How to get 1-1.5 inch of lift from new leaf pack
Old 02-03-2014, 03:50 PM   #1
davefollower is on a distinguished road
davefollower's Tacoma Gallery
I installed some new wheels and tires on my 2013 DC Off-road package.
New tires are 265/70R17. I am looking to put bilstein 5100's up front and
In the rear. I would prefer not to use a block in the rear. I would also like to
get a new leaf pack since the oem springs sag after a while. I didn't want to
add a leaf to the oem springs because I figured they would still sag over time.
Are there any aftermarket leaf packs that will get me the 1-1.5 inch that I am looking for in the rear of the truck. Based on the forum stuff I read, I was going to run the front billies at the 1.75 mark. Thanks for the help.
Old 02-03-2014, 03:58 PM   #4
Mainmoe02 is one of the sharper tools in the shedMainmoe02 is one of the sharper tools in the shedMainmoe02 is one of the sharper tools in the shedMainmoe02 is one of the sharper tools in the shedMainmoe02 is one of the sharper tools in the shedMainmoe02 is one of the sharper tools in the shedMainmoe02 is one of the sharper tools in the shedMainmoe02 is one of the sharper tools in the shedMainmoe02 is one of the sharper tools in the shedMainmoe02 is one of the sharper tools in the shedMainmoe02 is one of the sharper tools in the shed
Mainmoe02's Avatar
Mainmoe02's Tacoma Gallery
Check out wheelers offroad. Since your only wanting 1.5" lift at most then they have a couple options... either their 5 leaf spring pack which just says "will sit higher than stock". Or the Deaver or Alcan leaf springs which lift 1.5" - 1.75". You could go with OME and remove a leaf to lower the ride height to roughly 1.75". Just some options Ive researched over time. If your wanting a load bearing truck then Ive read the Deavers arent that great at handing weight, Just an FYI
Old 02-09-2014, 05:28 PM   #5
TacomaJay09 is one of the sharper tools in the shedTacomaJay09 is one of the sharper tools in the shedTacomaJay09 is one of the sharper tools in the shedTacomaJay09 is one of the sharper tools in the shedTacomaJay09 is one of the sharper tools in the shedTacomaJay09 is one of the sharper tools in the shedTacomaJay09 is one of the sharper tools in the shedTacomaJay09 is one of the sharper tools in the shedTacomaJay09 is one of the sharper tools in the shedTacomaJay09 is one of the sharper tools in the shedTacomaJay09 is one of the sharper tools in the shed
TacomaJay09's Tacoma Gallery
I went with the General Spring HD leaf pack 1.5-2" lift
Old 02-11-2014, 07:43 AM   #6
TAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shed
TAC1's Avatar
Name: Petros "Peter" AGE: 41
TAC1's Tacoma Gallery
Hello TacomaJay09,
I've been looking at those also. They are heavy duty & are 3/1 leafs. At $400 for a pair they are well priced. How long have you had them & how much lift did you actuially get?
Old 02-11-2014, 12:27 PM   #7
Originally Posted by TAC1 View Post
Hello TacomaJay09,
I haven't installed them yet. I anticipate installing them in March sometime. There are a few other parts I am waiting on so I can do the entire install at the same time.
Old 02-11-2014, 04:32 PM   #8
TAC1's Avatar
OK.
If you don't mind, keep me posted & post some pics.
Also, Before & after measurements.
Old 02-11-2014, 05:41 PM   #9
OK.
I can do that. Just keep in mind that my before measurements will be on a sagging leaf pack.
Old 02-12-2014, 07:40 AM   #11
whisk3ythrottle is on a distinguished road
whisk3ythrottle's Avatar
whisk3ythrottle's Tacoma Gallery
Bump, Looking for the same information.
Old 02-12-2014, 07:54 AM   #12
Banned
SoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shed
SoCaltaco65's Tacoma Gallery
Originally Posted by OZ-T View Post
Wheelers HD leaf pack
As my Esteemed TW Colleague pointed out
these are more of what you are looking at.
http://wheelersoffroad.com/product/l...af-spring-set/
Old 02-13-2014, 07:45 AM   #13
With a 5 leaf pack, isn't that going to give more than 1.5 in. of lift?
Old 02-13-2014, 09:10 AM   #14
OZ-T's Avatar
OZ-T's Tacoma Gallery
Depends on your constant load weight , with the Wheelers HD pack you can also remove one leaf to lower the ride height
Old 02-13-2014, 12:06 PM   #15
I like the Anaheim Ducks
Okeetee is one of the sharper tools in the shedOkeetee is one of the sharper tools in the shedOkeetee is one of the sharper tools in the shedOkeetee is one of the sharper tools in the shedOkeetee is one of the sharper tools in the shedOkeetee is one of the sharper tools in the shedOkeetee is one of the sharper tools in the shedOkeetee is one of the sharper tools in the shedOkeetee is one of the sharper tools in the shedOkeetee is one of the sharper tools in the shedOkeetee is one of the sharper tools in the shed
Okeetee's Avatar
Okeetee's Tacoma Gallery
OZ-T,
Does the rear stiffen up if you remove the overload leaf? And from your research, how much height are people giving up when they remove it?
I just purchased the Wheelers HD 1.5" AAL, but I'm planning on using all leafs (still have the 3 leaf rear at the moment).
.. Maple Leafs? Boy, you must be loving life right now.
Old 02-13-2014, 12:24 PM   #16
OZ-T's Avatar
Originally Posted by Okeetee View Post
OZ-T,
I don't think it's the overload you remove , I believe it is one of the leafs
I was talking about the full replacement leaf pack and you are talking about an AAL
8 inch leaf pack, who do i talk to? WailuaTaco808 Long Travel Suspension 17 09-06-2013 11:43 AM
feeler:Brand New 5 inch custom Deaver leaf pack/springs selfmade 2nd Gen Tacoma Marketplace 1 02-28-2013 01:00 PM
what length shocks for 3 inch leaf pack DreDog 2nd Gen. Tacomas 0 09-25-2011 01:20 PM
New shocks needed with 3 inch leaf pack? DreDog 2nd Gen. Tacomas 9 09-19-2011 04:00 PM
all pro 3 inch leaf pack install help? DreDog 2nd Gen. Tacomas 25 09-05-2011 11:44 PM
