33" tires RUB
Discussion in 'Suspension' started by 2010TRD, Feb 2, 2013.
  1. Feb 2, 2013 at 12:18 PM
    2010TRD
    2010TRD [OP] Well-Known Member
    Thomas
    Waldo, FL
    2010 MGM trd offroad DCSB
    Billistein 5100 front/rears, Toytec 2" AAL Custom grill, All Pro rear bumper, All Pro sliders, Anytime elocker/foglights, Rear diff vent relocated, W/O seat covers, weathertech mats/visors, nfab tire racK, cobra 75 stealth CB, Custom engine/trans skids 3/8", Hella and HID behind grill, LED bar backup light, LED pods under cab (rocklights)
    So I just got 285-75-16 rubber
    Issue is they rub hard on the fender flares in rear
    I have +3" in front and 2.5" AAL
    I'm afraid these tires are gonna rip my flares off in the rear
    Id prefer not to trim the fenders
    I hear I can install bigger bump stops
    Any suggestions on what/where to get bump stops ?
  2. Feb 2, 2013 at 2:26 PM
    2010TRD
    Thomas
    Waldo, FL
  3. Feb 2, 2013 at 2:47 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    33's and 1.5 AAL :anonymous:
    Needless to say next time I wheel the flares are coming off before I go out
  4. Feb 2, 2013 at 2:47 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Wow, crazy to hear they rub the fenders in the rear. I got 1.5" aal in the rear and they don't rub unless I stuff them while offroading.
    Can't give no feedback on those bumpstops since I'm still running stock but bump to ya for feedback(s).
  5. Feb 2, 2013 at 2:56 PM
    jandrews
    '09 FourDubDee TRD OR
    That's what trimming is for.
  6. Feb 2, 2013 at 5:51 PM
    2010TRD
    Thomas
    Waldo, FL
    Only rub when stuffing them offroad .. As pictured above by bullettooth
    Trimming isn't an option , as it would look like crap
    Bump stops are best option
  7. Feb 2, 2013 at 6:02 PM
    jandrews
    :rolleyes:
    99% of people can't even tell unless you point it out.
  8. Feb 2, 2013 at 6:08 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Where does it rub front part or back? I unbolted my bed and slid it forward 1/2" until it was centered better. Sometimes the rear lift moves the axel out of line. Larger bumps are a good idea and/or trimming!
  9. Feb 2, 2013 at 6:12 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    why not more lift in the rear? unless you like it “level”
  10. Feb 2, 2013 at 6:16 PM
    jandrews
    Where is it rubbing? At the back bottom of the fenderwell? If that's the case you should be cutting all that off at some point for a high clearance bumper anyway.
  11. Feb 3, 2013 at 3:41 AM
    2010TRD
    Thomas
    Waldo, FL
    It rubs on the front section of rear fender as pictured above by bullet tooth Tony
    I never thought about nudging the bed forward
  12. Feb 3, 2013 at 7:54 AM
    jandrews
    You can also relocate the axle backward with plates. I'm not a fan of this method either, since you're goobering with suspension geometry.
  13. Feb 3, 2013 at 11:04 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    It only had about 1/2 - 3/4 to go but did make a difference!
  14. Feb 3, 2013 at 2:50 PM
    2010TRD
    Thomas
    Waldo, FL
    This seems like a cheap alternative .. I do have plenty of clearance in between tire and rear section of fender ..hmm
    And I've been wanting to install the bed bolt d-rings .. I think they call that killing to birds with one stone ...if it works :rolleyes:
  15. Feb 3, 2013 at 3:25 PM
    eric3187
    eric3187 Well-Known Member
    just let it rub until it rubs through... viola.. no more rubbing ;)
  16. Feb 3, 2013 at 4:14 PM
    2010TRD
    Thomas
    Waldo, FL
    I would do just that, but .. My fear is ripping the flare off entirely or at least break the tabs that hold them on
  17. Feb 3, 2013 at 5:06 PM
    BulletToothTony
  18. Feb 3, 2013 at 5:13 PM
    2010TRD
    Thomas
    Waldo, FL
    What I'm trying to prevent
  19. Feb 3, 2013 at 5:14 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    The bolt holes have play or... ? My bed looks crooked the passenger side is farther from the cab than the drivers side... So I need to loosen the bed mount bolts and the bed will shift? :notsure:
  20. Feb 3, 2013 at 5:23 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    this^^^
    this^^^^
    I just took my flares off this week, but that was because of previouse body damage making them not fit so great anymore.
    it is really hard to rip a flare off by rubbing. the underside of my flares are completely black, from the tires rubbing the paint off, but it didn't break anything, and you couldn't tell they rubbed by looking at the truck at ride height.
    if you want to go the bump stop route, the 4.5'' bumps are pretty nice. i ran them for a while after i sold my timbrens. i'm on the 2.5'' energy suspension bumps now though. a little rubbing at full stuff, but the fenders never got town off
