Damned squeaky leafs again!!
Discussion in 'Suspension' started by badguybuster, May 21, 2009.
  1. May 21, 2009 at 6:03 PM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I posted a few weeks ago about my leaf pack squeaking. You all suggested driving through some water. Which worked for a bit. When I put my AAL's on, I greased the shit out of the hole thing but it is at it again. I tried hosing it out at the car wash, no luck, so I sprayed it with WD 40, no luck. I am frustrated as hell. It seems to come from the mounting bolts on either end. Any suggestions other than setting it on fire??
  2. May 21, 2009 at 6:07 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    loosen the lounting bolts a tad and spray down between them and the leafs with somewhite lithium grease or some type dry moly lube then tighten them back up. wd-40 isnt too good to use,cause it attracts dirt and dust.
  3. May 21, 2009 at 6:08 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
  4. May 21, 2009 at 6:29 PM
    badguybuster
    Michael
    Ok. I will give it a shot this weekend. If I dont' flip out first.
  5. May 21, 2009 at 6:34 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    -1 on flipping out...high blood pressure sucks. LOL
  6. May 22, 2009 at 4:58 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    Make sure the bolts that attach the leafs to the truck are torqued properly. I believe there is a bushing in there that will not work properly unless it is torqued to spec. When it is torqued to spec, it prevents the squeeking and other noises coming from that area.
    This just recently happened with my truck. It was pretty loud too. The probably was the front bolt on the drivers side leaf wasn't as tight as it should be.
  7. May 22, 2009 at 9:57 AM
    badguybuster
    Michael
    Well, I tried that and it didn't stop the squeaking..so I set her on fire and rolled her down a hill.......(ok, not really). I took the leaf pack apart and greased the whole thing. Nice and quiet now.
  8. May 22, 2009 at 2:23 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I get the squeaking every few months. I finally pin pointed the exact point where the squeak comes from.
    Shove a large screwdriver between the top leaf and the second one down. Pry them about 1/8 inch apart. Spray some silicone lube right on the pad. It works perfectly for me.
  9. May 22, 2009 at 5:54 PM
    badguybuster
    Michael
    Thanks. I will remember that for next time. I disassembled the pack and lubed the whole damn thing.:eek: Anyone know what the torque specs are. If not I can check on TTORA. Thanks
  10. May 22, 2009 at 5:56 PM
    no_werries
    no_werries Well-Known Member
    Simcoe County, Ontario, Canada
    2005 4x4 reg cab Indigo Ink 5 speed
    CAI, 2 1/2" rear lift AAL, Ready Lift strut ext. & diff drop = 2 1/2" front lift, tweaked clutch, Magnaflo Muffler & Custom exhaust 265/75/16lt Nitto Terra Grappler 8ply on stock rims. Huskyliners
    Yeh I do the same with the leafs, another good way to spread the leafs is to jack up the back of the truck by its frame, and let the axle hang, it will stretch the leafs out enough that you can spray in between where it squeaks!
  11. May 22, 2009 at 6:02 PM
    badguybuster
    Michael
    This is the 2nd time I have had to fix it plus the dealer fixed it once. what a pain in the ass.
