6 inch DB lift brake lines
Discussion in 'Suspension' started by blake5995, May 22, 2013.
  1. May 22, 2013 at 10:32 PM
    blake5995
    blake5995 [OP] Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    My buddies truck lost the spindle the other day and now i need to get a new front brake line. does anyone know where i can get one very very quickly. only need the driver side line.
  2. May 22, 2013 at 10:32 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    Should be factory
  3. May 22, 2013 at 10:39 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Does DB stand for douch bag?
  4. May 22, 2013 at 10:51 PM
    blake5995
    Blake
    Truckee, CA
    drop bracket lift and they are 6 inch extended
  5. May 22, 2013 at 10:52 PM
    PLC721
    Patrick
    Chandler, Az
    It has a relocation kit that allows use of the factory lines
  6. May 22, 2013 at 10:53 PM
    blake5995
    Blake
    Truckee, CA
    really? i took the one that broke and put it next to mine on my truck and it is about 5 3/4 inch longer than mine
  7. May 22, 2013 at 11:27 PM
    PLC721
    Patrick
    Chandler, Az
    That's odd. I replaced mine with stainless ones 6" longer than factory and they were way to long and had to be in a loop to fit. Anywho, PM OCtaco on here he does good brake lines I recommend him
