bilstein 5100 bushing / gap / clunk help!
Discussion in 'Suspension' started by aldoraine, Aug 22, 2013.
  1. Aug 22, 2013 at 2:47 PM
    aldoraine
    aldoraine [OP] Well-Known Member
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    So I decided to go ahead and install by bilstein 5100's (on stock TRD coils) in my truck this week, and I ran into an issue. On the way home I heard a clunking noise coming from the driver side. I checked it out when I got home and noticed about a 1/4" gap on the strut rod between the waser, and the top nut.
    I took the whole assembly out of the truck and took it to a local body shop, and they swapped the new struts onto my old coils for me (They have a bench mount compressor). It's a friend of mine and he didn't charge me so I don't want to call back and complain, but it seems like it's missing a bushing. Is there supposed to be 2 bushings up top? Maybe there was supposed to be one under the top hat? I didn't get a chance to see the old ones disassembled so I have no clue what the bushing /washer arrangement is.
    There is only a gap on the drivers side, and the passenger side looks normal, so what happened?
    Also, are my spring perches on upside down?
    I'll attach pics of both sides for reference.
  2. Aug 22, 2013 at 2:50 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    One washer and bushing on top, and one washer and bushing on the bottom. Something is not right on that one side.
  3. Aug 22, 2013 at 2:55 PM
    spark4
    spark4 Well-Known Member
    So Cal
    2018 Tacoma TRD OR 4x4 Cement
    Bilstein 6100/5160, Ray 10's, 5.29, KDMax Tuned
    I know there is a metal spacer in the shock cover, if you opted not to use them that might be the problem. I didn't want to use the cover so I popped the metal spacer out and slid into place.
  4. Aug 22, 2013 at 2:56 PM
    aldoraine
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    I supposed I'll go rip it apart and see what it looks like, I'll post back in a bit once I have it all torn apart. Local parts store doesn't stock strut bushings, so I ordered 2 sets of sway bar bushings, they look to be about the same size. Looks like I'm definitely missing something.
    EDIT: Dan, just noticed you are from Wheelers, which is where I got my billies! You guys don't stock a bushing kit do you?
  5. Aug 22, 2013 at 3:03 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    We do. It is $20 and covers both sides.
  6. Aug 22, 2013 at 5:06 PM
    aldoraine
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    Hey Dan, I wasn't able to get the assembly apart with the spring compressors I had. I went ahead and ordered a set of your bushings and I'll take them back up to the body shop that took them apart the first time. Do you think it will damage the strut in any way to leave them as they are? I won't be driving the truck at all until its fixed, It will just be sitting.
  7. Aug 22, 2013 at 5:26 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Just sitting, it should be fine.
  8. Aug 22, 2013 at 9:43 PM
    aldoraine
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    Awesome, thanks for your replies, I appreciate it.
    Since I didn't see the disassembly of the old struts, I am unsure of the order / position of the bushings and the rubber top perch. Anyone have some guidance / Diagram for this?
    Does It go something like this?
    (PIC ATTACHED)
    EDIT: After more searching, found a picture from a use.
    Says it goes in this order LEFT ---> RIGHT = BOTTOM ---> TOP
    Hope this helps others!
  9. Aug 23, 2013 at 11:36 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    This is a common problem.
    People either forget to install a steel washer on the shaft that goes below the top plate
    OR
    People decide not to use the black plastic dust boot that goes over the shock shaft. This boot has a small metal spacer in it. If you don't want to use the boot that's fine, but you need to use the metal spacer that is inside the plastic.
    YotaDan likes this.
  10. Oct 18, 2014 at 1:10 AM
    colbyrainey
    colbyrainey Well-Known Member
    Colby
    KC
    '11 Dbl TRD Sport
    TSB Leafs, Bilstein 5100's @ 1.75", K&N Filter, Kenwood DNX 6180, BFG Rugged Terrain T/A's, ImMrYo Rearview Mirror Bracket, Extra D-Rings, Gloss Black Stock Wheels, Grillcraft Grille
    So i read that the dust cover was optional, so I did not put them on. I just saw this post and went and grabbed the covers and pulled the spacer off. Do I really need to take it all apart and install these? I'm getting conflicting information in researching...
    FWIW I'm at 1.75" lift.
  11. Oct 18, 2014 at 11:49 AM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
  12. Oct 19, 2014 at 1:31 PM
    colbyrainey
    Colby
    KC
    '11 Dbl TRD Sport
  13. Oct 26, 2015 at 6:08 PM
    Hgibby11
    Hgibby11 Member
    Clemson SC
    2006 Red Tacoma TRD
    Added Pelfreybilt all Aluminum Front Bumper, with powdercoat and Rigid Industries Lighting, replaced front struts with Bilstein 5100 adjustable struts, wheels, and tires, flat screen radio, haven't had the truck but a year and hope to keep working on my build!
    Mine is worse! This is the drivers side (pic posted) what kit and what did you do to fix it!?
  14. Jan 5, 2016 at 7:11 PM
    mhorton1911
    mhorton1911 Fightin' Texas Aggie Class of '19
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    Trail Gear front and rear bumper, 5100's all 4 corners, Eibachs, toytec AAL 1980 Ford pickup horn, and lots of battlescars :)
    I have this problem on both sides. I never had those bushings to put on the inside...... What should I do?
  15. Jan 7, 2016 at 1:50 PM
    mhorton1911
    Mark
    Fort Worth
    2000 2.7 4x4 manual
  16. Jan 7, 2016 at 2:07 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    @mhorton1911 you need to take them apart and re-assemble them with the correct pieces if they look anything like the pics above.
  17. Jan 7, 2016 at 2:11 PM
    mhorton1911
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    The bushing and washer that go on the inside wernt on my truck and didnt come with my lift, did I have to order them separately or did I get screwed?
  18. Jan 7, 2016 at 2:16 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Most of the front shock options for 1st Gen Tacomas do not include those bushings and washers. If your stock bushings are not in good enough shape, you would need to purchase new ones separately.
  19. Jan 7, 2016 at 2:17 PM
    719bloodhound
    719bloodhound Well-Known Member
    cos
    06 trd off road
    Omd rear leafs Ome 886 up front
    Should have been on your stock shocks
  20. Jan 7, 2016 at 2:43 PM
    mhorton1911
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    check that, I just found em...:annoyed::facepalm:
