Can I put king coils on bilstein shocks?
Discussion in 'Suspension' started by corey.blanco, Apr 18, 2013.
  1. Apr 18, 2013 at 7:28 AM
    corey.blanco
    corey.blanco [OP] Member
    Corey
    Miami, Florida
    13 PreRunner 2.7L 4x2
    plastidipped rims, removed mud flaps, plastidipped grill, debadged, BHLM, tinted taillights and 3rd brake light
    Hello TW, new here. Just wondering if I can put king coils on bilsteins. I know it may not make much sense but I could buy these used for a great price on bilsteins and upgrade shocks later, when I get some more money. Will this fit?
  2. Apr 24, 2013 at 12:45 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    BUMP also interested in this
  3. Apr 24, 2013 at 1:41 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Short answer is no.
    Coil springs for Icon, King and other adjustable coilovers are ground flat on the top and bottom.
    The stock springs (and OME 88x) are only ground flat on the top. The bottom is an open coil and the bottom seat of the Bilstein 5100s are designed for that open coil, not a ground flat coil.
    Look at the differences of the bottom of the springs.
    Open Coil at the bottom
    Ground flat at the top and bottom
    Toytec makes an that require you to have a ground flat coil.
  4. May 25, 2014 at 11:44 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Bit of a zombie thread, but could the bottom just be clipped off? That adaptor hyperlink is no longer workin btw.
  5. May 25, 2014 at 12:13 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
  6. May 25, 2014 at 12:16 PM
    yota243
    E.J.
    north Alabama
    I see that but if u bought coils that were longer than u needed, could u not just clip them to length and get around the adapter? That was my. Real question
    Like this kinda, sorry cant figure photo shop out
  7. May 26, 2014 at 6:54 AM
    Mainmoe02
    Moe
    Austin, Texas
    As long as it doesn't effect the spring rate. But if your wanting to use the Coilover setup then no matter where you clip the coil it's still not gonna sit flat, unless maybe you grinded them flat, if that's possible. If your gonna use a coil seat like the oem ones or bilstein/ OME, then I think you'd be ok clipping the coil to the proper length.
  8. May 26, 2014 at 7:11 AM
    yota243
    E.J.
    north Alabama
    Yeah i just got 5100's and am installing them today, but i have off road springs and if i dont like the ride or want more height with out preloading any more, dsm has king coils on sale for $65 and free shipping any length, diameter, and spring rate, so i thought that would be a good economical alternative.
  9. May 26, 2014 at 7:15 AM
    Mainmoe02
    Moe
    Austin, Texas
    Wow $65 for king coils, are they 650# coils? Sounds like a good deal
  10. May 26, 2014 at 7:20 AM
    yota243
    E.J.
    north Alabama
  11. May 26, 2014 at 7:30 AM
    Mainmoe02
    Moe
    Austin, Texas
    Probably get the 2.5" coil for a shock body that's 2.0" (like the billies). If you get a shock body that's 2.5" then you should probably get the 3.0" coil. As for length I think your gonna want somewhere around 13-14 inch length coil with anywhere from 550-700 #'s. The length and spring rate depend on what your wanting. If your gonna add some weight or a lot of weight? How much lift you want? What type of ride your after, on the cushy side or firmer side? Also depends on if your truck is a 1st or 2nd gen.
  12. May 26, 2014 at 12:04 PM
    yota243
    E.J.
    north Alabama
    Im a 2nd gen. I dont want it to ride like a car but i dont want it to ride like a jeep either. Id keep it at or below 2.5" so i didnt have to change my ucas. And im gonna build a c channel bumper next month that shouldnt weight more that 50# give or take. I just finish my install and im gonna see how they do for now.
  13. May 26, 2014 at 12:33 PM
    Mainmoe02
    Moe
    Austin, Texas
    I think a 600# coil should be good for you being a second gen. But maybe do some research on those 2nd gen guys and see what they are running. I know the 620# EIBACH coil will give a 1st gen 3" lift and a 2nd gen 1.65" lift. Just some info to base your spring rates off of
  14. May 26, 2014 at 12:44 PM
    yota243
    E.J.
    north Alabama
    Is that a 14" coil?
