#41 | ||
Slap Chop
#42 |
Resident Hippy Removal Expert
Just tore mine apart yesterday...
Couple things I would recomend... a pry bar or big flat head screwdriver, some reason my coil overs didn't want to get out of the lower mount.... also when you go to re-attach the upper ball joint if you jack up right under the lower control arm it will be a bunch easier than putting all your weight onto it to try to get everything lined up.... This is what is meant by a spring compressor, DO NOT use one of the wimpy autozone ones... ![]()
__________________
Hello you sick twisted freaks, I am Adam. ![]() ![]() ![]() Forever... |
#43 |
Good for springs up to 10". The Tacoma springs are 14" and many after market springs are 16".[/quote]
Ok, My 886's are 16" high. I have a friend that works at monroe around the corner, I think I will have him do the coils. Safer that way, cheaper too. |
#44 | ||
Slap Chop
![]() Quote:
#45 | |
Meh I think the automotive gods just weren't satisfied with me. They were at the end, I lost another couple of square inches of flesh on my hands and my buddy ended up with 2 stitches from the "dust gaurd I guess" on the back of the discs.
__________________
#46 | |
Slap Chop
#47 |
That's what I was saying... Throw a butterfly bandage on there and man up!
__________________
#48 |
Just waiting for the Apocalypse
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Name: Mr. Mom
Bandages?? Bah!! At work I use electrical tape.
#49 | |
Slap Chop
#50 |
Pray for CG1705 and the Cobra Crew
Yeah...super glue is the awesome way to do it!!
__________________
Namaste Brunes
#51 |
If you can get the shit to come out...
#52 |
Slap Chop
#53 | |
__________________
#54 | |
There's an evil monkey in my truck
Looks like this one on eBay. $149 with free shipping.
__________________
#55 |
How many words can be fit in this s
I did not remove the spindle ball joint nut. When I installed mine I left the uca on the spindle untouched. I just used the bottle jack to jack the uca down a bit. Each side only took about 15 to 20 minutes.
#56 | |
Slap Chop
#57 |
Any thoughts?
Any of you know if 3" is what the actual lift is with the 886? (nothing add to front) I had the TSB done and I like the way it sits. Back is lower than most, I have a cap, sub and edead 80 on the truck. If the back lifts 1.5" (I have the non TSB aal, I am going to cut it down 1" as per toytech) with the aal then (# wise) I need a 1.5" block to keep the same angle. I also got 3/4' spacers for the front that came with the set-up I bought. If I use those do I need a additional 3/4" in rear?
THX |
#58 |
#59 | |
Slap Chop
#60 | |
Avatar approved by 98tacomav6
| Display Modes | |
| rear shock top nut 14 mm stuck, spins shock | robert benner | 2nd Gen. Tacomas | 12 | 10-12-2009 06:56 AM |
| WTB Rear shock or shocks, front mud flaps - 06 TRD | wheeler_01 | Buy / Sell / Trade | 0 | 02-02-2009 04:36 PM |
| ==> PLEASE Help ASAP w/Front Bumper Driver Flair/Extention Removal <== | iamrayzian | 2nd Gen. Tacomas | 5 | 11-03-2008 07:59 PM |
| front emblem removal | deadbolt | 2nd Gen. Tacomas | 21 | 09-30-2008 09:08 PM |
| Shock / Spring question | jrallan26 | 1st Gen. Tacomas | 1 | 04-30-2008 11:16 PM |
