NEW: Bilstein 6112 Coilover Spy Shots!
Old 12-15-2014, 03:16 PM   #1
Total Automotive Performance
Chas of MRT is one of the sharper tools in the shedChas of MRT is one of the sharper tools in the shedChas of MRT is one of the sharper tools in the shedChas of MRT is one of the sharper tools in the shedChas of MRT is one of the sharper tools in the shedChas of MRT is one of the sharper tools in the shedChas of MRT is one of the sharper tools in the shedChas of MRT is one of the sharper tools in the shedChas of MRT is one of the sharper tools in the shedChas of MRT is one of the sharper tools in the shedChas of MRT is one of the sharper tools in the shed
Chas of MRT's Tacoma Gallery
Im currently testing the Bilstein 6112 for the first gen Tundra, but wanted to let you all know the 05+ Tacoma, 03-09 & 10+ 4Runner, FJ & 07+ Tundra kits should be ready to ship in 30-45 days.
From our blog: http://totalautomotiveperformance.ne...ver-spy-shots/
Designed for the serious off-road adventure seeker, the all-new BILSTEIN 6112 Series kit is the ultimate suspension solution! These are massive coilovers that feature preset c-clip style height settings, new springs. Total Automotive Performance will be the first to offer these new coilovers and will be taking preorders in mid-January.
Product Highlights:
  • Large 60mm monotube for increased oil capacity, cooling, and long-term durability
  • Offers 0-2.5” of adjustable lift depending on the application
  • 60mm digressive piston for improved ride comfort and control over rough terrain
  • Utilizes a high quality OEM lower mount for long-term durability and a perfect fit
  • Custom engineered cold wound linear springs for enhanced vehicle control
  • Monotube design for consistent, fade-free performance
  • Application specific for maximum performance
  • Reuses OEM top mount and rubber isolator
Made in the USA Kit includes (2) front 60mm shocks, (2) spring seats and (2) springs
Check out how beefy they are!! (These are prototypes with no coating and a threaded shock body and are not representative of the final product.)
[/I]
6112 Front Coilover Kit Part Numbers:
05-15 Toyota Tacoma - Bilstein 46-241627
07-15 Toyota Tundra Bilstein 46-206084
03-09 4Runner / 07-09 FJ - Bilstein 46-227287
10-15 4Runner / 10-14 FJ - Bilstein 46-227294
Old 12-15-2014, 03:28 PM   #2
OICU812 has a brilliant futureOICU812 has a brilliant futureOICU812 has a brilliant futureOICU812 has a brilliant futureOICU812 has a brilliant futureOICU812 has a brilliant futureOICU812 has a brilliant futureOICU812 has a brilliant futureOICU812 has a brilliant futureOICU812 has a brilliant futureOICU812 has a brilliant future
OICU812's Tacoma Gallery
What's all in cost including a matching set of rears to go with? Assuming they've made a match set or rather will as pics display?
Also in regards to comments how would these fair against 5100s "street comfort / DD wise"?
For Taco what's the spring rate lbs?
Old 12-15-2014, 03:33 PM   #3
epa4wd is one of the sharper tools in the shedepa4wd is one of the sharper tools in the shedepa4wd is one of the sharper tools in the shedepa4wd is one of the sharper tools in the shedepa4wd is one of the sharper tools in the shedepa4wd is one of the sharper tools in the shedepa4wd is one of the sharper tools in the shedepa4wd is one of the sharper tools in the shedepa4wd is one of the sharper tools in the shedepa4wd is one of the sharper tools in the shedepa4wd is one of the sharper tools in the shed
epa4wd's Tacoma Gallery
Is it adjustable from 0" to 2.5" or is it just two settings, 0" (no lift) and 2.5" (lift)?
I see the threaded shock, but wanted to make sure.
Old 12-15-2014, 03:35 PM   #4
Unchained 5150 is one of the sharper tools in the shedUnchained 5150 is one of the sharper tools in the shedUnchained 5150 is one of the sharper tools in the shedUnchained 5150 is one of the sharper tools in the shedUnchained 5150 is one of the sharper tools in the shedUnchained 5150 is one of the sharper tools in the shedUnchained 5150 is one of the sharper tools in the shedUnchained 5150 is one of the sharper tools in the shedUnchained 5150 is one of the sharper tools in the shedUnchained 5150 is one of the sharper tools in the shedUnchained 5150 is one of the sharper tools in the shed
Unchained 5150's Avatar
Marines:
Name: Dave Trends Auto
Unchained 5150's Tacoma Gallery
Threaded shock will not be on the one you can buy. That is just on the prototype.
Old 12-15-2014, 03:39 PM   #5
Makes me wonder even more then if its just two settings 0" and 2.5" like the procomps.
