Clunk after OME installation
Old 03-02-2009, 06:03 AM   #1
chabro [OP] chabro is offline
chabro will become famous soon enough
chabro's Avatar
chabro's Tacoma Gallery
Not to long ago I installed OME all the way around. Installed 882s in the front and ended up with 3.5" of lift in the front. Ever since, when I drove over bumps I get a clunking noise from the drivers side. Sounds like it's right under my foot. Talked to a few people and they said I was probably just bottoming out and that would stop as the springs settle.
Has anybody had this sort of problem before? If so, what did you do? Where does the front suspension hit when it bottoms out?
Help???
Old 03-02-2009, 06:04 AM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
Is everything tightened to spec?
Old 03-02-2009, 06:06 AM   #3
chabro's Avatar
yeah everything torqued to spec. Not sure about the coilover assembly itself as a shop did that for me. But when I picked them up I thoroughly inspected bushings and such before installing.
Old 03-02-2009, 06:17 AM   #4
chris4x4's Avatar
Well, you could swap to the passenger side and see if the noise moves over there. that will let you know if its a faulty shock, or something else....
Old 03-02-2009, 06:20 AM   #5
chabro's Avatar
yeah. I was thinking about doing that. Not really what I wanted to do but maybe the best way to narrow it down. Any merit to the bottoming out theory?
Old 03-02-2009, 06:27 AM   #6
chris4x4's Avatar
How big of bumps is this happening on? you have to hit a pretty big bump for it to bottom out.
Old 03-02-2009, 06:30 AM   #7
chabro's Avatar
small. local street driving. only happens at relatively slow speeds. Mostly when going through pot holes. Rarely on speed bumps.
Old 03-02-2009, 06:32 AM   #8
chris4x4's Avatar
then its not bottoming. If its the shock, the installer MAY have left out a bushing washer, or somthing. Move the shock to the other side, and see if the sound moves with it. If it does, the only other thing to do is take apart the shock/spring assbly. and check it out.
Old 03-02-2009, 06:35 AM   #9
chabro's Avatar
Thanks Chris. I'll move the assembly and see what happens. I'll take another close look at the assembly and see if there is anything different between the drivers and pass side.
Old 03-02-2009, 06:36 AM   #10
chris4x4's Avatar
Keep me posted.
Old 03-02-2009, 09:17 AM   #11
chabro's Avatar
Originally Posted by silverback07 View Post
Make sure the nut on top of the shock is tightened to spec. Mine was a little loose (shop installed the coil and left it loose) and it clunked just a tad. I just put a wrench on it and a pair of vise grips on top and tightened it up.
The instructions say "torque to thread runout". Does that mean keep tightening til I run out of thread? Are there other torque specs? Thanks for the help!
Old 03-02-2009, 09:21 AM   #12
chris4x4's Avatar
Yep. Torque until it stops. It will be obvious when it does, so dont throw a 3' cheater bar on it.
Old 03-02-2009, 09:37 AM   #13
chabro's Avatar
Well thought we might be on to something but the nut is tight. All the way down. Talked to Kurt at Cruiser Outfitters where I bought the kit and he mentioned to try and spin the spring in the house. Says to put the upper end of the spring facing out. What do you guys think. I guess it is worth a try. Prob try Chris's suggestion tomorrow and spin the springs at the same time.
Old 03-03-2009, 03:50 PM   #14
chabro's Avatar
Well the noise is finally gone!! Took the coilovers out and spun them so the top end spring faces out like the photo. Then put the drivers in the passenger and vice versa. Not 100% sure what the problem is but it is nice and quiet now.
Also added a winch while I was taking things apart. Thanks again for all your help!
Old 03-03-2009, 07:52 PM   #15
chris4x4's Avatar
Good to know its fixed!
Old 03-03-2009, 07:59 PM   #16
chris4x4's Avatar
FWIW, Im going to take one of my shocks off, and turn it to where the top of the spring coil is faceing the back....I want to see if this can happen on a second gen...
Old 03-04-2009, 06:27 AM   #17
My other ride Hovers
Alaskaflyer has a spectacular aura aboutAlaskaflyer has a spectacular aura aboutAlaskaflyer has a spectacular aura about
Alaskaflyer's Avatar
Coast Guard: Helicopter Flight Mechanic
Alaskaflyer's Tacoma Gallery
Keep us posted!
Old 03-04-2009, 09:49 AM   #18
chris4x4's Avatar
Ok. I swapped the springs around to a few positions...No affect on the second gens...
Old 03-04-2009, 09:58 AM   #19
chabro's Avatar
Good to know! It looked like on mine the spring was making contact with the UCA bolt shaft in the tower. The coating on the spring was worn from rubbing. Can't tell you how happy I am this noise is gone. Peace of mind at last...
Old 05-14-2011, 01:21 AM   #20
x2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shed
x2468's Avatar
x2468's Tacoma Gallery
how did u spin the coil spring?
WTB: Front 5100's or OME Shocks, OME 885x, TSB AAL matt_06trdtaco Buy / Sell / Trade 5 05-29-2012 09:45 PM
5100/ome installation help in Los Angeles area munkeeboi Southern California 40 11-11-2011 12:08 AM
WTB: OME 881 Coils AND/OR OME 90004 Struts for 4Runner chris360hawks Buy / Sell / Trade 0 01-18-2011 09:56 AM
DIY OME installation??? Stillfly199 Suspension 25 01-19-2010 09:43 AM
OME Lift Kit Installation AZ11 Arizona 14 09-04-2009 12:53 PM
