5100 885 or 886?
Old 05-07-2009, 04:50 PM   #1
toymachine [OP] toymachine is offline
toymachine will become famous soon enough
toymachine's Tacoma Gallery
5100 885 or 886?
got an 08 dc sport and i just installed the 5100 1.75 set up at front and they ride really stiff. i was thinking if i install the ome coils on my 5100 set at stock will it ride better? how much lift will i get? i just want it leveled and less stiffer. and which one 885 or 886? thanks
Old 05-07-2009, 04:51 PM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
You would want the 885's. Being as they are a 590# spring rate, the ride may be the same, but they would give more lift. The 886's are only for use with a bumper and/or winch.
Old 05-07-2009, 05:03 PM   #3
ohhhh ic. i should just get he toytec coilover kit then. will that solve everything?
Old 05-07-2009, 06:20 PM   #4
chris4x4's Avatar
Stock spring rate is 540 lbs-in. OME 885's are 590#, the coils for the Toytec CO Kit are 600#. Being as your 5100's were useing stock springs preloaded .875" (1.75" lift), your spring rate you have now is around 575 lbs-in. The more the spring rate, the stiffer the ride will be. SO, If your looking to have a softer ride, your gonna want a softer spring, which also means your truck will be lower.
Old 05-09-2009, 09:29 PM   #5
sincitytaco is a name known to allsincitytaco is a name known to allsincitytaco is a name known to allsincitytaco is a name known to allsincitytaco is a name known to allsincitytaco is a name known to all
sincitytaco's Tacoma Gallery
LOL. Trust me I want a lift with a cushy ride as well. The only way to do it though it to either get spindles or a drop down bracket lift.
Old 05-09-2009, 09:29 PM   #6
In my opinion RCD makes the best drop down braket lift.
Old 05-09-2009, 09:32 PM   #7
chris4x4's Avatar
X2.
886 in 885 out OH-MAN Suspension 8 02-26-2011 06:27 PM
Are 884's enough? or 885's or 886's? Hunter'06FLKY 2nd Gen. Tacomas 8 12-27-2010 06:51 PM
Are 884's enough? or should I change to 885's or 886's? Hunter'06FLKY 2nd Gen. Tacomas 0 12-24-2010 08:28 PM
WTT: My OME 885 for 886 blackhawke88 Buy / Sell / Trade 24 05-06-2010 07:33 PM
OME 885 or 886? sonjay Suspension 2 10-21-2008 12:03 AM
