Help Identify these AAL that are on the top of the leaf pack?
Discussion in 'Suspension' started by alexc, Jul 20, 2013.
  1. Jul 20, 2013 at 11:12 AM
    alexc
    alexc [OP] Well-Known Member
    Alex
    Tampa, FL
    Previous owner said they were to help with heavy weight in the rear, I guess similar to the tsb?
  2. Jul 20, 2013 at 11:15 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Those are helper springs
  3. Jul 20, 2013 at 11:20 AM
    alexc
    Alex
    Tampa, FL
    Should I keep em? Get something else and sell em? I know nothing about these helper springs...
  4. Jul 20, 2013 at 11:24 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Its up to you, they just add a little weight capacity to the leafs; if they're not giving you a problem there's no real reason you should take them off other than if you want to swap for a lift AAL or. a new lead pack
