Need advice from a fellow 6" Pro Comp lifted Tacoma owner
Old 07-02-2013, 05:57 PM   #61
iJonny [OP] iJonny is offline
TACOMA, If I wanted a HUMMER I'd call your mom.
iJonny is one of the sharper tools in the shediJonny is one of the sharper tools in the shediJonny is one of the sharper tools in the shediJonny is one of the sharper tools in the shediJonny is one of the sharper tools in the shediJonny is one of the sharper tools in the shediJonny is one of the sharper tools in the shediJonny is one of the sharper tools in the shediJonny is one of the sharper tools in the shediJonny is one of the sharper tools in the shediJonny is one of the sharper tools in the shed
iJonny's Avatar
iJonny's Tacoma Gallery
Parts list is the 1st post, its only chaged a little. Im not doing the ubolt flip and the ICON coils will be extended travel. Do you really think I will need straps up front Patrick? I haven't spoke to SDHQ, ive been doing the research with Total Chaos and ICON on my own.
Im also fairly certain I will have SDHQ do the labor now and take it to Network for the alignment.
How many inches of wheel travel must I have before needing straps? What does it cost?
Old 07-02-2013, 09:06 PM   #62
PLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shed
PLC721's Tacoma Gallery
It's just to protect your coilovers from over extending, which in your application isnt a big deal. they are cheap anyways if you do feel the need for it but i wouldnt worry about it
Old 07-03-2013, 05:54 AM   #63
iJonny's Avatar
Haha, which one is it? You suggest to run, then dont. Is it plausible that I can overextend with this application? I will see what SDHQ has to say regardless but since you raised alarm id like to know more.
Old 07-03-2013, 08:57 AM   #64
AaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shed
AaronArf's Avatar
Navy:
AaronArf's Tacoma Gallery
All that work and gucci parts with no ubolt flip kit?
Old 07-03-2013, 09:14 AM   #65
I didn't mean "you" specifically!
For your application and how your going to wheel the truck I don't see a need for you to strap it
Old 07-03-2013, 11:31 AM   #66
iJonny's Avatar
no point to a flip and it creates another purchase for bump stops. Sure it protects the thread on the ubolt but they are cheap to replace if damaged. Im saving the 100$ and will end up putting it towards armor.
There is no travel gained with a flip, the pumpkin is still the most likely to take the hit.
Old 07-03-2013, 11:33 AM   #67
iJonny's Avatar
They remove a spacer inside the shock assembly that prevents the shock from over extending, you gain 1" of shock travel which equals more than 1" of wheel travel, but you should run straps
I was confused when you said "but you should run straps" in response to my post. My bad
Old 07-03-2013, 11:38 AM   #68
AaronArf's Avatar
Navy:
With the 6" lift and no blocks in the rear, the tiny factory bump stop height is useless...
Old 07-03-2013, 01:56 PM   #69
808 Member
WailuaTaco808 is one of the sharper tools in the shedWailuaTaco808 is one of the sharper tools in the shedWailuaTaco808 is one of the sharper tools in the shedWailuaTaco808 is one of the sharper tools in the shedWailuaTaco808 is one of the sharper tools in the shedWailuaTaco808 is one of the sharper tools in the shedWailuaTaco808 is one of the sharper tools in the shedWailuaTaco808 is one of the sharper tools in the shedWailuaTaco808 is one of the sharper tools in the shedWailuaTaco808 is one of the sharper tools in the shedWailuaTaco808 is one of the sharper tools in the shed
WailuaTaco808's Avatar
WailuaTaco808's Tacoma Gallery
Originally Posted by EATABULLETcom View Post
You have a spacer on top of your coil over and they are cranked up too high, that's killing your down travel
yessir i learned that lesson the hard way. The spacer is getting tossed but i was just curious if the OP is trying to gain more height out of his DB lift or just more travel or both. Or if he is just trying to stick with the 6 inch height and reinforce the weak PC stage 1 lift.
