OME TRYING TO SIT LEVEL
Discussion in 'Suspension' started by Jrozz, Apr 18, 2015.
  1. Apr 18, 2015 at 9:27 AM
    Jrozz
    Jrozz [OP] Well-Known Member
    Jonathan
    Colorado
    08 Acc TRD offroad
    hey guys well its my birthday and i got a little cash so I'm wanting to do the Ome suspension lift kit from toytec. i have an 08 access cab TRD offroad. i want to do the 885 coils and the complete dakar leaf pack in the back. i want 3" of lift. toytec says the front will have 3" with a top plate spacer. will i be too high in the front with the top plates? i want to be level but i you have to choose, i would rather be a tad high in the back.
    Thanks for the help!
  2. Apr 18, 2015 at 9:30 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    If you go up 3" in front and approx 3" in the rear with Dakars , you won't be level , you'll have factory rake just 3" higher
  3. Apr 18, 2015 at 10:03 AM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    Even with the top plate spacers?
  4. Apr 18, 2015 at 2:48 PM
    OZ-T
    Peter North
    British Columbia
    Well , consider what you are asking .
    Lets say you have 2" of rake now for example
    If you go up 3" in the front and 3" in the back , you still have 2" of rake , the truck is just 3" higher
  5. Apr 18, 2015 at 4:18 PM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    Ok that makes sense lol. I've seen that you've posted on this subject before. So let me run this setup by you, full OME lift with 885 coils, no top plate spacers, with the full Dakar lead pack but I remove the 3rd leaf. That should be fairly level correct?
  6. Apr 18, 2015 at 4:25 PM
    OZ-T
    Peter North
    British Columbia
    885's with spacers and Dakars with the 3rd or top overload removed is more likely to result in a level stance
    What are your hub to fender measurements now pre-lift ?
  7. Apr 18, 2015 at 5:02 PM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    I'm sitting right at about 20" in front and 23" in the back
  8. Apr 18, 2015 at 5:03 PM
    OZ-T
    Peter North
    British Columbia
    So theoretically putting 885's up front and nothing out back would level you
  9. Apr 18, 2015 at 5:32 PM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    so i wasn't sitting on level ground so i parked and remeasured from the pinch weld and 19" and 21 1/4"
  10. Apr 18, 2015 at 5:34 PM
    OZ-T
    Peter North
    British Columbia
    Measure from the centre of the wheel hub to the underside of the fender directly above the hub vertically
  11. Apr 18, 2015 at 5:53 PM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    ok 3rd time is a charm lol. 19 7/8 in front and 22 1/8 in the back
  12. Apr 18, 2015 at 5:56 PM
    OZ-T
    Peter North
    British Columbia
    So you basically have the 2" of rake I mentioned before , so keep that in mind when you decide what to add for front and rear heights if you want to level or reduce your rake
  13. Apr 18, 2015 at 6:05 PM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    well i don't want it to look like I've only leveled the front. this is all kind of confusing to me. if I'm gonna spend a good amount on a lift i want it to be noticeably higher, not just level if that makes sense. what would you sugest?
  14. Apr 25, 2015 at 1:51 AM
    P33Rob
    P33Rob Well-Known Member
    Rob
    Watertown, NY
    13 Tacoma V6 TRD 4X4
    OME 3" Lift; Maxfit aeromax; Volant CAI w/scoop; TRD Exhaust; Step rails; SCS stealth 6 wheels; Bedrug
    I have the 885's in front with trim packer and Dakar's in back with ome struts. I have 3" gain in rear and about 2.5" gain in front. I bought a set of ½" spacers for the front. Would have bought 887's had I known. The spacers go on today we will see what the diff is. Right now I am on 33" tires and get some rub up front from the side view it looks a little low in front. I have a camper shell which I assumed would drop the rear a little but nope. BTW I took pics at an angle and turn camera to give lvl appearance I will take level before after shots and post later today.
  15. Apr 25, 2015 at 2:30 AM
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    If u want 3" in the front you might as well get the 887 coils instead of the 885s with spacers..885s will get you roughly 2.5"
  16. Apr 25, 2015 at 2:51 AM
    P33Rob
    Rob
    Watertown, NY
    That's why I have to do spacers the 887's were not available.
  17. Apr 25, 2015 at 5:39 PM
    P33Rob
    Rob
    Watertown, NY
    First one Before/others after
  18. Apr 26, 2015 at 5:23 AM
    P33Rob
    Rob
    Watertown, NY
    Not too noticeable in pics but no more rub. Drives and feels more level. Highly recommend ½" spacer if you have 885 and dakkars.
    -Rob
  19. Apr 26, 2015 at 7:39 PM
    Mikechek
    Mikechek Sitting on Twinkies.
    Pembroke Pines
    2016 Tacoma TRD 4X4 Sport
    fox 2.5 CO. With res, rear fox 2.5 with res, Dakar pack, total chaos arms, Fuel maverick with 285/55/20, AFE intake, Bakflip, stock navigation, Weathertech, Top Rack
    I had the same doubt about which way to go. But went with the 887 in the front and Dakar's in rear. 3' all the way. 887 are bigger. My truck rides fantastic. It got stiff but a good stiff. Not a ruff stiff. You won't need any spacer. But will need new uca. Caster will be boarder line. But my truck sit just right. I bought the complete ome set with new spc UCA fRom HEadstrong. Everything was 1500. I had bad experiences with spacer on my f150. Never again.
