tierod rubbing procomp stage 2 shocks
Old 02-11-2013, 04:37 PM   #1
07tacoswb [OP] 07tacoswb is offline
07tacoswb is one of the sharper tools in the shed07tacoswb is one of the sharper tools in the shed07tacoswb is one of the sharper tools in the shed07tacoswb is one of the sharper tools in the shed07tacoswb is one of the sharper tools in the shed07tacoswb is one of the sharper tools in the shed07tacoswb is one of the sharper tools in the shed07tacoswb is one of the sharper tools in the shed07tacoswb is one of the sharper tools in the shed07tacoswb is one of the sharper tools in the shed07tacoswb is one of the sharper tools in the shed
07tacoswb's Avatar
07tacoswb's Tacoma Gallery
Question tierod rubbing procomp stage 2 shock spring
I have had this issue since installing my lift 2 years ago on my 07 4x4 lb sport. Even after installing my lr uca's and have my alignment check twice it still rubs. It is only rubbing on the drivers side. At full right lock the outer tierod comes in contact with the stage 2 shock spring. I even called procomp and they told me that this was just going to happen. Is anyone else having this issue? Is there a fix or a better alignment setting to try. I even set the drivers side uca to 1.5 to move the tire forward a little. Still bumps it. Its driving me crazy. Looking for a fix. Please help. Thanks
Old 11-12-2013, 11:21 AM   #2
07tacoswb's Avatar
Has anyone else had this issue with Procomp's 6" lift stage 2?
Old 11-12-2013, 12:04 PM   #5
07tacoswb's Avatar
Yeah everything is installed correctly. As you can see the tie rod is close to contacting when the steering wheel is straight. When at almost full lock on a right hand turn it is rubbing. You can see the mark on the spring from the contact. I can't even get the most caster out of my LR arms because they are rubbing all the time. I only have about 1.5 degrees. Steering is loose. The passenger side is not a problem. Also I'm afraid that if I move the wheel back in the wheel well that I'm going to have some serious rubbing on the frame/wheel well when turning.
Old 11-12-2013, 01:16 PM   #7
07tacoswb's Avatar
yeah let me know. How much caster do you have with your UCA's. I should be able to get what ever I need from the LR's but this rubbing is crazy.
Old 11-12-2013, 11:31 PM   #9
07tacoswb's Avatar
I have the Light Racing UCA's. I upgraded them from the rubber bushings to the poly's. I also just bought some Energy Suspension poly's for the steering rack in hopes to help with the loose steering feel. i just need to install them. Is your steering real loose feeling with your larger tires?
Need help from Procomp stage 2 owners 07tacoswb Suspension 13 12-14-2010 11:30 PM
ProComp Stage 2??? T0LLPHR33 2nd Gen. Tacomas 9 05-23-2010 11:49 AM
Procomp 6 inch Stage II compared to stage I caleb337 2nd Gen. Tacomas 1 03-17-2010 06:38 PM
procomp stage 1 6 inch taco_man Suspension 0 09-03-2009 09:18 PM
can anyone comment on the Procomp 6" stage 1 vs stage 2? cdnbanker Suspension 1 05-02-2009 06:47 PM