Old 12-15-2014, 03:45 PM   #6
Cost is TBD
They ride much better than my 5100s on & offroad. The freeway ride is butter.
Spring Rate TBD
The production units will not be threaded but feature snap ring grooves just like the 5100s. The Tacoma will have 4 settings (0, .85, 1.75 & 2.5)
Old 12-15-2014, 03:46 PM   #7
Marines:
I am just wondering what the big differences are between the 5100's and this? They come with there own coils? You still have to take them apart to adjust the height?
Old 12-15-2014, 03:47 PM   #8
Fearless Keyboard Warrior
Capt. Obvious has a brilliant futureCapt. Obvious has a brilliant futureCapt. Obvious has a brilliant futureCapt. Obvious has a brilliant futureCapt. Obvious has a brilliant futureCapt. Obvious has a brilliant futureCapt. Obvious has a brilliant futureCapt. Obvious has a brilliant futureCapt. Obvious has a brilliant futureCapt. Obvious has a brilliant futureCapt. Obvious has a brilliant future
Capt. Obvious's Avatar
Capt. Obvious's Tacoma Gallery
So, they're basically 5100s that come with springs and have a slightly larger diameter shock body?
Old 12-15-2014, 03:47 PM   #9
Originally Posted by Chas of MRT View Post
Cost is TBD
Spring Rate TBD
Awesome! Can't wait
Old 12-15-2014, 03:48 PM   #10
Marines:
Doesn't sound like a big difference with all this hype going on
Old 12-15-2014, 03:52 PM   #11
mbrogz3000 has a spectacular aura aboutmbrogz3000 has a spectacular aura about
mbrogz3000's Tacoma Gallery
I'm probably wrong, but they look like the bilstein trd baja/pro shocks ...
Old 12-15-2014, 03:55 PM   #12
Marines:
Your post up top says about 750.00 a pair. Wow sounds like a lot of cake for a ramped up 5100.
Old 12-15-2014, 04:37 PM   #13
Yes, think of this shock as having the performance of the big name 2.5" coilovers without all the fancy features. This is more than a few steps up from the 5100, you are comparing a 46mm shock vs a 65mm shock. The shock shaft is larger as is the piston. The ride difference and offroad control between the 5100 & 6112 will be huge. Basically going from something smaller than a Fox 2.0, to something larger than an ICON 2.5"
Pretty much.
Old 12-15-2014, 04:41 PM   #14
corrected, under 750 for the whole kit F+R. These will come in under 500 for just the front coilovers
Old 12-15-2014, 04:42 PM   #15
Marines:
Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
Old 12-15-2014, 04:53 PM   #16
gray223 is a splendid one to beholdgray223 is a splendid one to beholdgray223 is a splendid one to beholdgray223 is a splendid one to beholdgray223 is a splendid one to beholdgray223 is a splendid one to beholdgray223 is a splendid one to behold
gray223's Avatar
gray223's Tacoma Gallery
Heard anything about them for 1st gens?
Old 12-15-2014, 04:57 PM   #17
Yes, they are in development for the first gen.
First release coming in Jan will be new Tacoma, Tundra, FJ & 4Runner. Second release will be first gen Taco, Tundra, Sequoia & 4Runner.
Old 12-15-2014, 05:06 PM   #18
gray223's Avatar
New Tacoma as in 2016?
Old 12-15-2014, 05:08 PM   #19
Second gen.
Old 12-15-2014, 05:10 PM   #20
TW 1%er
Ghost. is one of the sharper tools in the shedGhost. is one of the sharper tools in the shedGhost. is one of the sharper tools in the shedGhost. is one of the sharper tools in the shedGhost. is one of the sharper tools in the shedGhost. is one of the sharper tools in the shedGhost. is one of the sharper tools in the shedGhost. is one of the sharper tools in the shedGhost. is one of the sharper tools in the shedGhost. is one of the sharper tools in the shedGhost. is one of the sharper tools in the shed
Ghost.'s Avatar
Ghost.'s Tacoma Gallery
Y u no 4runner
Spy Shots of Extreme Dimensions DuraFlex 05+ Tacoma 6" Flare Rear Bedsides - 108887 Chas of MRT 2nd Gen. Tacomas 16 12-04-2014 05:34 PM
Spy Shots of Extreme Dimensions DuraFlex 95-04 Tacoma 4.5" Rear Bedsides - 108888 Chas of MRT 1st Gen. Tacomas 5 11-13-2014 10:57 AM
Next Gen mule spy shots hpvds 2nd Gen. Tacomas 370 10-31-2014 11:04 AM
all-pro/bilstein coilover replacement silas144 1st Gen. Tacomas 5 02-28-2012 11:53 AM
Production Chevy Colorado Spy Shots KenLyns General Automotive 88 09-08-2011 12:38 AM
