Pics of CV Boots with 1.75" and 2.5" lift
Old 05-28-2009, 02:01 PM   #1
STLTaco09 [OP] STLTaco09 is offline
STLTaco09 has a spectacular aura aboutSTLTaco09 has a spectacular aura aboutSTLTaco09 has a spectacular aura about
STLTaco09's Tacoma Gallery
Just as the title states, can you share your photos of your CV boots if you have a lift of either 1.75" or 2.5"? Just doing a little research here and I'm curious how drastic the difference is between the two.
Also, if you've got a 2.5" lift (i.e. Billys @ 2.5"), I'm interested to know how many miles you've put on your truck, and what (if any) issues you've had related to your lift, diff, or CV boots.
I've searched and found a few photos with the wheel off the ground, which obviously isn't realistic.
Thanks!
Old 05-28-2009, 05:25 PM   #2
pataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud of
pataco's Tacoma Gallery
heres mine with 2.5" of lift with diff. drop.got 5000 miles on it with no issues except the mild vibes between 35 and 38mph.
Old 05-28-2009, 05:29 PM   #3
I'm new to this and all, but that angle doesn't seem harsh at all. Correct me if I'm wrong though... Any idea as to the vibes? Does it feel like its coming from the rear (lifted rear?), from the diff?
Thanks for posting the pic, I really appreciate it.
If anyone else can chime in with photos, it would help greatly.
Thanks!
Old 05-28-2009, 05:32 PM   #4
Carolina Alliance
jolayiv is one of the sharper tools in the shedjolayiv is one of the sharper tools in the shedjolayiv is one of the sharper tools in the shedjolayiv is one of the sharper tools in the shedjolayiv is one of the sharper tools in the shedjolayiv is one of the sharper tools in the shedjolayiv is one of the sharper tools in the shedjolayiv is one of the sharper tools in the shedjolayiv is one of the sharper tools in the shedjolayiv is one of the sharper tools in the shedjolayiv is one of the sharper tools in the shed
jolayiv's Avatar
Marines: SSgt 6332
jolayiv's Tacoma Gallery
Send a message via AIM to jolayiv
I know you asked for the 1.75" and 2.5" but here is my 3" and the diff drop.
Old 05-28-2009, 05:34 PM   #5
I can tell a difference b/w this and the 2.5" lift in the CV boots. Is this considered pushing the limits? They definitely seem closer together. Any issues? Vibes?
The CV boots on the left in the photo seem worse than the other side.
Old 05-28-2009, 05:39 PM   #6
Carolina Alliance
jolayiv's Avatar
Marines: SSgt 6332
Nope no problems. I had a small vibe but that was fixed with some carrier bearing spacers. I have about 6k on the lift so I would like to think that if I was going to have a problem I would have seen it by now.
Old 05-28-2009, 05:40 PM   #7
STL im pretty sure its from the front(vibes).it a long drawn out story but it seems to b some get it and some dont.cant answer why though.i do no i had the 3" spacer lift and the vibes were REAL bad.took all that JUNK off and went to foxs set at about 2.5" and its a bunch better.so im going to say the cv angles were to much imo.again,some people get it and most dont.but it deff. wouldnt stop me from doing another one,thats for sure.
Old 05-29-2009, 04:31 AM   #8
Muliefever
muliefever has a spectacular aura aboutmuliefever has a spectacular aura about
Coast Guard: First Class Petty Officer
muliefever's Tacoma Gallery
5100 at 1.75", The tire is turned out in this pic. I think this is a good setting.
Old 05-29-2009, 12:44 PM   #9
No diff drop here for you? Just checking to make sure.
Old 05-29-2009, 05:04 PM   #10
Makana will become famous soon enough
Air Force:
Makana's Tacoma Gallery
How many inches of thread did set below adjuster ring?
Old 05-30-2009, 01:48 PM   #11
If anyone else has a 1.75" or 2.5" lift, it'd be helpful if you could chime in here with a photo of the CV boots. I think this could be a pretty helpful thread for a lot of people debating on lift heights.
Old 07-16-2009, 08:57 PM   #12
FoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud of
FoxRacR17's Tacoma Gallery
Dont mean to bring this thread back from the dead, or hijack it, but I too am curious to see some more pictures of the CV boots with a 3" lift.
Old 07-17-2009, 06:31 PM   #15
heres a picture of mine with a 3" lift and diff drop. Does this look about right? Looks similar to the other person that posted a pic of their 3" boots.
Old 07-17-2009, 10:27 PM   #16
rab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shed
rab89's Avatar
rab89's Tacoma Gallery
3'' seems to be a bit far. the pics of 2.5 dont look bad at all!
Would anyone have pics with an ome lift? list the specs of the lift with the pic if you can
Old 09-07-2010, 05:06 PM   #17
ibengineer will become famous soon enoughibengineer will become famous soon enough
ibengineer's Tacoma Gallery
are the ribs just not supposed to be touching?
Old 09-07-2010, 08:45 PM   #18
Bsly862 has much to be proud ofBsly862 has much to be proud ofBsly862 has much to be proud ofBsly862 has much to be proud ofBsly862 has much to be proud ofBsly862 has much to be proud ofBsly862 has much to be proud ofBsly862 has much to be proud of
Bsly862's Avatar
Bsly862's Tacoma Gallery
Correct thats the general rule to follow, if the ribs are touching the chances of a rip or a role in the CV increases so the boots may not last as long
pics of 1.75" lift and 265/75/16??? TRDfarmerTN 2nd Gen. Tacomas 13 07-10-2012 07:21 AM
3" Lift + CV Angles - bring pics jandrews Suspension 131 12-23-2011 08:13 PM
3" Lift w/ 265/75/16 pics please BEEFY_CHEESY_TACO 2nd Gen. Tacomas 13 06-01-2010 09:11 PM
Post Pics of CV angles w/ 2-3" lift !! toyo freak 2nd Gen. Tacomas 14 05-22-2010 03:29 PM
CV boots touching on my 3" lift chad68 Suspension 1 06-20-2009 12:23 AM
