2015 Two Inch Lift
Old 01-14-2015, 05:52 PM   #1
FJpescador [OP] FJpescador is offline
FJpescador will become famous soon enough
FJpescador's Avatar
FJpescador's Tacoma Gallery
2015 Two Inch Lift
Ok, Here it goes.
I did a 2" spacer lift up front.
Conclusion: It rode very stiff. lift looked good.
Fix: Removed sway bar.
Concision: Great ride. Just a little lean on sharp corners. High speed sway no problem. Better articulation and better IFS
Rear: Wheeler's 2" aal lift.
Conclusion: It rides Great.
Some people will have bad things to say about this lift. But untill my tires wear out and I get larger tires. I'm not going to do full OME lift. This works for now.
As a 40yr off road driver and mechanic nothing wrong with this lift if you don't push it to hard.
Bret
Anyone out there have a 6 inch Bds lift on a 2014 or 2015? Eagle1 Suspension 7 12-11-2014 09:20 PM
6 inch lift plus 1-2 inch body or spacer lift davelee94 2nd Gen. Tacomas 12 03-03-2014 11:43 AM
6 inch lift plus 1-2 inch body or spacer lift davelee94 Suspension 0 03-03-2014 11:01 AM
3 Inch TOYTEC Ultimate Lift OR RCD 4.5 Inch Lift Kit? FXHO 2nd Gen. Tacomas 17 08-08-2013 01:37 PM
3 inch body lift on a 6 inch fab tech lift bruth Suspension 17 05-08-2010 12:58 AM