Old 07-03-2013, 02:11 PM   #70
iJonny's Avatar
No more height, just travel & strength
Old 07-03-2013, 03:44 PM   #71
808 Member
Gotcha! thanks for the clerification (my addiction to an inch or 2 more of height is killing me hahaha) But i will be removing that damn spacer very soon and messing with the C/o height to get exactly what i want with plenty of travel as well. Look forward to seeing ur rig all finished so i can compare notes
Old 07-03-2013, 07:17 PM   #72
iJonny's Avatar
Good stuff man! Im confident my ride will be pretty solid.. sure is going to cost enough to get me there
Old 07-05-2013, 09:51 AM   #73
Banned
Phil Dammit is one of the sharper tools in the shedPhil Dammit is one of the sharper tools in the shedPhil Dammit is one of the sharper tools in the shedPhil Dammit is one of the sharper tools in the shedPhil Dammit is one of the sharper tools in the shedPhil Dammit is one of the sharper tools in the shedPhil Dammit is one of the sharper tools in the shedPhil Dammit is one of the sharper tools in the shedPhil Dammit is one of the sharper tools in the shedPhil Dammit is one of the sharper tools in the shedPhil Dammit is one of the sharper tools in the shed
Gender: Trans
Phil Dammit's Tacoma Gallery
Whens the build day and pics of said pieces/parts anywhere in this thread?
Old 07-05-2013, 09:59 AM   #74
iJonny's Avatar
TC UCA w HEIM & Racing LCA Here
Icon Coils Here
Deavers Here
SDHQ Here
For piece of mind I am no longer doing the install. I am trusting all of this work to SDHQ! I would have to go down there for a re-torque & alignment anyway
Old 07-05-2013, 10:11 AM   #75
Banned
Gender: Trans
Icon Coils Here
Deavers Here
SDHQ Here
You gay, don't trust your own work huh? That bumper on the chaos page is clean....
Old 07-05-2013, 10:20 AM   #76
pa blaster is one of the sharper tools in the shedpa blaster is one of the sharper tools in the shedpa blaster is one of the sharper tools in the shedpa blaster is one of the sharper tools in the shedpa blaster is one of the sharper tools in the shedpa blaster is one of the sharper tools in the shedpa blaster is one of the sharper tools in the shedpa blaster is one of the sharper tools in the shedpa blaster is one of the sharper tools in the shedpa blaster is one of the sharper tools in the shedpa blaster is one of the sharper tools in the shed
pa blaster's Avatar
pa blaster's Tacoma Gallery
Old 07-05-2013, 10:49 AM   #77
iJonny's Avatar
Its not that at all PhillyD! It would be different if I had my own garage, my own tools or even my brother around. He is has been a master mechanic for 20 years and has everything (including air tools). But unfortunately, he isnt in AZ anymore and I would have to rely on Jason Ks garage, tools and a few of you guys to spend a day wrenching in 120 degree heat. That is a lot to ask of you all but I sincerely appreciate everyone who jumped up and offered help. Due to the amount of work needed, I'm trusting SDHQ and Its the right decision.
Old 07-05-2013, 11:16 AM   #78
Banned
Gender: Trans
Oooo so you don't trust us now, and here I thought we were the real deal Jon...
Old 07-05-2013, 11:41 AM   #79
iJonny's Avatar
YOURE STILL MY BOY BLUE!!!
Old 07-05-2013, 11:48 AM   #80
Banned
Gender: Trans
Lmao
coilovers for already lifted 6 inch pro comp saltidadyo 2nd Gen. Tacomas 26 09-14-2013 05:33 PM
Advice for Pro Comp 3" Suspension lift cabz1691 Suspension 0 06-09-2012 09:47 AM
"NEW" Looking at 6" Pro-comp lift Any advice MamouCoonass Suspension 7 05-10-2012 03:18 PM
96-04 tacoma pro comp 4" lift kit and 3.5" rear procomp leafs tacoma27 Buy / Sell / Trade 1 06-26-2010 05:28 PM
6" Pro Comp on 07 Tacoma caglezxj Suspension 63 02-17-2010 03:25 PM
