4" suspension lift. Good idea?
Old 01-23-2013, 07:03 PM   #1
Jferrill84 [OP] Jferrill84 is offline
Jferrill84 is on a distinguished road
Firefighter:
Jferrill84's Tacoma Gallery
I am looking at getting a 4" suspension lift on my 2013 Tacoma. I've heard and read good and bad things. Will I have to have the transmission regeared? Loss of power? I'm thinking 32s or 33s. I have 245/75/16r on now. Will I have to get new wheels?
Old 01-23-2013, 07:06 PM   #2
dlooney has a spectacular aura aboutdlooney has a spectacular aura about
dlooney's Avatar
dlooney's Tacoma Gallery
Who makes it? BDS? If you're just running 33s you shouldn't need to regear.
Old 01-23-2013, 07:11 PM   #4
Firefighter:
Any issues with loss of power?
Old 01-23-2013, 07:11 PM   #5
evanmb31's Avatar
evanmb31's Tacoma Gallery
Is this a 4.5" drop bracket lift?
Old 01-23-2013, 07:13 PM   #6
dlooney's Avatar
Don't know much about their lift. Have you considered any other lifts? Any particular reason for this one? People tend to steer clear from drop bracket lifts but it's your truck. Some guys also run the 4.5 inch RCD drop bracket lift on here, you should be able to get plenty of info from them.
Old 01-23-2013, 07:13 PM   #7
dlooney's Avatar
It's the BDS 4 inch drop bracket. I don't know much about it, here's the kit
http://bds-suspension.com/product?kid=815F
Old 01-23-2013, 07:14 PM   #8
if your not the lead dog, the view never changes
k9cop is one of the sharper tools in the shedk9cop is one of the sharper tools in the shedk9cop is one of the sharper tools in the shedk9cop is one of the sharper tools in the shedk9cop is one of the sharper tools in the shedk9cop is one of the sharper tools in the shedk9cop is one of the sharper tools in the shedk9cop is one of the sharper tools in the shedk9cop is one of the sharper tools in the shedk9cop is one of the sharper tools in the shedk9cop is one of the sharper tools in the shed
k9cop's Avatar
Gender: Trans
k9cop's Tacoma Gallery
I'm assuming your going with spindles? if your gonna run 33's you will have some loss of power and lotsa loss of gas. I have spindles with billies at 1.75 and 33's. I go real easy on the pedal. so in reality i never notice the loss of power.hahaha
Old 01-23-2013, 07:15 PM   #9
k9cop's Avatar
Gender: Trans
ah shoot ok i skimmed by the bds, my bad. the rest still goes
Old 01-23-2013, 07:18 PM   #10
Firefighter:
To keep my truck in warranty The dealership said I have to go to a certain company who deals with BDS lifts. It is the 4" drop bracket
Old 01-23-2013, 07:18 PM   #11
evanmb31's Avatar
Whats your reasoning for going with a 4" drop bracket over a 3" suspension lift? I'm not saying that it is a bad choice, just wondering what you want out of the lift
Edit: posted to late. That does not make sense to me at all
Old 01-23-2013, 07:20 PM   #12
k9cop's Avatar
Gender: Trans
hu??that's weird. never had any problems with warranty issues with my lift. they won't warranty any issues that the lift causes or the lift parts but everything else should be covered
Old 01-23-2013, 07:21 PM   #13
dlooney's Avatar
Wow seriously? Damn, strict dealership. As far as new wheels go, all I can see is max 4.5 backspacing, I don't know if those numbers are recommendations or what. I'd say call them direct. I don't know, maybe someone who actually has this kit will stop by
Old 01-23-2013, 07:23 PM   #15
evanmb31's Avatar
Do you have to cut the crossmember with this kit like other drop bracket lifts? If so the warranty thing is BS. And 3" block in the rear? :/
Old 01-23-2013, 07:25 PM   #16
k9cop's Avatar
Gender: Trans
Originally Posted by GREEKBOY12295 View Post
Since you are a prerunner get the maxtrac spindles!
x2 I love my spindles and they give you more ground clearance than drop bracket.
Old 01-23-2013, 07:27 PM   #17
dlooney's Avatar
I'm gonna assume yes...and that was what I was thinking, and 3 inch spacers in front? No wonder not too many people run it
Old 01-23-2013, 07:32 PM   #19
Membor
Cowboyz has a spectacular aura aboutCowboyz has a spectacular aura aboutCowboyz has a spectacular aura about
Cowboyz's Avatar
Cowboyz's Tacoma Gallery
I'm not seeing the spacer up front. I'm seeing $1300 Fox coilovers. It's a nice lift if your getting a db lift
^^^^^^^And that's a different lift than what was posted above
Edit: I was looking at the 6in that dlooney posted.
Old 01-23-2013, 07:33 PM   #20
evanmb31's Avatar
So the dealership wants you to use this lift to keep warranty, but to install the kit it will require MAJOR modifications to the truck. Once the lift is installed it will probably never be going back to stock. You should find out more from the dealership and try to reason with them or the lift shop. If you want a lift to run 33's then a drop bracket lift probably isnt worth it, you can accomplish this for cheaper with a 3" lift and have more ground clearance. Like others said spindle lifts are always a good choice for pre runners
off brand 3" lift. Good idea? casperthetoyota Suspension 8 11-28-2012 02:56 PM
Good Idea for Lift? TacomaProject 1st Gen. Tacomas 5 02-21-2012 09:00 PM
would this be a good idea for a 3in susp. lift? djford193 1st Gen. Tacomas 4 10-13-2010 06:50 PM
4 cyl 6" lift on 35's? Good idea? especk Suspension 10 08-25-2010 08:55 PM
Is this a good lift. Pro comp 3" suspension lift/top gun customz MikeyD Suspension 23 10-21-2009 07:49 PM
