LCA's
Discussion in 'Suspension' started by pasotaco, Jan 11, 2015.
  1. Jan 11, 2015 at 7:13 PM
    pasotaco
    pasotaco [OP] Well-Known Member
    Central Coast, CA
    2013 4x4 Access Cab
    LCE headers, King 2.5 Coilovers w/ res, TC UCA's, King resi's in rear, Geared to 4.88, rear locker, Timbren Bump stops, All Pro Leafs, Carrier bearing drop kit, ARB onboard air,
    Besides strength and the possibility of a second shock what do the TC LCA's give you?
  2. Jan 11, 2015 at 7:24 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Got a link?
  3. Jan 11, 2015 at 7:25 PM
    Adamar85
    Adamar85 Well-Known Member
    Adam
    Baker City, OR
    22 Ford F350 Lariat
    If you get the race version, they add uniballs instead of ball joints. Which gives you a little more articulation up front.
  4. Jan 11, 2015 at 7:52 PM
    pasotaco
    Central Coast, CA
    2013 4x4 Access Cab
    I just can't seem to justify the expense on a mid travel when their are other mods I think I will utilize more for the $...
  5. Jan 11, 2015 at 7:53 PM
    pasotaco
    Central Coast, CA
    2013 4x4 Access Cab
  6. Jan 12, 2015 at 8:57 AM
    Dirt King Fab
    Dirt King Fab Well-Known Member
    San Diego
    2013 Toyota Tacoma
    If you are looking for another option for LCAs we also offer an OEM width lower control arm. Our arms use a uniball that is mounted in the arm rather than a block that bolts to the spindle to gain additional ground clearance. Our arms are also fitted with hydraulic bump stop mounts to allow for optional hydraulic bump stops to be mounted if desired. We use delrin inner bushings which allow the arm to pivot more freely than the factory 1 piece injected bushing design. The delrin bushings allow feature grease fittings which allow them to be easily serviced. Our arms also do not require a 1.25" spacer as the TC ones.
    Here are a few images of our OEM width 05+ Tacoma lower control arms.
  7. Jan 12, 2015 at 9:06 AM
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    My opinion, I'm saving for Dirty King vs TC. Touchly made and look great. don't have to buy a skid to go under them either. Plus i like the black anodized look.
  8. Jan 12, 2015 at 4:53 PM
    pasotaco
    Central Coast, CA
    2013 4x4 Access Cab
    Agreed, These look sick... So many toys, bank account :( not happy... For me X-wing sliders next...
  9. Jan 13, 2015 at 6:44 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    TC Non race/Standard version also use Uniballs - just requires the use of an adapter instead of having them built into the LCA. As Dirt king described it allows for more ground clearance.
    I see DK uses the full stock LBJ adapter with stops whereas TC requires you to cut the stops off and radius the knub.
    Not sure if that has anything to do with the requirement of wheel spacers/different BS or possible limited steering travel. Maybe they can chime in, I'd like to learn more about the engineering that went into these things. Both companies work is amazing IMO, From what I've read about DK and my experience with TC you can't go wrong with either.
    For the money spent on stock width lowers you can go +2 damn near, just sell your mid travel stuff to fund new coil overs.
