FOX 2.0 vs 2.5 Coilover
View Poll Results: If you had a choice and money wasn't a factor, would you choose...
Fox 2.0 adjustable coilovers 55 22.27%
Fox 2.5 coilovers 192 77.73%
Voters: 247. You may not vote on this poll
Old 06-07-2009, 06:06 PM   #1
Seagrave [OP] Seagrave is offline
Seagrave will become famous soon enough
Seagrave's Avatar
Seagrave's Tacoma Gallery
Thumbs up FOX 2.0 vs 2.5 Coilover
I apologize in in advance but I was unable to find my answer in the other suspension threads and tried a searching for it too.
This information will help others too.
I have several suspension questions...
I have narrowed it down to FOX brand suspension products for the lift on my 2009 Tacoma (4 door Long Bed 4x4)
What is the difference between the Fox 2.0 and the fox 2.5? What does the 2.0 and the 2.5 mean. Is that the diameter of the spring or the shock?
Also, why is the 2.0 Fox Coilover cheaper if it has adjustability to it?
If you have a choice, which one would you get, the 2.0 or the 2.5 Fox Coilover?
Also if you have pictures of Fox products... lets see ONLY fox suspension here too
Old 06-07-2009, 06:08 PM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
2.0 and 2.5 refers to the diameter of the shock body. The 2.5 holds more oil, so as to stay cooler longer. Depending on the wheeling you do, the 2.0's may work just fine for ya.
Old 06-07-2009, 06:26 PM   #3
Seagrave's Avatar
The shock bodies are ether 2" or 2.5" but they both have the same spring right
Old 06-07-2009, 06:37 PM   #4
chris4x4's Avatar
Hmm...I never checked to see if the springs are the same size....I know they are the same spring rate.
Old 06-07-2009, 06:58 PM   #5
mjp2's Avatar
mjp2's Tacoma Gallery
Springs are different. A 2.5" coilover requires a 3.0" inner diameter spring. The 2.0" coilover uses a 2.5" I.D. spring.
What kind of wheeling do you do?
Old 06-07-2009, 09:50 PM   #6
Seagrave's Avatar
OK i guess that makes sense... that if the shock is bigger then the spring has to be bigger diameter. But I assume they have the same spring rate of #650.
I will only be doing minor wheeling, nothing too crazy.
Money is not really an issue here.... I just want the better of the two. Just from my little knowledge, it seems that the 2.0 would be a better choice because of the adjustability factor.
What would you chose? Can someone put a poll on this thread to choose between the 2.0 adjustable or the 2.5 coilover.
Old 06-08-2009, 07:48 AM   #7
Founder Socaltacomas.com
SocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shed
SocalMan22's Avatar
SocalMan22's Tacoma Gallery
In your case you say minor wheeling, in my case i would go with 2.5" cause it suits my needs, but you seem like you would be happier with 2.0 but if money isnt a factor go with 2.5"
Old 06-08-2009, 07:51 AM   #8
mjp2's Avatar
I have the 2.5's with the remote reservoirs because I need as much fluid as possible in the shocks to help keep them cool. I'm also not opposed to opening up the shocks and revalving the them internally to get the ride just right.
For light wheeling, or even hardcore wheeling that isn't continuous high-speed stuff, the 2.0 shocks will be an excellent choice for their performance and easy tunability.
Old 06-08-2009, 07:56 AM   #9
Fire931 is one of the sharper tools in the shedFire931 is one of the sharper tools in the shedFire931 is one of the sharper tools in the shedFire931 is one of the sharper tools in the shedFire931 is one of the sharper tools in the shedFire931 is one of the sharper tools in the shedFire931 is one of the sharper tools in the shedFire931 is one of the sharper tools in the shedFire931 is one of the sharper tools in the shedFire931 is one of the sharper tools in the shedFire931 is one of the sharper tools in the shed
Fire931's Tacoma Gallery
i run the 2.0's on mine.. unless you are going to be doing alot of high speed offroad traveling they will do just fine. i love how mine preform offroad and the onroad ride is like a caddy!!!
Old 06-12-2009, 09:35 AM   #11
spaghettiedy has much to be proud ofspaghettiedy has much to be proud ofspaghettiedy has much to be proud ofspaghettiedy has much to be proud ofspaghettiedy has much to be proud ofspaghettiedy has much to be proud ofspaghettiedy has much to be proud ofspaghettiedy has much to be proud ofspaghettiedy has much to be proud ofspaghettiedy has much to be proud of
spaghettiedy's Avatar
Army: Ret. USAR Sgt.
spaghettiedy's Tacoma Gallery
From what I'm reading, the 2.5s perform better offroad. Will the 2.0s perform better onroad, or will the 2.5s beat them there as well?
Old 06-13-2009, 08:02 PM   #13
pataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud of
pataco's Tacoma Gallery
here is mine.2.0 and love them.got the lruca as well.good luck.
Old 06-13-2009, 10:17 PM   #14
Seagrave's Avatar
Is this a good deal?
http://www.offroadwarehouse.com/prod...roductID/39119
Old 06-13-2009, 10:29 PM   #15
SocalMan22's Avatar
I believe thats a very good deal. comes with everything you need so have a bad ass suspension.
Old 06-18-2009, 09:33 PM   #16
FoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud ofFoxRacR17 has much to be proud of
FoxRacR17's Tacoma Gallery
Is that a trust worthy seller? That is a great deal! I think this would seal the deal for me if this website is legit.
Old 06-18-2009, 10:12 PM   #17
Seagrave's Avatar
Off Road Warehouse is a big company in southern California. It is indeed legit. It went there yesterday and they a hard time believing the deal and had to call corporate to verify the what the website stated. It think I am going to make the purchase tomorrow.
It came out to:
$2179.00 (Merchandise)
$497.00 (Labor)
$17.00 (Misc)
$192.15 (Wonderful California Tax)
$2885.15 (Total)
But I think I am going to install the lift myself with the help of my pops, then get it aligned following the install. That will save 500 bucks
Old 06-19-2009, 04:21 PM   #19
save the $500 bucks.its not a hard install at all if you have a little machanical background.i couldnt believe how easy it was when i did mine.good luck.
Old 06-19-2009, 05:36 PM   #20
so i'm probably going to order from ORW today since its payday. Correct me if i'm wrong but I still need to buy a 1.5" AAl for the rear correct? I have an 09 DC that DOES NOT have the TSB done.
Fox Coilover Leveling Adjustibilty norcaloffroad Suspension 2 08-05-2011 12:05 AM
2.0 Fox Coilover Q's Weekend Warrior Suspension 1 04-04-2011 11:06 PM
FOX 2.5 Resi Coilover question Masada Suspension 11 06-29-2010 07:58 AM
Fox coilover quote sinaloa226 Suspension 14 04-03-2010 08:23 AM
Fox 2.0 Coilover resivoirs Questions jdkeller Suspension 81 08-16-2009 01:00 AM
