2013 3 inch suspension questions
Old 04-10-2013, 11:28 AM   #1
Annolino122 has a spectacular aura aboutAnnolino122 has a spectacular aura about
Annolino122's Avatar
Annolino122's Tacoma Gallery
So for the last few weeks Ive been doing major research on the main types of suspensions (LT, DB, and 3 inch). After going through the pros and cons of each suspension, analyzing what you have to do to the body, frame, and fenders, and also taking into consideration the type of driving and off roading I want to do, I've came to the conclusion that a 3 inch lift would best suit my needs.
So everyone knows (cause from prior posts people getting flamed for not explaining their intentions), I will be driving my truck 75% on road, and 25% off road, some being slow trails and more articulation, and some beig mid speed (30 to 50mph) dirt trails with no extreme whoops or bumps.
Now that you know... Here comes the questions that I can't seem to fully piece together and also would love some comments of each type of suspension I'm looking at. Also, my price range is not set, because i want to do the truck the best way I can for my needs, so if the $1000 is the best, then ill save for it, if a $3500 system is the best, ill save for it.
So here's what I'm looking at:
Toytec ultimate suspension.
Fabtech (either the uniball, or the UCA with dirt logic equipment)
Icon suspension (stage 1,2,3, or 4)
Obviously spending the most money on the icon stage 4 suspension would be ideal, but I want to know if that's too much suspension. Also want to know which kit is best for my situation so I can keep my onroad ride ( it's my DD) and be able to beat it up a little off road and not have to worry.
Another question I have is the tire and wheel sizes that fit, without having to shave, cut, or ulter anything by my wheels, and not have rubbing. Be it the dimensions of the tires being 32's or 31's instead of 33's. or be it spacers, or backspacing... Whatever it is. I would just like to understand what dimensions for
Old 04-10-2013, 11:43 AM   #2
DevL's Tacoma Gallery
You cannot run a 33" tall 285 without cutting. There is no such thing as too much suspension. That said, if you care most about unladen ride quality I'd go King coilover front with reduced valving (digressive Icons can be smoother offroad at speed but firmer on pavement) set to 2-2.5" lift, a Light Racing UCA to add 1 deg caster instead of 2 which will make rubbing a strong possibility, a Deaver rear spring pack (everything else is harsher on road unladen) and King rears... also custom valved soft.
That is the highest quality, least rubbing, softest riding set up. Do not get an E rated tire. Use 30 psi on street. 4.5" backspace wheels.
Old 04-10-2013, 12:16 PM   #3
Ronn is a splendid one to beholdRonn is a splendid one to beholdRonn is a splendid one to beholdRonn is a splendid one to beholdRonn is a splendid one to beholdRonn is a splendid one to behold
Ronn's Tacoma Gallery
4Wheelin4Banger runs a 33" tire (255/85/16) with a 3 inch lift and no cutting IIRC and it looks pretty good
Old 04-10-2013, 12:51 PM   #4
Longtime Toyman
4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed
4Wheelin4Banger's Avatar
Navy: DDG 996
Location: Ferntucky, NV Halfway between Reno & Falabama
4Wheelin4Banger's Tacoma Gallery
You are correct Ronn. 255/85/16 BFG KM2s are 33.3" on 1st Gen TRDs (16"x7" 4.5"BS the decreased BS pushes the tires out .75" farther than stock). I'm running OME 885s & Dakars, originally 3" front & rear (2.5" front on your DCSB or add .25" spacer to get full 3") now 2.75" front & rear after adding sliders & full set of skids with .25" top plate spacer to regain .5" up front.
Great ride on & off road. Firmer than stock but not harsh. Sway bar removed for better articulation, body roll is probably similar to stock.
Very happy with the suspension I got, and the money I saved compared to a higher end system allowed me to get trail armor sooner.
My sig pic is a link to my build thread, click it if you want to see more.
Old 04-10-2013, 01:03 PM   #5
Vaginas are rad.
