3 Leaf Progressive Add A Leaf Kit
Discussion in 'Suspension' started by harshest, Mar 20, 2009.
  1. Mar 20, 2009 at 12:58 PM
    harshest
    harshest [OP] I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    Anybody running a truck with these on them? Specifically I am looking at . Just wondering if they provide the full 1.5" of lift, how much they sag over time, did you install them with or with out the TSB springs?
    I have the non TSB springs.
  2. Mar 20, 2009 at 7:07 PM
    ComaTosin
    ComaTosin The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    I have not installed them but plan to do so in the next couple of weeks. They ar eon backorder with wheelers. I also have the NON TSB spring that are flat as a board. My friend is also orderinf and installing on his truck with TSB at the same time. I should have a report in a couple of weeks. Seems like a good option. I will likely also use a 1" block to level out with my lift up front.
  3. Mar 20, 2009 at 7:28 PM
    harshest
    Michigan
    05 PreRunner SR5
    Nice keep my updated when you get them installed.
