Rear Brake lines after lift.
Old 01-16-2013, 06:00 PM   #1
totmacher [OP] totmacher is offline
totmacher has a spectacular aura abouttotmacher has a spectacular aura about
totmacher's Avatar
totmacher's Tacoma Gallery
I plan to buy longer rear brake lines since installing my Dakars but am wondering about something.
There are the 2 flex lines toward the driver side that are typically replaced. What is the pair of smaller lines closer to center? Anyone ever have issues with those being too short?
Old 01-16-2013, 06:11 PM   #2
offroadwonder is a splendid one to beholdoffroadwonder is a splendid one to beholdoffroadwonder is a splendid one to beholdoffroadwonder is a splendid one to beholdoffroadwonder is a splendid one to beholdoffroadwonder is a splendid one to beholdoffroadwonder is a splendid one to behold
offroadwonder's Avatar
Air Force:
offroadwonder's Tacoma Gallery
Wheel speed sensors. They are so close to the center that they shouldn't be a problem.
Old 01-16-2013, 06:20 PM   #3
My68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shed
My68ur8trd's Avatar
My68ur8trd's Tacoma Gallery
you can make a little bracket to raise them up.
not the prettiest, but I found a old piece of galvanized strap to raise mine up a few inches.
I have a ton of droop though, so they were stretched
Justin
Old 01-16-2013, 06:29 PM   #4
totmacher's Avatar
The axle droop when jacking the frame is what concerned me. I was imaging taking truck to a shop and when they put it on the lift seeing those lines pop off.
I think I've got some scrap aluminum bars somewhere in the garage that I can use to make a bracket like that.
thanks guys.
Old 01-16-2013, 06:36 PM   #5
05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed
05tacoSPORT's Avatar
05tacoSPORT's Tacoma Gallery
. On OEM lines. If you adjust the mount you will gain all you need. Or you can spend $$$ on new lines
Old 01-16-2013, 07:31 PM   #6
totmacher's Avatar
I thought the brake flex lines were attached to hard lines. How do you adjust the mount without bending the hardlines?
Old 01-16-2013, 07:34 PM   #7
evanmb31's Avatar
evanmb31's Tacoma Gallery
Holy droop. Are those invisible shocks? I am also curios to see how you did this with the stock lines
Old 01-16-2013, 09:03 PM   #8
Air Force:
Wow, I will be studying your build thread closely. I would love to have that much movement in the rear.
extended rear brake lines disc0monkey 5 Lug 7 06-11-2013 01:42 PM
Extended rear brake lines Sjoffroad 2nd Gen. Tacomas 3 03-12-2012 10:55 AM
New All Pro rear brake lines, how to install? cgrove04 Suspension 25 08-14-2010 06:15 AM
NEED HELP!! Spindle Lift and brake lines... Masada 2nd Gen. Tacomas 2 12-29-2009 11:24 AM
05+ Extended rear brake lines 06Bluez Buy / Sell / Trade 6 04-30-2009 11:43 AM
