Wondering about a 2 inch leveling kit
Old 05-07-2013, 11:46 AM   #1
battlezone [OP] battlezone is offline
battlezone is on a distinguished road
battlezone's Tacoma Gallery
I was thinking about getting a 2.25 inch leveling kit put on my 2012 Tacoma DCB sport 4x4
http://www.4wheelparts.com/Lift-Kits...&t_pn=EXP65205
I was wondering if anyone could show me pictures of lifts close to 2.25 inches that still had stock rims and tires on them, i want it to look good. with that 2.25 lift would i need to get bigger rims and tires to make it look good? (i was hoping not to, so that i wouldnt have to lose MPG) Thoughts? Pics?
Old 05-08-2013, 06:25 AM   #2
sirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shed
sirsaechao's Avatar
sirsaechao's Tacoma Gallery
Personally I would get Bilstein 5100's and set them in the 1.75" and call it good.
Old 05-09-2013, 06:39 PM   #3
Primo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shed
Primo 95's Avatar
Primo 95's Tacoma Gallery
^^^^ What he said. 2.25" is going to be way too high in the front. 5100 set at 1.75" in the front will make it perfectly level and have a better ride...that is my set up
Just about any aftermarket wheels will look better than stock. even only 1 tire size up will make a big difference.
265/75/16 - 5100s set at 1.75" in the front. 4 Factory leafs in the rear. No Rubbing. Much better ride & handling than stock.
See my write ups on this topic
http://www.tacomaworld.com/forum/wheels-tires/260429-2013-dcab-small-lift.html#post6375347
Old 05-12-2013, 04:37 PM   #4
Won't the increase in tire size decrease the has mileage and throw off the speedometer? Or is that false info that I was told?
Old 05-12-2013, 04:39 PM   #5
KodiakToyTRD is one of the sharper tools in the shedKodiakToyTRD is one of the sharper tools in the shedKodiakToyTRD is one of the sharper tools in the shedKodiakToyTRD is one of the sharper tools in the shedKodiakToyTRD is one of the sharper tools in the shedKodiakToyTRD is one of the sharper tools in the shedKodiakToyTRD is one of the sharper tools in the shedKodiakToyTRD is one of the sharper tools in the shedKodiakToyTRD is one of the sharper tools in the shedKodiakToyTRD is one of the sharper tools in the shedKodiakToyTRD is one of the sharper tools in the shed
KodiakToyTRD's Avatar
Law Enforcement:
KodiakToyTRD's Tacoma Gallery
Definitely go with 5100's at 1.75, that was my set up and I had stock tires and wheels.
Old 05-12-2013, 04:56 PM   #6
tacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shed
tacosupreme54's Avatar
tacosupreme54's Tacoma Gallery
Leveling kits (spacers) ride like poop. Bumping up to 265/75/16 or 265/70/17 (which is what you could run if you got the 5100's) would make negligible difference in mpg. And supposedly the stock configuration of the speedometer is actually a little low, and adding a slightly larger tire will actually get it closer to correct. I can't confirm that, just something I've heard multiple times on here though. Trust me on this though. I've had a leveling kit and spacers = crap. Do it right the first time with the 5100 shocks. You can set them to .85" 1.75" or 2.5". Also 265/75/16's made no difference for me personally.
Old 05-13-2013, 04:48 PM   #7
Dixon22 is on a distinguished road
Air Force:
Dixon22's Tacoma Gallery
I put on the 265/70/17 on my 2010 sport Double Cab
After getting them on, it did actually fix the speedometer. Toyota wont adjust your speedometer as long as it's 7mph and below off. Mine used to be off by 3-4mph but now it's spot on. Funny but very true. What about this leveling kit......doetsch-2006-uptac-2wd-trd-ez-lift. I really want one but have nothing on my truck.
Old 05-13-2013, 07:22 PM   #8
Good to hear. I wouldn't get an ez lift or spacer lift. For about the same price or cheaper than most spacer kits, you can get a set of adjustable billstein 5100 shocks. You can adjust them from .85" 1.75" and 2.5" of lift in the front to level it out. I can guarantee they will ride better than spacers. Research them on this site, so you won't waste your money on junk.
Old 05-13-2013, 07:34 PM   #9
Air Force:
thanks for the advice man. Looking now actually.
3 inch leveling kit Sida914 Buy / Sell / Trade 2 04-05-2013 06:06 PM
2 inch leveling kit? tristen Suspension 10 10-02-2012 07:43 PM
1.5 inch leveling kit for sale checker c5 2nd Gen Tacoma Marketplace 0 06-28-2012 08:22 AM
2.5 inch toytec leveling kit (used) PPD934 Buy / Sell / Trade 2 01-03-2011 11:23 AM
3 inch leveling kit rejTRD 2nd Gen. Tacomas 31 02-27-2009 04:11 PM
