Bds 6 inch coilover lift kit.yay or nay?
Old 05-19-2013, 11:18 PM   #1
cdelgado14 [OP] cdelgado14 is offline
cdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to behold
cdelgado14's Tacoma Gallery
Anybody running this lift currently?hows the ride?worth 3100$?
Old 05-20-2013, 12:37 AM   #3
The Dank Tank
Blacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shed
Blacktacoma23's Avatar
Blacktacoma23's Tacoma Gallery
Arrow
Ride is pretty cherry! (except rear blocks)
Just make sure your dead set on a DB lift
Maybe get new UCA's
Old 05-20-2013, 03:51 AM   #4
Nice.ever guna get rid of the rear blocks?i was told that if I didn't not want the blocks..they could order me shocks for the rear.extra 1400$.any cheaper ideas?what size tires are you rolling on?
Old 05-20-2013, 03:53 AM   #5
What is "db"?
Old 05-20-2013, 04:13 AM   #7
Buck717 is on a distinguished road
Buck717's Avatar
Buck717's Tacoma Gallery
How do shocks get rid of the blocks? Am I missing something?
I have the BDS lift but I did spacers. Get the fox coil overs from the get go, or you'll just be upgrading in 6 months to a year like me. Luckily the coil overs come assembled so its a easy swap!
As for the rear blocks you'll need a spring pack to get rid of them, also in my plans at some point.
Also the bump stops that came with my kit were too big so I got low pro ones from amazon for $12, much nicer.
Old 05-20-2013, 04:35 AM   #8
Mmm have coils for the rear..?Spring pack.where can they be found an how much do they run?I'm running a 3 inch.just not sure if the 6 is going to be better or not..As far as bumps..?im lost.
Not too familiar with this field.what does the db have to do with a 6 inch..?Also..in what way does the UCA help?are they a must?
Old 05-20-2013, 06:17 AM   #9
Buck717's Avatar
Spring packs are about $500 a pair, give or take, you have leaf springs in the back not coil. Bump stops are what limit the Up travel of the front suspension, the smaller the more travel you have. The ones that came with my kit must have been misboxed because they were always touching the LCA.
DB is drop bracket. Means they add a lower cross member, taller steering knuckles, that's where the lift comes from to allow bigger tires. Stock UCAs are fine, after market allows more camber adjustment and better caster, they are not a must.
Old 05-20-2013, 07:38 AM   #10
Where can they be purchased?
Old 05-20-2013, 12:39 PM   #11
Buck717's Avatar
Leaf springs from
customsuspension.com
Bump stops from amazon
BDS 6 inch Lift. Hollyhonda82 Suspension 8 09-26-2014 06:30 AM
4 inch BDS lift cost jaysly Suspension 1 04-30-2013 09:50 AM
Toytec Ultimate Lift Kit 3in...yay or nay? LeanMeanGreenTaco 1st Gen. Tacomas 6 05-10-2011 10:18 AM
Rear Lift??? Yay or Nay Zac808 Suspension 13 01-09-2011 10:59 PM
Total Chaos 6 inch lift or BDS ? Audra Suspension 10 02-18-2010 03:30 PM
