out my extended 5100s for 5160s later this year once everything settles and can see how far the dakars flex.
    I noticed this too, driving at speeds my 886s/nitros eat all the bumps but hitting speedbumps it sort of feels like the fronts don't want to compress on bumps low speed.
    I'll still need to get a bumper to add some weight which should smooth it out.
  10. Apr 10, 2013 at 12:53 PM
    #1090
    4Wheelin4Banger
    4Wheelin4Banger [OP] Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    My 885s got a lot smoother with the weight of sliders & a full set of skids.
    Added 1/4" spacers to regain 1/2" of lift (lost 3/4" front & 1/2" rear) and will probably swap them for 1/2" (or maybe just add 1/8") when I get my aluminum bumper.
  11. Apr 10, 2013 at 12:58 PM
    #1091
    Large
    Large Red
    Same thing here, Didn't like 885s without weight, added bumper and rode like a champ.
  12. Apr 10, 2013 at 1:09 PM
    #1092
    4Wheelin4Banger
    Randy
    I liked them before, just like them better now.
  13. Apr 10, 2013 at 1:11 PM
    #1093
    Large
    Large Red
    Hah well it wasn't a bad ride, it was a lot better with 100 pounds on the front though. Added a winch and it sagged too much, had to swap for 886s.
  14. Apr 10, 2013 at 1:14 PM
    #1094
    YOTA LOVER
    NH
    I don't even have the winch in the bumper yet and I'm sagging. Going to have to get spacers at some point.
  15. Apr 10, 2013 at 1:16 PM
    #1095
    OZ-T
    Peter North
    British Columbia
    886 or 886x ?
  16. Apr 10, 2013 at 1:17 PM
    #1096
    Large
    Large Red
    I'd go ahead and swap for 886s, they are stiff as :censored: but with a bumper, winch, skids and sliders it was actually pretty good..
  17. Apr 10, 2013 at 1:18 PM
    #1097
    4Wheelin4Banger
    Randy
    I'm going with a receiver mounted winch so the weight will only be up front if I'm using it & it can also be mounted on the rear.
  18. Apr 10, 2013 at 5:13 PM
    #1098
    YOTA LOVER
    NH
    886x??? Wazzat?
    I've got the 886s in there now.
  19. Apr 10, 2013 at 5:15 PM
    #1099
    OZ-T
    Peter North
    British Columbia
    How old are the coils ?
  20. Apr 10, 2013 at 5:26 PM
    #1100
    YOTA LOVER
    NH
    Close to 18 months, only had the bumper and skid on there for 6 months or so.
