2009 Lift help
Old 05-14-2009, 08:49 AM   #1
09tacoLI [OP] 09tacoLI is offline
09tacoLI is one of the sharper tools in the shed09tacoLI is one of the sharper tools in the shed09tacoLI is one of the sharper tools in the shed09tacoLI is one of the sharper tools in the shed09tacoLI is one of the sharper tools in the shed09tacoLI is one of the sharper tools in the shed09tacoLI is one of the sharper tools in the shed09tacoLI is one of the sharper tools in the shed09tacoLI is one of the sharper tools in the shed09tacoLI is one of the sharper tools in the shed09tacoLI is one of the sharper tools in the shed
09tacoLI's Avatar
Air Force: security forces
09tacoLI's Tacoma Gallery
2009 Lift help
I have a 2009 OR 4x4 dbl cab SB. I got my TC ucas yesterday from the group buy. Now I need to pick out my lift and I have been reading my ass off trying to decide what is going to work for me. I do mostly trail off roading and beaches. What I'm looking for is midrage price and reliable.
I have been leaning toward the Toytec ultimate lift kit. If I go with this lift will I need to buy other stuff like brake lines ext. Also I see alot of guys swearing by OME what kind of set up is this and do you need a diff drop and shims for the rear. Thanks for the help.
Old 05-14-2009, 03:48 PM   #2
TacoTycoon is a splendid one to beholdTacoTycoon is a splendid one to beholdTacoTycoon is a splendid one to beholdTacoTycoon is a splendid one to beholdTacoTycoon is a splendid one to beholdTacoTycoon is a splendid one to beholdTacoTycoon is a splendid one to behold
TacoTycoon's Avatar
TacoTycoon's Tacoma Gallery
you can't go wrong with either the toytec coilovers or the whole OME setup. The only difference is in spring rate (can't remember the difference) and the coilovers are adjustable. I do not believe extended brake lines are required, nor is the diff drop. Hope this helps some and others will chime in to verify and help you with the rest, good luck!
Old 05-14-2009, 06:32 PM   #3
bajamoon is one of the sharper tools in the shedbajamoon is one of the sharper tools in the shedbajamoon is one of the sharper tools in the shedbajamoon is one of the sharper tools in the shedbajamoon is one of the sharper tools in the shedbajamoon is one of the sharper tools in the shedbajamoon is one of the sharper tools in the shedbajamoon is one of the sharper tools in the shedbajamoon is one of the sharper tools in the shedbajamoon is one of the sharper tools in the shedbajamoon is one of the sharper tools in the shed
bajamoon's Tacoma Gallery
don't need brake lines, both are good affordable kits that will serve you well, flip a con and pick one.
Old 05-14-2009, 08:16 PM   #4
rpparkster is a splendid one to beholdrpparkster is a splendid one to beholdrpparkster is a splendid one to beholdrpparkster is a splendid one to beholdrpparkster is a splendid one to beholdrpparkster is a splendid one to beholdrpparkster is a splendid one to behold
rpparkster's Avatar
rpparkster's Tacoma Gallery
I went OME through Toytec w/ the AAL and OME Shocks all around. Drives good and really happy w/ the results. I didn't want to go with Ultimate Kit b/c I wanted a ride close to stock without firming it up too much. Also, I'm not that serious of an off road-er so I thought Coilovers were overkill for me.
Old 05-14-2009, 08:29 PM   #5
chris4x4's Avatar
chris4x4's Tacoma Gallery
The differences between the OME and the Toytec Coilovers are:
The Toytec springs are a 16" 600# spring rate
OME 885's are 16" 590# spring rate
The Toytecs are adjustable
The OME shocks are a low pressure twin tube (more oil) speed sensative dampening
The Toytec uses the Bilstien 5100's which are a single tube High pressure shock, with speed sensative dampening.
Old 05-14-2009, 08:30 PM   #6
vwguy60 is a jewel in the roughvwguy60 is a jewel in the roughvwguy60 is a jewel in the roughvwguy60 is a jewel in the rough
vwguy60's Tacoma Gallery
I went with the Toytec Ultimate Kit on my 2009, it was great, the install took less than 2 hours with a friend and it rides really nice!
Old 05-15-2009, 02:07 AM   #7
09tacoLI's Avatar
Thanks guys still till june to make my choice. I have more info now this site is great.
lift/vsc/trac questions for 2009 808 Suspension 7 09-22-2010 05:40 PM
3" lift on a 2009 4x4 reyespoli Suspension 52 02-28-2010 09:48 PM
WTB: Coil-over lift 2009 Tacoma Its_Taco_Time Buy / Sell / Trade 3 09-16-2009 11:50 AM
2009 3" lift SDe92bmw335i 2nd Gen. Tacomas 1 05-25-2009 01:13 AM
2009 Taco Lift Options STLTaco09 Suspension 44 12-19-2008 07:38 PM