Boone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shed
Boone's Avatar
Boone's Tacoma Gallery
FWIW I also run a 285/75/16 KM2 With 5100's @ 2.5'' and progressive AAL in the rear with no rubbing, cutting or trimming. 4.5'' BS on FJ's
Old 04-10-2013, 05:23 PM   #6
fireroad has much to be proud offireroad has much to be proud offireroad has much to be proud offireroad has much to be proud offireroad has much to be proud offireroad has much to be proud offireroad has much to be proud offireroad has much to be proud of
fireroad's Tacoma Gallery
Based on your needs and the lifts listed I would say an Icon set-up for sure. The stage 4 would not be "too much suspension" but, given your usage, you would not be getting the most out of your investment. To put it another way, the law of diminishing returns would get you after the stage 2 setup. If it was my hard-earned and your situation I would go for icon's stage 2 plus LR UCA's ....and not loose any sleep over it. That would be a fantastic setup for just under 3k installed.
Old 04-11-2013, 09:06 AM   #7
Okay sorry for the late response to everything.
Soo either I can piece together a suspensions as devl and 4wheel said... Or I can go with the stage 2 icon suspension set up with a UCA... But what is a LR UCA, is that low range?
Old 04-11-2013, 09:09 AM   #8
And truthfully I don't want to piece together a bunch of parts because knowing me I would mess it up.
So from my understanding is the icon stage 2 kit would work the best for my needs with a UCA and would fit 33's without rubbing? What if I dropped down to 32's? Would I not haw to worry at all
Old 04-11-2013, 09:10 AM   #9
And what light racing UCA would you suggest?
Old 04-11-2013, 09:13 AM   #10
evanmb31's Avatar
evanmb31's Tacoma Gallery
Spc makes light racing UCAs, if you going with a high end coilover like icons i would suggest getting a uniball UCA, the light racing UCAs are balljoint style. Uniballs offer cleaner travel
Old 04-11-2013, 09:15 AM   #11
Also looking at the kits in icon... I could go stage 3 and save the money instead of buying separate UCAs and have it all come in 1 kit? Or are there UCAs tha are just as good but cheaper
Old 04-11-2013, 09:15 AM   #12
And what uniball UCAs would you suggest?
Old 04-11-2013, 09:19 AM   #13
bultaco is on a distinguished road
bultaco's Tacoma Gallery
Just go for it! Got a cyber deal on my Stage 4. Billet UCA 's are very nice.
I went with 16 inch wheels and 285's and had minimal trimming after taking off the front flaps. Very happy with it now that got it level and tuned up.
Old 04-11-2013, 09:26 AM   #14
Bultaco... I don't use mud flaps so that's not an issue.
How is the ride on and off road?
Also what parts did you have to trim to cause no rubbing?
Old 04-11-2013, 10:26 AM   #15
Trim
Not much. But again I went 16 inch wheel
Old 04-11-2013, 11:56 AM   #16
Adding a uca that adds caster compounds rubbing issues.
Old 04-11-2013, 11:57 AM   #17
Is that tire 33" tall? I see it is 33.1 and 11.3" wide which is narrow for a 285 however I don't believe you dont rub without trimming under compression while turning. Just not gonna happen.
Old 04-11-2013, 12:05 PM   #18
evanmb31's Avatar
285/75/16 is around 32.6, 32.7". 285 is the width. A 285 on stock wheels requires spacers so the tires dont rub the UCAs. Or you can go with aftermarket wheels with a 0 to -12 offset. If you run a 285/75/16 or 285/70/17 you will most likely have to trim, and theres a possibility that you will have to modify the body mounts, (CMC cab mount chop) just because some people claim they dont rub or have minor rubbing doesnt mean you wont. If you go with 285s be ready to cut
Old 04-11-2013, 12:12 PM   #19
evanmb31's Avatar
This. Which is a common misconception on TW. Most people think added caster moves the wheel foward in the wheel well, but its not that simple. Adding caster at the top of the spindle with the UCA will actually move the wheel back.
Old 04-11-2013, 12:32 PM   #20
Longtime Toyman
Navy: DDG 996
DevL got it right. He just didn't explain it as well as you did.
6 inch suspension lift with 33 inch tires Indytransplant08 Suspension 2 03-19-2013 06:33 AM
2013 SUSPENSION PROBLEM!!!! EVILSKEEMZ Suspension 28 10-22-2012 02:02 PM
New 2013 questions Joe.erau 2nd Gen. Tacomas 0 09-16-2012 07:41 PM
rough country 3 inch suspension lift questions whiteboytoy05 Product Reviews 11 10-11-2011 02:04 PM
9 inch suspension lift questions CAN8EN 2nd Gen. Tacomas 47 03-07-2011 10:47 AM
