Advice on 5100 setting
Discussion in 'Suspension' started by Taco2112, Jun 26, 2013.
  1. Jun 26, 2013 at 4:07 PM
    Taco2112
    Taco2112 [OP] Active Member
    Pittsburgh
    13 4x4 access cab 2.7
    265/75/16 Firestone Destination A/T, Trd or wheels, Bilstien 5100's all the way around set at .85 in the front Comming soon LC Engineering header, avid light bar, lights
    Ok so my 5100's should be here Friday . I have been reading through countless post and have done a ton of searching but I seem to keep getting different answers. I have a 2013 and only have 2500 miles on it right now. I was going to just set the front at .85 to make it more level. Doing more research I am thinking about doing a 1.5 inch aal and setting the bilstein's to 1.75. I see most people say that is no problem but some say they get vibes at 1.75 with aal. I want to keep my ride as close to stock as possible. So at 1.75 with an aal would I get vibes? Also is the 1.75 setting too hard on stock parts like cv's and uca's? I have a access cab 4 cyl 4x4 I don't have the tsb done.
  2. Jun 26, 2013 at 4:08 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    You'll be fine at 1.75.
  3. Jun 26, 2013 at 5:36 PM
    Chakraj
    Chakraj Well-Known Member
    CA
    2013 DCSB TRD SPORT v6 auto 4x4
    Badgers, I don't need no stinking Badgers.
    I just put 4 / 5100's on my new 2013 dcsb 4x4 set the fronts at 1.75, didn't touch the back yet, it's sitting level/bro lean right now. I had the shop align it three times to get it right. Right now it's
    Lft/Rght
    Camber .05/.06
    Caster 2.0/1.6
    Toe .11/.12
    But I am still unhappy with the camber. I really want 0/0 for tire wear. Do you think I should go back again? Or go somewhere else? Or just live with it?
    Oh and it rides much better with the5100
  4. Jun 28, 2013 at 7:42 AM
    Taco2112
    Pittsburgh
    My 5100's came in today. I'm going to try to get them put on tomorrow. I have decided to go with the .85 setting. I will post some pics after they are on.
  5. Jun 28, 2013 at 7:47 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    I'd be going back. They should be able to get your camber closer to 0, your caster evened up and your toe closer to 0. If you feel that the shop is willing to take care of you and your truck, go back. If not, I would look into another shop.
  6. Jun 28, 2013 at 3:09 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    x2 , shop should easily hit your numbers I'd think...
  7. Jun 28, 2013 at 3:16 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    You'd be fine at 1.75" setting. CV's look good at that setting as well and alignment shouldn't be a problem. As for the rear, it's a hit and miss for vibes with people. Be sure to get a CB drop to prevent vibes.
  8. Jul 13, 2013 at 4:03 AM
    Taco2112
    Pittsburgh
    Getting my 5100s on today finally. They have been sitting in the spare room for a couple weeks. Setting them at .85. I will post up before and after pics later
  9. Jul 13, 2013 at 3:22 PM
    Tacozilla
    Tacozilla Well-Known Member
    So Cal
    2013 DCLB TRD 4X4 MGM
    Diffinitly would like to see pictures. I was thinking of getting them as well and also setting at .85. Just to avoid any of these issues about alignment. People say you would be fine with the 1.75 but then most are unhappy with their alignment. I just want to add alittle and be done.
    Are you using the stock springs and UCA's.
  10. Jul 14, 2013 at 9:13 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I would not agree that "most are unhappy with their alignment" at 1.75. I was fine at 2.25.
    That said, there are different reasons for lifting a truck. I would suggest doing some research and knowing exactly what is going in when you change things on your vehicle and then doing it right the first time by making your truck applicable to where and in what scenarios you will need it to perform.
    If its solely for looks, do what you want.
  11. Jul 14, 2013 at 9:19 AM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    1.75" & 4 Factory leafs in the rear. Alignment came out fine, Truck is level, truck rides better than smooth.
    Just measure your center hub to fender front & rear...that is what will change when you add your 5100s and a possible AAL.
    Good luck
  12. Jul 14, 2013 at 9:28 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    X2 also lets not forget the issue with the VSC.
  13. Jul 14, 2013 at 9:35 AM
    dand
    dand You can't see me
    Dan
    SE VA
    2020 MBM TRD Offroad MT
    1st stage commencing
    What issue with the VSC?
  14. Jul 14, 2013 at 10:36 AM
    tacoma guy
    Joe
    Phoenix Az.
    I have read some threads where guys are having issues with the vehicle stability control system after installing a lift.
  15. Jul 14, 2013 at 10:49 AM
    dand
    Dan
    SE VA
    Hmmm,thanks for the info. I hadn't heard that before..
    Guess I better look into it..
  16. Jul 14, 2013 at 11:01 AM
    tacoma guy
    Joe
    Phoenix Az.
    Yeah no problem. Glad to help.:)
  17. Jul 14, 2013 at 2:40 PM
    Lefty08
    Lefty08 Member
    2010 Tacoma SR5
    Rear TSB, Biltsein 5100's set at 1.75
    I have a 2010 access cab 4cly. 4x4 and just put on 5100's yesterday at 1.75". Got the allignment done, but was not happy with the numbers. I have a thread going now about that. Also, I use my truck as a daily driver (100mile commute) a day. I though I liked the stiffened up ride until I drove it to work and back today. On the highway, crossing over passes and joints in the road are "jarring". I came home and just removed the 5100's and am setting them to .85. I will let you know "my oppinion" on the ride once I get them back on and take another trip. I am also curious if my allignment numbers can get better as well with the lower lift setting.
    I have the rear TSB and my only purpose for the 5100's was to level out the front some. I know everyone is different, but with my AC 4cly. 4x4 the ride was too harsh at 1.75".
  18. Jul 14, 2013 at 2:49 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You may want to consider an aftermarket coil in front thats longer & a little softer, your preload is whats giving it a harsh ride....:)
  19. Jul 14, 2013 at 3:05 PM
    Lefty08
    Lefty08 Member
    2010 Tacoma SR5
    Agreed. I will try the .85 setting first (less pre load) and see if that improves the ride enough for my taste. If not I will look into other options; like new coils... Trying to make it work on the cheap first.
  20. Jul 14, 2013 at 4:39 PM
    tacoma guy
    Joe
    Phoenix Az.
    What coil do you recommend that would give the same lift height as the .85 setting and have a soft ride. I have a 2011 trd off road . I understand that my coils are progressive coils. would they ride too stiff at .85? I am just wonting to level it !
