Will this lift/tire/rim setup work?
Discussion in 'Suspension' started by FawkQ, Jul 9, 2014.
  1. Jul 9, 2014 at 10:44 PM
    FawkQ
    FawkQ [OP] Well-Known Member
    Alberta, Canada
    2013 TRD Sport DCSB V6 4.0 6M "The Sequel"
    So I don't consider myself a complete newb, but I definitely don't have enough knowledge to tell if this setup will work without doing my own trial & error. With so much info stickied on lift and suspension, I get lost in it and I confuse myself sometimes...
    So will this setup work? Will I run into any issues? i.e. rubbing (something a minor trim job can fix?), wheel spacers required?, do I get the LR UCA's or not?, etc
    16" TRD Trail Team rims:
    Wrapped in 285 Duratracs:
    And the 3" lift kit with Bilistein 5100 Height Adj. Coilovers, with the CS047R Dakar leaf pack (not pictured) from Toytec
  2. Jul 9, 2014 at 10:48 PM
    FawkQ
    Alberta, Canada
    I have a 2013 DCSB TRD Sport 4x4 if that changes anything.
  3. Jul 9, 2014 at 10:52 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    You'll be good, with 285's you will have to do some minor trimming on your fenders flares. You won't need spacers either. As for ucas you may or may not need after market ones. Some guys can get stock specs and others can't.
  4. Jul 9, 2014 at 10:58 PM
    FawkQ
    Alberta, Canada
    Roja that!
    What setting would I have to set the billies at to achieve the max height, but maintain the levelled/stock rake?
  5. Jul 9, 2014 at 11:05 PM
    BulletToothTony
    If you don't add any rear lift the front setting will need to be 1.75 if you add an aal you'll have to bump it up to 2.5
  6. Jul 9, 2014 at 11:12 PM
    FawkQ
    Alberta, Canada
    Do adding the Dakars qualify as adding lift? Or no? I know some who would consider those as lift.
  7. Jul 9, 2014 at 11:21 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    2 1/2"
  8. Jul 9, 2014 at 11:22 PM
    BulletToothTony
    Haha yeah those are lift. Around 3 inches of it actually, you'll want to set the front at 2.5 then. Also look at getting the extended rear 5100 shocks and exteneded rear brake lines as well.
  9. Jul 9, 2014 at 11:26 PM
    FawkQ
    Alberta, Canada
    Thanks gents!
    If ordering from toytec, they should automatically ship with extended 5100's shouldn't they? After all this is the business they're in, or would you have to request them?
  10. Jul 9, 2014 at 11:28 PM
    FawkQ
    Alberta, Canada
    Never mind... It says right on their site they use extended 5100's.... I'm more newb than I thought
  11. Jul 9, 2014 at 11:30 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    I got same wheels with 285s and spacers. The spacers give it a better stance dur to bo backspacing. You will probably do some light trimming
  12. Jul 9, 2014 at 11:34 PM
    FawkQ
    Alberta, Canada
    And I assume you're running 3" lift also?
  13. Jul 10, 2014 at 4:40 PM
    TacoRuthe
    TacoRuthe Well-Known Member
    Joshua
    Santee, CA
    2002 Acura RSX Type-S / 2006 4Runner 4WD V8 / 1999 4Runner V6 4x4
    Loading......
    I have a 13' with those TRD wheels no spacer and 285's in General Grabber AT2's. The only thing I have done is cab mount chop (mostly for off-road) and unbolted the little flaps in the front of the wheel well.
    I run King's @ default setting so like 2.5"? and 1.5" AAL in the rear only rub when I bottom out off road because of driving a little too fast on whoops. Haven't rubbed on the street and I frequently crank my wheel all the way to back into spots. Hope this helps.
  14. Jul 16, 2014 at 11:20 PM
    FawkQ
    Alberta, Canada
    helps big time!
    thanks for the info gents
  15. Jul 17, 2014 at 8:33 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah, but you're not using factory upper control arms, right? Aren't you using the Total Chaos UCAs?
    To the original poster - you'll probably need spidertrax (or equivalent) wheel spacers to avoid those tires rubbing against the factory upper control arms when mounted on those rims. EDIT - or you could swap out the UCAS for the Total Chaos ones. (The light-racing UCAS that a lot of us use have a little wider shoulder - if you're trying to prevent UCA rubbing - the basic Total Chaos UCAs are probably your best bet)
  16. Apr 1, 2015 at 6:54 PM
    FawkQ
    Alberta, Canada
    hate to wake an old thread but thought others could benefit from this...
    I finally got around to installing everything I mentioned above after being deployed, my lil boy showing up 2 months earlier than expected, living out of a suitcase in another city for some time, etc...
    So once installed the lift and the rubber/rims it was rubbing LIKE A SAVAGE, I couldn't turn the wheel much more than 90*... thankfully my stealership wasn't too far away. I had them max out the caster as much as they could without knocking the camber out to lunch. I think we got caster up to 1.6 and camber bang on spec. Anymore caster and camber was sacrificed.
    After that the only rubbing was that goofy little mud flap at the front of the wheel well with the wheel at full lock, so to the trash they went. Now the only time they rub is if I hit a bump at lock harder than I or anyone ever should, if I hit that same bump straight on I have no problems!
    I will report I did notice a difference in handling after this lift (nothing major or worth panicking over). From everything I've read, I guess I need to save my money and get some LR UCA's so I can get my caster out to 2.5 or more and then handling will be restored.
    Hope this helps any newbies like myself.
