Fox 2.0 Coilover and Rear Resi Question
Discussion in 'Suspension' started by boogie3478, Feb 6, 2015.
  1. Feb 6, 2015 at 6:58 AM
    boogie3478
    boogie3478 [OP] Well-Known Member
    14 TRD Off-Road V6
    All the mods
    The prices on the Fox 2.0 set is pretty attractive but the only actual lift height info I've seen so far is that it would give 2" in the front and 1" in the back.
    Can anyone running this setup confirm this? I was really looking for closer to a 3" lift.
  2. Feb 9, 2015 at 4:33 AM
    BloodThinnerz
    BloodThinnerz Well-Known Member
    Alberta
    2015 MGM DCLB
    TRD Cup Holders
    They give you 2" out of the box to level you out, and I'm pretty sure that they can be cranked to 3"
  3. Feb 9, 2015 at 7:12 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Ahh thanks for the response!
  4. Feb 9, 2015 at 7:13 AM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    The rear shocks don't give you any lift
  5. Feb 9, 2015 at 6:50 PM
    Ghost9
    Ghost9 Active Member
  6. Feb 9, 2015 at 7:03 PM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    2.5 Fox & UCA You can go 3" [​IMG]
  7. Feb 9, 2015 at 7:57 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    The 2.5's are about $300 more though, if he needs that extra inch then they are good. But I think the 2.0's you can crank up to 3" as well
  8. Feb 9, 2015 at 8:05 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Boogie, the shocks dont do shit, but you want to know if they will support over 2" and not destroy the shock. I looked into the same thing. You really need to look at max extended length and compressed lengths. If you exceed the max extended length then you would need limiting straps and you have to have enough lift to make sure you dont compress beyond the compressed length as well. I am sure some folks could provide best tips and practices for how to measure these limiting factors.
  9. Feb 9, 2015 at 8:16 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    You don't need limiting straps in the back (not sure if they even make them for the rear) but he just needs to choose the correct length shock for the amount of lift he is having. Every shock will say "good for ___ amount of lift". Limiting straps are only for LT trucks in the front, I believe its because they don't have the fender clearance for full LT.
