axle wrap help
Old 05-10-2013, 12:46 PM   #1
chasebrooks14 will become famous soon enoughchasebrooks14 will become famous soon enough
chasebrooks14's Avatar
chasebrooks14's Tacoma Gallery
axle wrap help
So i figured out i had bad axle wrap and am looking for traction bars. yet i do not know much about them so i found this one by tuff country
the ones by pro comp require a lift on it and i dont have that. i just need it for stock hieght. should i get this one? i need all the help i can get
Old 05-10-2013, 02:02 PM   #4
Carolina Alliance Southwest Region Ambassador
jandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shed
jandrews's Avatar
jandrews's Tacoma Gallery
Get ruff stuffs kit and have it fitted to your truck.
All the other designs are flawed in some way.
Old 05-10-2013, 06:02 PM   #5
sirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shed
sirsaechao's Avatar
sirsaechao's Tacoma Gallery
How about beefier rear spring leaf pack instead? Like:
http://www.wheelersoffroad.com/tacoleafs.htm
Old 05-11-2013, 07:13 PM   #7
Ronn is a splendid one to beholdRonn is a splendid one to beholdRonn is a splendid one to beholdRonn is a splendid one to beholdRonn is a splendid one to beholdRonn is a splendid one to behold
Ronn's Tacoma Gallery
Don't those go on the top of the leaf?
Old 05-11-2013, 07:16 PM   #8
Whyareyoureadingthis?
VirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shed
VirginiaBound's Avatar
Name: Sam I am, green eggs and ham
VirginiaBound's Tacoma Gallery
Originally Posted by chasebrooks14 View Post
fixed it with these $37 helper leafs
You don't even need the helper leaf. That's not stopping the axle wrap.
The clamp on the front of the leaf keeps them from separating.
All that's needed is a clamp to keep the springs from separating under acceleration, the helper leaf is simply resting under the leaf pack until those springs frown enough to apply pressure to the helper, which helps hold the weight.
Old 05-11-2013, 07:24 PM   #9
payrow is on a distinguished road
payrow's Avatar
payrow's Tacoma Gallery
Originally Posted by payrow View Post
Well, completed the install and after driving around yesterday and today....NO MORE BUMP!!!!
Thanks for your help guys!
Installed the 2.5 in wide (Autozone Part Number: 13-1401A $15) clamps about 4in in front of the axle and torqued them down to 50ft lbs. That did the trick!
I am happy happy happy.
This made all the difference, you may want to try it out
Old 05-11-2013, 07:26 PM   #10
Exactly. All you need are the clamps to prevent the springs from separating.
Old 05-11-2013, 07:51 PM   #11
jandrews's Avatar
Honestly, aside from the traction bar, spring clamps did more to lessen my axle wrap than any other solution.
Trac bar is the one true fix, but if the budget is tight, I'd just clamp the springs.
Is this Axle wrap? Rebel Taco Man 1st Gen. Tacomas 5 02-05-2013 02:07 PM
Axle Wrap? Rebel Taco Man 1st Gen. Tacomas 5 08-29-2012 08:01 AM
Axle wrap Daddyants1122 Solid Axle Suspension 5 08-01-2011 03:18 PM
Axle Wrap SPOOK 1st Gen. Tacomas 1 06-21-2011 06:30 AM
Think it's axle wrap? chad68 Suspension 9 05-16-2010 11:26 AM
