Broken leaf - advice
Discussion in 'Suspension' started by Ronn, Apr 7, 2013.
  1. Apr 7, 2013 at 8:06 AM
    Ronn
    Ronn [OP] Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    Well I wasn't fully ready to pull the trigger on new suspension components, but a quick look at my truck this afternoon has pushed me over the edge. I have a broken leaf spring on the drivers side. I will be purchasing new leaf packs and placing the order tomorrow. There is no way I'd put Toyota springs back on this thing. The ones that came factory are the canadian 4 leafs and they sagged as soon as I started hauling my quad around.
    I'd like the rear to be a little more stiff because I haul a 14ft trailer with quads. As for lift I don't really want it to be more than 1 1/2" - 1 3/4".
    Option 1: Dakars with 3rd leaf removed. Can people that have done this chime in on what their center hub to fender measurements are? Or just any info at all would be appreciated, about height gained, settling etc.
    Option 2: Wheelers HD leaf spring. Anyone with experience? I searched around and doesn't seem to be that much info on them.
    For reference I have a 2007 DCLB SR5 with 200000km. My rear measurements now are 22inches both sides with a little less than 1/4 tank of fuel.
    All help is appreciated I'd like to make a more informed purchase tomorrow because I need my truck in a couple weeks, so I'd like to get this stuff ordered ASAP.
  2. Apr 7, 2013 at 8:13 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    can't offer too much help. my truck broke the same leaf, i wish wheelers had their replacement option available when mine broke. looks like a good product. i ended up getting a good deal on a basically new 3 leaf pack and put those back on.
  3. Apr 7, 2013 at 11:58 AM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    not the same as your situation but last week i added the dakar leaf pack and am very pleased. my stock leaf pack with a 2" toytec aal would sag from simple errands like dumping trash; no can that kine! i did not pull the third leaf but instead ADDED the extra overload leaf because i did not want to run into this problem again. in hind sight i think i may have OVER did it with the adding over the xl leaf but i dont regret it. the dakars are very stiff and can handle weight well. the back doesnt even flex now (im exaggerating but you get the point). i measured 25 1/4". a little more rake than i like but im sure these new leaf packs is gonna settle soon.
  4. Apr 7, 2013 at 2:35 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    That's a little more rake than I'm going for. I'm sure the dakars will settle, how much is the question. I'm thinking they might even settle more with the 3rd leaf removed. I'd be happy at 23 1/2 or so. I've read that 2 inches of lift is around where you have to start dealing with vibes. How much troubleshooting did you have to do with vibrations?
  5. Apr 7, 2013 at 2:56 PM
    Xer0 SiN
    Hilo, HI
    this and that...
    ive put on a good 100 miles so far since ive installed the leaf packs; not much since this is not my daily drive. i have since dumped trash and loaded up my quad around just to haste the leaf settling and have not ran into vibration issues. im very grateful for that sitatuion, cause i crossing fingers, toes, and puckering assholes to avoid that issue LOL.
  6. Apr 7, 2013 at 3:41 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    You must be one of the lucky few. Did you have the tsb rear and did you measure pre lift?
  7. Apr 7, 2013 at 3:46 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Do the Wheelers HD
    You will get at least 2 1/2" lift from the Dakars
  8. Apr 7, 2013 at 4:20 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Only reason I was considering dakars is because a couple members in your measurements thread got 23 3/8 with the third leaf removed. One with AC and one DCSB, I'm at 22 now so I could live with another 1.5 inches, and after break in maybe closer to 23.
  9. Apr 7, 2013 at 7:17 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    2 1/2 inches even with the 3rd removed OZ? Not sure if those guys that took it out were running caps or weight in their bed.
  10. Apr 7, 2013 at 7:20 PM
    OZ-T
    Peter North
    British Columbia
    Oh my bad , missed the 3rd removed
    You probably get around 2"
  11. Apr 7, 2013 at 7:41 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Dakar advertises their lift over stock. What do they consider stock? TSB or non TSB springs?
  12. Apr 7, 2013 at 9:03 PM
    OZ-T
    Peter North
    British Columbia
    Non TSB
  13. Apr 7, 2013 at 9:52 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Thanks OZ.
    I'll have to sleep on this... very tough decision.
  14. Apr 9, 2013 at 12:47 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Went with Bilstein 5100 on the 4 corners, Wheelers HD leaf pack, stem cushions and new eye bolts for the rear leafs. Will post pics once installed.
  15. Apr 9, 2013 at 12:57 PM
    OZ-T
    Peter North
    British Columbia
    What's a stem cushion ?
  16. Apr 10, 2013 at 9:38 AM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    The strut stem cushion and washer kit for the top bolt on the struts. The 5100's don't come with new ones so for 20 bucks I ordered replacements for my weather cracked stock ones.
  17. Apr 10, 2013 at 9:46 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I removed the third leaf on my dakars, after install i was at about 23.5", thats with about 100lbs in the bed on my access cab. They have settled a little, ive added some weight with sliders and a hi-lift in the bed, probably only 1/4" lower now. I havnt checked in awhile so ill measure again when im home.
  18. Apr 12, 2013 at 6:05 PM
    TotalBrutal
    TotalBrutal Well-Known Member
    Dan
    Vancouver Island, BC
    2007 V6 4X4
    Front 5100s @ 0, OME 844s, Rear 5100s, AFE pro dry filter
    Interested to see what height your truck sits at with the Wheelers pack... I'd like some stiffer springs that raise the back a wee bit.
  19. Apr 12, 2013 at 8:09 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    I will have the package by the end of next week but probably won't be able to get it on the truck until the week after. I will post pre and post measurements ie: hub to fender, driveline angles and actual measurements along with a few pictures. I will be setting the 5100's at 1.75.
  20. Apr 23, 2013 at 7:50 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Sorry for the crappy cell pics but you get the idea. This is Bilstein 5100's on all 4 corners with the front set at 1.75 with a Wheeler's HD leaf pack in the rear (4 leafs 1 overload).
    Before lift measurements center hub to fender:
    FR: 20 inches
    FL: 20 inches
    RR: 22 inches
    RL: 22 inches
    After lift center hub to fender:
    FR: 22 inches
    FL: 22 inches
    RR: 24 inches
    RL: 24 inches
    Full 2 inches all the way around.
    I haven't got around to measuring post lift drive angles because of all the snow we got but prior to the lift my driveshaft was almost straight with a - 5 deg angle towards the rear end. Will update with better pics when we get a nice day.
    First impressions are pretty good, I haven't been able to try it out that much because of the weather. The ride is slightly stiffer than stock, it doesn't float over bumps anymore it's a little more jarring but nothing crazy. There isn't much room between the 4th leaf and the overload so I can't imagine much flex out of this pack.
    More updates to come.
