Shock VS Coil??
Old 02-11-2014, 09:16 PM   #1
usaftaco4x4 is on a distinguished road
usaftaco4x4's Avatar
Air Force:
usaftaco4x4's Tacoma Gallery
Shock VS Coil??
I have a spacer lift on my truck now and want to get rid of it because the truck drives like a brick. I cannot afford the full coilover setup at this point in time. Would it be better to get Bilstein 5100s with the stock coil and let the shock do the lifting or get OME 884/885 coil and stock shock and let the coil do the lifting? Does either way put too much stress on other stock suspension parts (UCA/LCA, CV Boots, ext.)
Old 02-13-2014, 10:26 AM   #2
Air Force:
Anyone?
Old 02-13-2014, 10:28 AM   #3
I'd rather be skiing...
teneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shed
teneighty's Avatar
Law Enforcement:
teneighty's Tacoma Gallery
You can't run the stock shocks with new 885 coils. You need 885's and 5100's
Your best bet is the 5100's with stock coils. Not sure if it would ride much better than your spacer though. You'll be fine with stock UCA's at 2.5" lift
BAJA Bilstein coil and shock MWM BAJA 12 2nd Gen Tacoma Marketplace 12 01-29-2014 07:24 PM
Rubber that goes between coil and shock? Kenny650 Suspension 7 04-03-2012 06:54 PM
Best coil/shock setup for stock height? JeffsJeep04 1st Gen. Tacomas 5 04-14-2011 10:06 AM
what coil pairs well with 5100 shock. gofas Suspension 9 08-22-2010 12:25 AM
Help! Can't get the front shock/coil out. MxRacer190 2nd Gen. Tacomas 12 05-02-2010 09:51 PM
