5100 lift questions
Old 03-14-2013, 08:24 PM   #1
jenk34 [OP] jenk34 is offline
jenk34 is on a distinguished road
jenk34's Tacoma Gallery
5100 lift questions
I have a 2012 double cab TRD Off Road edition and I will soon be ordering 5100's for my entire truck. I hate to say it but I doubt that I do much off roading, just want to have a truck that looks good and will ride close to stock on the highways, which is where I do most of my driving. I do have a few questions:
1. I'm going to go with some 16x8 Method Double Standard Wheels and 265/75/16 Goodyear DuraTracs. I want to go 1.75 to level out my truck. I was told that I should order these Camburg UCA's:
http://camburg.com/store/05-12-taco/...nt-upper-arms/
My question: Do I need to order UCA's for my truck, and if so, what are brand suggestions? Someone on here told me that the Camburg UCA's won't help my ride.
2. I was also told that I should install a differential drop. I have read mixed reviews on them. Opinions?
3. I have seen some people install 5100's and end up with a bro lean. Is this something that happens from time to time? Any way to avoid it?
4. Are there any other suspension components that I'm forgetting?
Thanks for any input!
Old 03-14-2013, 08:31 PM   #2
All I Do Is Nguyen
gym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shed
gym_jamz's Avatar
gym_jamz's Tacoma Gallery
1)When you lift your front to 1.75, you don't need new UCAs. Your stock ones should be fine.
2)Differential drop doesn't do anything to our 2nd gen.
3)Every truck is different. From what I've seen, with the front at 1.75, your nose will be a little higher. A tad higher. You can either set your 5100s down to .85, run a rear block (not recommended), or run an AAL.
4) You'll want a 1/4" top plate spacer to correct the driver side lean.
Old 03-14-2013, 08:37 PM   #3
Vaginas are rad.
Boone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shed
Boone's Avatar
Boone's Tacoma Gallery
Seems like a thousand different suggestions for every set up. 2012 DCLB Sport, 5100's set @ 2.5'' with stock coils and TSB rear is what I run and it sits level. Stock UCA's and alignment in spec. No diff drop, no vibes.
Old 03-14-2013, 09:58 PM   #4
lpfm1990 is on a distinguished road
lpfm1990's Avatar
lpfm1990's Tacoma Gallery
Send a message via Yahoo to lpfm1990
Does anyone have the specs for that spacer plate? I run a CNC waterjet and could cut my own for free... Thanks
Old 03-15-2013, 06:10 AM   #5
All I Do Is Nguyen
gym_jamz's Avatar
I don't know but you can probably email Toytec about it.
Old 03-15-2013, 06:31 AM   #6
Could you explain the TSB process you went through? I have read threads on it, but still don't quite understand it.
Old 03-15-2013, 07:16 AM   #7
Vaginas are rad.
Boone's Avatar
Went to look at the truck before purchase, asked them if they could take care of it before papers were signed and they did. It's just something that you'd have to talk to the dealer about. they should do it no problem if it's under warranty. If not I'd just go with some Dakars or Alcans.
Old 03-16-2013, 01:13 PM   #8
maxpower29 is one of the sharper tools in the shedmaxpower29 is one of the sharper tools in the shedmaxpower29 is one of the sharper tools in the shedmaxpower29 is one of the sharper tools in the shedmaxpower29 is one of the sharper tools in the shedmaxpower29 is one of the sharper tools in the shedmaxpower29 is one of the sharper tools in the shedmaxpower29 is one of the sharper tools in the shedmaxpower29 is one of the sharper tools in the shedmaxpower29 is one of the sharper tools in the shedmaxpower29 is one of the sharper tools in the shed
maxpower29's Avatar
maxpower29's Tacoma Gallery
its just adding an extra leaf to the stock rear pack. It was not on a lot of the american trucks when the 2nd gen started
Old 03-18-2013, 04:03 PM   #9
DBroman3 is on a distinguished road
DBroman3's Tacoma Gallery
Boone Taco, Any cutting needed for your 285's with only using 5100"s @2.5 in the front? I have a 2013 DC and I really want to just throw 5100's @ 2.5 and some 285's and call it done...
Old 03-18-2013, 05:16 PM   #10
maxpower29's Avatar
covered many times. You will need to cut some plastic. Maybe do the cab mount chop too depending of how bad it rubs. Its easy as fuck though
Old 03-25-2013, 03:23 PM   #11
Yeah, I see different results all over the place. Just asking what you did, more importantly, did you do the cab mounts?
Old 03-25-2013, 04:21 PM   #12
maxpower29's Avatar
not yet, but i have the 2 plates to weld there and will be doing it soon
Bilstein 5100 Lift Questions 2005Taco4X4 2nd Gen. Tacomas 10 07-08-2012 01:52 PM
removing lift 5100 questions medikirk Suspension 0 03-23-2012 07:18 PM
Bilstein 5100 lift questions (you probs have never seen a post like this before)jk whitetail Suspension 3 11-01-2011 11:03 AM
Bilstein 5100 Part # for 3" of rear lift??? Longer than standard 5100 Deathbeard Suspension 3 01-24-2011 05:49 PM
a few questions about 5100's tacosupreme54 Suspension 24 10-26-2010 12:07 AM
