3" Lift with 33's?
Old 06-16-2013, 10:23 PM   #1
FixItTicket is on a distinguished road
EMS:
FixItTicket's Tacoma Gallery
3" Lift with 33's?
So earlier today I was wanting to get myself a nice 6" suspension lift on my DCSB tacoma but after doing a lot of research I changed my mind and would rather get some really nice coil overs with UCA nice rear shocks and leaf pack maybe some deavers or all pro. My question is would I be able to fit 33's with that set up without rubbing?
Old 06-16-2013, 10:24 PM   #2
Bro do you even 'Merica?
jdk52 is one of the sharper tools in the shedjdk52 is one of the sharper tools in the shedjdk52 is one of the sharper tools in the shedjdk52 is one of the sharper tools in the shedjdk52 is one of the sharper tools in the shedjdk52 is one of the sharper tools in the shedjdk52 is one of the sharper tools in the shedjdk52 is one of the sharper tools in the shedjdk52 is one of the sharper tools in the shedjdk52 is one of the sharper tools in the shedjdk52 is one of the sharper tools in the shed
jdk52's Avatar
Air Force:
jdk52's Tacoma Gallery
yes, just make sure you get enough offset on the wheels.
Old 06-16-2013, 10:28 PM   #3
EMS:
okay awesome! Would you recommend some spindles with that set-up or do you think that's just fine if I go with a camburg kit as far as off roading it goes?
Old 06-16-2013, 10:30 PM   #4
redtacoma88 is one of the sharper tools in the shedredtacoma88 is one of the sharper tools in the shedredtacoma88 is one of the sharper tools in the shedredtacoma88 is one of the sharper tools in the shedredtacoma88 is one of the sharper tools in the shedredtacoma88 is one of the sharper tools in the shedredtacoma88 is one of the sharper tools in the shedredtacoma88 is one of the sharper tools in the shedredtacoma88 is one of the sharper tools in the shedredtacoma88 is one of the sharper tools in the shedredtacoma88 is one of the sharper tools in the shed
redtacoma88's Avatar
redtacoma88's Tacoma Gallery
You should be able to fit 33's. REMEMBER Spindle lifts are only for 2wd, idk if you are 4x4 or not. Smart choice about going with coilovers and UCA's.
Old 06-16-2013, 10:33 PM   #5
EMS:
yea I saw this tacoma at a dealership with a 6" lift, fell in love with the look didn't realize that the 6" db is only good for the look and then read some stuff about how amazing the coil over uca set up is for offroading. I have a 2wd would you recommend spindles like the TC ones or should the coil overs and UCA be enough?
Old 06-16-2013, 10:42 PM   #6
GO VOLS!
TnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shed
TnRedNeck721's Avatar
TnRedNeck721's Tacoma Gallery
I’m not 100% sure but i think some one makes a 4” llift spindles. maybe it’s 4.5”
I also think that most the hate for 6” lift comes from 4wd guys, because you actually lose ground clearance with the drop bracket. I like the looks of the 6”, but i want to really get into off roading(if i could get the cash to do so) and the 3” is better for 4wd guys wanting to off road a lot/ really hard. But since you are 2wd you don’t have that.
If i was you and had a 2wd, I’d get a 6” and 35”s. and sounds like thats what you really like the looks of, so why not do it exactly like you want?
Old 06-16-2013, 10:45 PM   #7
EMS:
I thought the 2wd had drop brackets does it not with a 6" lift?
and also because I read through this whole thread
http://www.ttora.com/forum/showthread.php?t=132096
and they bagged on the 6" lifts throughout the whole thing said the coil overs with UCA are the better way to go as far as offroad performance is concerned.
Old 06-16-2013, 10:50 PM   #9
EMS:
Originally Posted by Blackdawg View Post
Stick with just coil overs and UCAs.
could you elaborate a little more on why that set-up is better because I have no idea why it's better other than that's what everyone is saying. btw just in case nobody knows I have a 2wd...
Old 06-16-2013, 10:50 PM   #10
Problem Solved, Toytech has this 6" lift for 2wd, its has spindles and toytech coil-overs.
http://toyteclifts.3dcartstores.com/...ift_p_880.html
(i would get the optional UCA's with it.
Then fit some 35" tires and 18" rims under this and it will be perfect. Just my 2 cents
Old 06-16-2013, 10:53 PM   #11
Dr. Frankenstien
Blackdawg is one of the sharper tools in the shedBlackdawg is one of the sharper tools in the shedBlackdawg is one of the sharper tools in the shedBlackdawg is one of the sharper tools in the shedBlackdawg is one of the sharper tools in the shedBlackdawg is one of the sharper tools in the shedBlackdawg is one of the sharper tools in the shedBlackdawg is one of the sharper tools in the shedBlackdawg is one of the sharper tools in the shedBlackdawg is one of the sharper tools in the shedBlackdawg is one of the sharper tools in the shed
Blackdawg's Avatar
Blackdawg's Tacoma Gallery
Your not gaining anything really with spindles..some front end clearance I suppose.
Just UCAs and a nice CO will ride better.
But if your not into offroading or having looked t long travel yet(if you do you will want it haha) then go for the spindles.
Old 06-16-2013, 10:55 PM   #12
GO VOLS!
no donít think so! the drop bracket drops/lower the front diff to keep the right angles on the drive shafts.
also coil overs are kinda the way to go. but agin i donít know anything about spindles.
Old 06-16-2013, 10:56 PM   #13
EMS:
I'm definitely into offroading but I'd rather not drop a bunch of cash on a LT kit. BTW how does this kit look??
http://camburg.com/store/kits-05-12-...mance-6-0-kit/
Has coilovers for about 10" of travel deaver leafs in the back with bilstein 5100 shocks and UCA specifically says no DB and gives 4 to 6 inches of lift what do you guys think?
Old 06-16-2013, 11:47 PM   #14
Tkucera is on a distinguished road
Tkucera's Tacoma Gallery
Lift with 33'
Hello
I have a 2.7 litre 4 cylinder 2wd 2012 toyota tacoma I want to put it on a lift with 33 in tires but I only see lift kits for the prerunner 2wd wich isn't my truck was wondering if the lift would work on mine even though it isn't a prerunner
Old 06-16-2013, 11:49 PM   #15
5 lug
Fitment: 07 with a 3" lift 33"12.5" 17" Saskyota Wheels & Tires 9 01-16-2014 12:17 PM
2009 3" Lift! Wa-Hoo!!! 3" 33" 17 moto metals.... kcmac2435 2nd Gen. Tacomas 67 02-09-2013 05:13 PM
4.5" lift, 33" KM2s, tube bumper! With pics brett3xx 1st Gen. Tacomas 55 01-19-2013 07:17 AM
VSC Issue with new 33" tires, Spidertrax and 3" spacer lift cehensley 2nd Gen. Tacomas 5 03-19-2012 06:32 PM
Noob questions about 33"s on stock 15x7 rims, with 2.5" lift woodpost Wheels & Tires 3 09-07-2011 03:03 PM
