3" revtec. Need UCAs?
Discussion in 'Suspension' started by Jpf8653, Feb 11, 2009.
  1. Feb 11, 2009 at 6:36 AM
    Jpf8653
    Jpf8653 [OP] Well-Known Member
    Justin
    Baton Rouge,LA
    Revtek 3" lift, Tinted Windows Wheels n' Tires Door Sill Protectors Rockford fosgate P3 shallow w/ alpine mono 500 amp in a MR MARV PORTED box Weathertech floor liner Rear TSB Pioneer 3200BT Double Din touch screen
    My dbl cab has 3" revtec. at 65 to 75 it really start wanting to pull right or left. I'm about to get an alignement but don't want to beat a dead horse. I just got the truck and not totally familiar with lifts and all that. I have read some about UCAs but not sure as to when ssomeone would need them. Also what is the difference in aftermmarket ones and stock.
  2. Feb 11, 2009 at 6:42 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I've also heard of other Tacoma's pulling to the left or right after a 3" lift. I don't have that problem because I bought TC UCA's. Difference between stock and these ones are you get a lot more play and adjustment out of the TC UCA's so that you can get your alignment correct.;)
  3. Feb 11, 2009 at 6:49 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    NEED is an overstatement. The alignment adjustments will be close-ish to in spec with the stock UCAs- but with aftermarket UCAs you'll be able to get them perfect. It won't explode or fail or anything cause you have the stock ones.
    However the aftermarket UCAs are the accepted way of "doing it right the first time"
  4. Feb 11, 2009 at 7:26 AM
    Jpf8653
    Justin
    Baton Rouge,LA
    Thanks for those good answers. Next what if I switched to the toytec coilovers. Are uca needed then?
  5. Feb 11, 2009 at 7:28 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    needed again is a bit strong...to do it right...Yes. You'll be able to do it with the stock UCA's but it puts a fir bit of strain on the CV joints and your alignment won't be quite right.
  6. Feb 11, 2009 at 7:32 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Jason
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    +1. The way I always put it is "necessary, yes. Required, no."
  7. Feb 11, 2009 at 7:49 AM
    Jpf8653
    Justin
    Baton Rouge,LA
    How do uca alow for better alignment are they longer. Is there different size uca? If so what size do I need? I know nothing about this!
  8. Feb 11, 2009 at 7:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The uniball is moved back a little bit to allow for the lack of caster when lifted.
