question about lifting my tacoma
Old 04-19-2009, 12:25 PM   #1
tacody [OP] tacody is offline
tacody is on a distinguished road
tacody's Avatar
tacody's Tacoma Gallery
i have an 06 prerunner v6 2 wheel drive access cab
i am thinking about getting a 3" toytec body lift
would 16" rims wrapped in 275/70/16 look nice??
please let me know
lend me any recomendations
Old 04-19-2009, 12:30 PM   #2
Avatar approved by 98tacomav6
DanGer is one of the sharper tools in the shedDanGer is one of the sharper tools in the shedDanGer is one of the sharper tools in the shedDanGer is one of the sharper tools in the shedDanGer is one of the sharper tools in the shedDanGer is one of the sharper tools in the shedDanGer is one of the sharper tools in the shedDanGer is one of the sharper tools in the shedDanGer is one of the sharper tools in the shedDanGer is one of the sharper tools in the shedDanGer is one of the sharper tools in the shed
DanGer's Tacoma Gallery
do you plan on wheelin at all?
Old 04-19-2009, 05:39 PM   #4
tacody's Avatar
i actually like the look of body lifts though ha
your truck looks nice =]
soo with a 3 inch lift i will be ok on stock rims and tires?
should i increase tire size but keep 16's?
Old 04-19-2009, 05:49 PM   #5
tacody's Avatar
could you recomend a good 3" suspension lift kit?
Old 04-19-2009, 06:21 PM   #6
Poodoo
luk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shed
luk8272's Avatar
luk8272's Tacoma Gallery
You are on the correct track with the toytec, that is what I have. Or you could get some 5100 shocks they will level your truck and are adjustable. Look them up on here others know more about them than I do. As for your tires its your call. I had the base model rims so I dumped them. I am not certain which rims you have or what size tires will fit them.
Here are some wheel specs. Wheel Specs
Here is a tire size tool. Tire Size Tool
This may be the tire size for you Largest Tires w/o Lift on TRD
If you have more questions, just ask.
Old 04-19-2009, 08:04 PM   #9
tacody's Avatar
Ya I had that kit in mind actually
Sobeith that kit could I just run the stock tires and rims?
Until I can afford better
Lifting Question bohunter1990 Suspension 22 10-06-2011 08:04 PM
Question regarding lifting and tires Voltairevillain 2nd Gen. Tacomas 6 09-10-2011 06:11 PM
Question on lifting and souping up a tacoma. helmsracing Toyota Trucks & SUVs 5 12-20-2010 01:28 PM
Lifting question dirtytaco2010 Suspension 11 09-01-2010 11:35 AM
lifting block question jeff6001 1st Gen. Tacomas 2 05-29-2009 04:23 PM
