JBA Offroad Upper Control Arms And Suspension MEGA Thread BS thread
Discussion in 'Suspension' started by tcBob, Feb 24, 2015.
  1. Apr 27, 2015 at 5:15 PM
    #41
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Can you measure the difference between stock and these ball joints as far as angle deflection they are capable of?
  2. Apr 27, 2015 at 5:30 PM
    #42
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Look nice. Are you the guinea pig for us?
  3. Apr 27, 2015 at 7:21 PM
    #43
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Subbed for further updates. UCA's should be in my near future and these are definitely an option
  4. Apr 27, 2015 at 7:45 PM
    #44
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    I'd really like to see some more alignment specs at 2.5"-3" of lift.
  5. Apr 27, 2015 at 8:03 PM
    #45
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Mine got installed a little over a week ago.
    I painted the wheel speed sensor wire bracket and discovered that a dust cap for the factory brake bleeder screw works perfect for the zerk grease fitting.
    Here is my alignment numbers.
  6. Apr 28, 2015 at 5:00 AM
    #46
    remery829
    remery829 Well-Known Member
    Eastern NC
    '14 DCSB TRD Offroad
    Some stupid expensive stuff
    Maybe it's the crew chief in me, but I think the bolts are about 2 threads too short.
    ckblum, scocar and DormaTaco like this.
  7. Apr 28, 2015 at 10:44 AM
    #47
    nd4spdbh
    SoCal
    Did they end up allowing for more droop (more ball joint flex?
  8. Apr 28, 2015 at 6:43 PM
    #48
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Subd
  9. Apr 29, 2015 at 10:00 AM
    #49
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I was curious as to how much caster these will give you. I couldn't find anything on their site so I gave them a call. I spoke with a man who introduced himself as the owner, Marlin Gehman. He said he didn't know exactly how many degrees of caster they would allow. He said their tacoma with a 3" lift was set at 1.9 caster with these arms. That seemed low to me, but I read earlier in this thread that member is at around 2.5 or something like that with these arms. The owner said that if I was not able to get my caster high enough to satisfy me, I could return them for a full refund. He emailed me some more info on the UCAs. He was a very nice guy to talk to. I'd suggest giving him a call if you have any questions. I'm going to do a little more research, but definatley keeping these in mind.
  10. Apr 29, 2015 at 10:10 AM
    #50
    Crom
    Nick
    San Diego, CA
    Millions
    ^ That's great to hear! Very pleased with people who stand behind the products they make. With my JBA UCA's, and Firestone alignment, my caster is set to 2.4. I have not measured my lift, but I think I am at least 2" or maybe 2.5". Anyways, I am very pleased with how the truck drives. :thumbsup:
  11. Apr 29, 2015 at 10:19 AM
    #51
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    These look really interesting to me, going to be doing suspension with probably 2.5" lift this fall. Originally was thinking I'd stick with OEM UCAs as I was under 3" of lift but I've read more than one person still having squirrelly alignment with OEM in the 2" to 2.5" range.
    One question just to make sure I understand. These UCAs basically change the range of caster available from the OEM LCA cams to be more appropriate for a lifted truck. So in the process of making the caster adjustment range more favorable for say a 2-4 inch lift they also make the caster adjustment range worse for a stock suspension height. Do I have that right?
    And in comparison the LR UCA actually has an additional adjustment on the UCA to allow for the caster adjustment range of the LCA to be shifted appropriately for whatever lift the vehicle has (all the way from stock height to some significant amount of lift). Did I get that right too?
  12. Apr 29, 2015 at 10:26 AM
    #52
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    Not much room on either kind to gusset much that'd do anything.
  13. Apr 29, 2015 at 10:38 AM
    #53
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The ball joint on the LRs have a way to be set initially to add or subtract caster (and camber) before even doing anything to the oem adjusters. I center the oem adjusters and then set the LR ball joint to add 1 degree of caster and center the nut in camber adjustment slot and then the alignment people can use the oem adjusters to fine tune the alignment. If they need big adjustment to get in the ballpark better so they don't have to max oem adjusters, just move the camber nut to get close then go back to oem to fine tune or micro adjust where those stay close to being centered. That way everything has adjustment in either direction to fine tune and no adjustment on truck or UCAs needs to be maxxed out. I don't see where these with the Moog ball joints would have as much camber/caster adjustment as the LRs do but they have the plus of having greasable balljoint and more readily available ball joints without having to go thru manufacturer to get. Pick your poison. Other than those differences, color & price, not seeing much difference between the 2.....................not bashing on either type either so everyone can spare me that crap.
  14. Apr 29, 2015 at 11:06 AM
    #54
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I agree with providing an extra two threads on the bolts.
    Also, would be ideal to get the torque on those bolts stamped somewhere on those UCAs for whenever we have to replace the ball joints.
    I think another idea would be posting a video/picture gallery on how easy it is to swap out the ball joints would get you more customers. :)
    hueman562 and DoorDing like this.
  15. Apr 30, 2015 at 10:17 PM
    #55
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Nice looking product. I'll definitely consider these when it comes time to invest in a set.
  16. May 4, 2015 at 10:03 AM
    #56
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Since SPC control arms are known to fail at the bushing-tube weld point, and because both Camburg and Total Chaos upper control arms gusset that same weld for strength - I'd definitely suggest the feedback that for a strong, trouble free UCA design, those welds should be gussetted with an additional piece of steel for strength, even if that meant a slightly increased cost point.
    Folks are going to buy these in order to wheel them.
    Crom likes this.
  17. May 4, 2015 at 10:05 AM
    #57
    ramonortiz55
    Ramon
    Texas
    stock
    do you know if these would work on a 3rd gen runner?
  18. May 11, 2015 at 6:29 PM
    #58
    Pigpen
    Pigpen My truck is never clean
    Northwest Montana
    2012 AC Manual 4.0 4x4 Base Model
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    UCAs are on my to do list this summer or next spring. These just went to the top of my list. I'll be keeping an eye on this thread. Tell your buddy good work!!
  19. May 13, 2015 at 6:41 AM
    #59
    Pigpen
    Northwest Montana
    @Blackout14 Does he have these in stock, or is he making them per order? Might just pull the trigger for next week when I'm having the ECGS Bushing installed and alignmnet done.
    OBA may just have to wait
  20. May 22, 2015 at 5:52 AM
    #60
    Pigpen
    Northwest Montana
    Okay, now I know just enough to confuse myself....:annoyed:
    @DoorDing According to your link, If I increase my caster at the UCA I will lose clearance at the rear of the wheel well. My truck drives fine, but I wanted more clearance at the rear of the well - I thought that was why I was going to do UCAs.
    Today is pay day and I was going to order these, but now I don't know. The rear of the well is where I'm rubbing and I'll keep my stock UCAs if I'm going to lose the little clearance I have.:help:
    @Crom What's your experience with the clearance in your wheel well??
