3" Lifts...
Discussion in 'Suspension' started by Menametony, May 11, 2009.
  1. May 11, 2009 at 6:13 PM
    Menametony
    Menametony [OP] Well-Known Member
    Tony
    Oahu
    09 Black 4x4 DC Offroad
    Flow Master 40 Series, TRD CAI, Kings 2.5 remote res front and back, All Pro Front bumper, All Pro Skid Plate, PIAA 4" 510 XT SMR, TC UCA's, 265/75/16 WildPeak AT3 on ATX Artillery, LightForce 240 Blitz HID's, WeatherTech Vents and FloorMats, Cobra 19 CB & PA, Maglite mod both driver and passenger, safari snorkel, TRD supercharger, warn 10k winch, PRINSU CabRack, Cali Raised 42" Light Bar, OEM bed mat, softtopper. WeatherTech Mudflaps On order dissent bed rack and retrofits.
    here it goes again.. another 3" lift question... i would like to lift my 09 Tacoma... not exactly sure what kind of lift though.. well brand that is.. i hear alot about the toytec lift... i will be wheeling it when i can.. but probably going to be highway most of the time.. and when i wheel it, it wont be hardcore.. just some mud holes... a small hill easy stuff like that... im looking to spend about $2k... any inputs would be nice.....i would prefer that the lift come in a package.... i was on wheelers and im thinking about getting the IVD package.. and then i saw the remote resevoir? thats the difference?.. also i want an AAL... Deavers?.. what consist of a full package? and tires... im hoping to run 33's.. is there really rubbing? do i need to trim? im thinking either nitto mud grapplers or some MT baja claws..? any size issues with the stock rim?
    Im also waiting on an all pro bumper, and some rock sliders from revenge fab
    Tony
  2. May 11, 2009 at 6:23 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    You will rub with 33s, minor trimming required. If you wheel seldom you shouldn't need the reseviors, just my $.02. I would run the toytec. Get the 5100 shocks with the AAL.
  3. May 11, 2009 at 6:29 PM
    Menametony
    Tony
    Oahu
    is that all i really need for the lift?
  4. May 11, 2009 at 6:31 PM
    rick
    rick `
    thats about it. Deavers and the IVD's are great choices. new upper control arms are a nice option but not needed.
  5. May 11, 2009 at 6:31 PM
    Menametony
    Tony
    Oahu
    i thought about getting this
  6. May 11, 2009 at 6:33 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Ya stay away from spacers and blocks. Shocks work by converting mechanical energy to kinetic energy (heat) and the oil dissipates it. The reservoir provides more oil to help dissipate that energy
  7. May 11, 2009 at 6:42 PM
    Menametony
    Tony
    Oahu
    i mean this lift is fine right? or is it too much?
    i mean if all i need is the aal and the 5100 billy's.. what the heck is the rest for in this package?
  8. May 11, 2009 at 6:43 PM
    DanGer
    yes that kit is a great kit!
  9. May 11, 2009 at 6:55 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    What I listed was the bare minimum. The link you posted is great, get all the shims and drop brackets include the carrier bearing drop as well. For incase.
  10. May 11, 2009 at 6:57 PM
    Menametony
    Tony
    Oahu
    what does the front diff drop kit do?
