2012 TRD suspension into a 2010 4 cyl.?
Discussion in 'Suspension' started by Lionel Hutz, Feb 23, 2013.
  1. Feb 23, 2013 at 5:22 PM
    Lionel Hutz
    Lionel Hutz [OP] New Member
    British Columbia Canada
    2010 2.7 4x4 Access Cab
    Hi everyone. Noob question but the following parts will bolt directly into my 2010 2.7 cyl. 4x4 access cab?
    A full TRD suspension, body flare and wheel/rubber set up off a 2012 Tacoma Double Cab TRD.
    - Four Bilstein shocks.
    - Two of the upgraded 4 leaf rear spring paks with bushings and u-bolts.
    - Front springs.
    - Four 265/65-17 Bridgestone Duellers on factory Toyota alloys, centre caps, lug nuts and locking lug nut. (obviously)
    - Front and rear factory flares (waste?)
    Keywords: Toyota, Bilstein, Tacoma, tires, leaf, spring, flares, alloy, rim
    Cheers. Thanks everyone.
  2. Feb 23, 2013 at 5:25 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Can I ask why? there are much better options than stock suspension for probably the same price it would cost you.
  3. Mar 3, 2013 at 4:13 PM
    Lionel Hutz
    Another guy just pulled out his stock rig including the rims with stock tires for a build and offered me his old stuff for about $1000.
    I need another set of rims as my winter ones are beat up. I figured the rims alone are worth ~$800 so installing the (marginal) upgraded system would be valuable in the short term.
    Clearly I am new to all this so insights, suggestions and critiques are welcomed...
    LH
  4. Mar 3, 2013 at 4:16 PM
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    some people would give that stuff away for damn near free.
    1000 is robbery
  5. Mar 4, 2013 at 11:44 AM
    Lionel Hutz
    This is the kind of thing I need to know...
    Thank you. I will not be spending $1000 on used parts that buddy just wants to get rid of.
    This is why the forum is awesome.
    Cheers,
    LH
  6. Mar 4, 2013 at 11:50 AM
    Large
    Large Red
    It will all work, and bolt right in. Now by front flare do you mean the flare on the fender or the whole fender? If it's the whole fender, it will not bolt up with your headlights / bumper / hood.
