Bilstein 5100 for a 97 Tacoma
Old 05-08-2013, 09:14 AM   #1
Rosco97 [OP] Rosco97 is offline
Rosco97 is on a distinguished road
Rosco97's Tacoma Gallery
So I'm looking at getting the Bilstein 5100 for the front and rear of my truck. The truck is still stock so I'm thinking I should probably replace the front coil springs too. What advice do you have on that setup?
Old 05-08-2013, 10:57 AM   #2
Independent Thinker
Lumpskie is one of the sharper tools in the shedLumpskie is one of the sharper tools in the shedLumpskie is one of the sharper tools in the shedLumpskie is one of the sharper tools in the shedLumpskie is one of the sharper tools in the shedLumpskie is one of the sharper tools in the shedLumpskie is one of the sharper tools in the shedLumpskie is one of the sharper tools in the shedLumpskie is one of the sharper tools in the shedLumpskie is one of the sharper tools in the shedLumpskie is one of the sharper tools in the shed
Lumpskie's Avatar
Lumpskie's Tacoma Gallery
I'm not sure what type of wheeling you do, or if you have a lift. That being said, I've got a '96 with a similar setup. In front, I've got Tundra 5100s inside of the "build it yourself" Toytec coilover. The coil is a 16", 600 lb coil. This setup has worked great for me. I've got a front bumper, winch, and full skid plates so the larger shock doesn't overheat as easily and the coil matches my truck's weight really well.
Here's a picture of my setup under full compression (you can see my LCA on the bump stop):
Here's a pic with the coilover extended a bit. Not full extension though.
I've got 7100 short bodies in my rear, so I can't speak to the 5100s as much there:
Old 05-08-2013, 11:16 AM   #3
I don't do to much aggressive wheeling. I just bought my truck so I'm still getting started. With the 5100's and Toytech coil overs, how much will that lift the truck? And what do you have a for a lift in the back besides the 7100 short bodies?
Old 05-08-2013, 11:43 AM   #4
Independent Thinker
Lumpskie's Avatar
So, you can set the coilovers to any ride height you want (0-3 inches of lift), but they are more expensive than just buying a lift spring and shock by about $200. I bought the coilover because I am OCD and wanted the truck to sit exactly level (Left/Right).
In the rear, I have a custom 8 leaf pack from Alcan and a 1.5" longer shackle (5.5" eye to eye). My total front lift is just under 3" and my rear lift is about 3.75". My truck is raked but it's very functional off road.
What I'd do, in your situation, is give Toytec a call and ask for "Jeff". Tell him "Lumpskie" told you to call and he'll know me. He's really knowledgeable and you can tell him what you plan on doing with your truck. Also, he'll give you any discounts that he can.
Old 05-08-2013, 12:05 PM   #5
Ok thanks! I emailed toytec and told them what I wanted to do with the truck and that you referred me. Thanks for your help!
Toyota Tacoma Bilstein 5100 Question - HELP Tacozona 1st Gen. Tacomas 56 08-26-2014 09:36 AM
2005-Up Tacoma Rear Bilstein 5100's Downsouth Motorsports 2nd Gen. Tacomas 21 06-24-2014 10:15 AM
2012 TRD Tacoma Bilstein 5100's ? Tacoma20 New Members 3 10-31-2012 03:58 PM
09 Tacoma Bilstein 5100 TMP1207 2nd Gen. Tacomas 9 07-14-2010 07:15 PM
Tacoma Bilstein 5100 08TRD Sport 2nd Gen. Tacomas 4 01-30-2010 12:47 PM
