Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Nov 3, 2014 at 11:57 AM
    #9961
    Evenflow
    Evenflow Well-Known Member
    Jason
    San Diego, CA
    06' DCSB 4x4
    Yes
    your truck does not look like it is sitting at 6" it looks more like 8" in the front ? What is your front measurement ?
    Edit - Hduece22 you need to add 6" to your current front measurement and then do the math for the rear end...make sense ? Unless you are goi to pre load your new CO's to go higher that 6"
  2. Nov 3, 2014 at 12:00 PM
    #9962
    Hdeuce22
    Hdeuce22 Well-Known Member
    Alabama
    2013 4x4 DC Sport TRD
    I was thinking the same thing. His trucks looks to be a good bit higher than 6" in the front.
  3. Nov 3, 2014 at 12:05 PM
    #9963
    Hdeuce22
    Alabama
    My preference is to roll with no preload up front. These guys that have the Alcan 6" packs have to be cranking the front up to get it level is the only thing I can come up with.
  4. Nov 3, 2014 at 12:46 PM
    #9964
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    This :thumbsup:
    5" leaf pack and loose the preload, this is what I did.
    I also removed the plastic from my rear fenders this weekend and did a drive line service. Turns out I separated my carrier bearing. I ended up changing the spacing on the carrier as well and the vibs are gone or so minor I don't feel them. I won't pull the front plastic until I get a plate bumper and I will end up using spray liner to coat the inner fender.
  5. Nov 3, 2014 at 5:23 PM
    #9965
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Considering that stock It was 20" in the front and 22" in the back...center hub to fender....got it on level ground now and im at 28" even in back and 28 1/4" in front.....so yes I'm 8" front and 6" rear
    And it's perfect :cool:
  6. Nov 3, 2014 at 5:55 PM
    #9966
    Evenflow
    Jason
    San Diego, CA
    06' DCSB 4x4
    Yes
    Please don't misunderstand me, I'm not saying there is anything wrong with it - my truck sits that high too :D I just want Hdeuce22 to understand what an actual 6" lift nets him vs. what he may be seeing and visually comparing too vs performance.
  7. Nov 3, 2014 at 6:03 PM
    #9967
    YotaMatt
    West Point VA
    He also may not realize I'm a prerunner and don't have a 6" drop bracket lol
  8. Nov 3, 2014 at 6:57 PM
    #9968
    Hdeuce22
    Alabama
    Yes,it makes sense. I think if I wan't it level I have 2 choices. Either go with the 6" leaf pack and crank up the coilovers to match or get the 4" pack and roll with no preload. I think the guys running the 6" pack have to be sitting on a couple inches of preload up front. I just wanted to make sure I was ordering the right pack to sit level is all and I wasn't sure if the 6" pack would net me an actual/true 6". I appreciate the help guys. By the way,I like both of your trucks. I hope to join the club soon! :)
  9. Nov 3, 2014 at 6:58 PM
    #9969
    Hdeuce22
    Alabama
    Thanks Matt. I actually just realized you were a Prerunner. :D
  10. Nov 3, 2014 at 7:50 PM
    #9970
    Hdeuce22
    Alabama
    Anyone here with 18x10 or 20x10 wheels with 4.75 backspacing? Curious if I will run into issues or not. Not sure if lift brands play a part in this too but I'm planning on going with BDS.
  11. Nov 3, 2014 at 8:28 PM
    #9971
    2ndGenJonny
    Jon
    Gilbert, AZ
    Talk to the Hawaii group, that look is huge there
  12. Nov 4, 2014 at 3:11 AM
    #9972
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, 18 x 9 -12 Weld Racing Ledge 6 wheels w 275/65r18 Toyo AT III tires
    I ran a 18 x 10 w 4.5 bs and no issues. There is enough room between the wheel and spindle on the bds / zone kits where where a 4.75 bs will be fine.
  13. Nov 4, 2014 at 5:41 PM
    #9973
    Hdeuce22
    Alabama
    Thanks a lot Born! The wheels I want are only listed in 4.75 but I spoke with the manufacturer today and they can make them with a 4.5 but will take a couple weeks longer so to be safe I think I may wait for the 4.5.
  14. Nov 4, 2014 at 9:27 PM
    #9974
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Toytec Ultimate lift Coilovers Toytec AAL No diff Drop 5% Tint all around Morimoto 2Stroke LEDS High and Low Morimoto Fog Lights MESO Key FOBs
    Really? It's more of a 20x12 or 20x14 look
  15. Nov 5, 2014 at 4:53 AM
    #9975
    2ndGenJonny
    Jon
    Gilbert, AZ
    I stand corrected :confused:
  16. Nov 5, 2014 at 6:22 AM
    #9976
    Hdeuce22
    Alabama
    Matt,where did you get your 18" coils from? I plan on staying with the stock bumper up front and no added weight so do you think going with the 18" and staying at 600lb would be ok?
  17. Nov 5, 2014 at 6:52 AM
    #9977
    2ndGenJonny
    Jon
    Gilbert, AZ
    I belong to the mindset that its the +3.5 LT trucks that need fiberglass for a functional reason. Maybe its because I'm yet to see a set of fenders that really match the Tacoma's sexy curves. I've never seen a DB with glass either.... Until now.
    So here is a SEMA DB Tacoma with fiberglass. The RTT looks good, the red sway bar needs to disappear ad well as the red letter grabbers IMO. Sadly, this truck is probably a mall crawler only and the RTT is used for black Friday and iPhone release parking lot camping.
  18. Nov 5, 2014 at 7:44 AM
    #9978
    Manwithoutaplan
    ID
    Does it ride better Blacktacoma?
  19. Nov 5, 2014 at 9:09 AM
    #9979
    JonathanN
    JonathanN Well-Known Member
    Jonathan
    Center, TX
    2013 DCLB 4x4
    Finally got my "HYBRID" finished up. OME 2.5" setup with progressive AALS stacked on top of a Zone Offroad 4" lift.
    20141016_165051_zpsa8zradj_edit_14152071_a834c704ef93c91ce869ab86d5a59c930c282320.jpg[/URL]
  20. Nov 5, 2014 at 1:41 PM
    #9980
    Evenflow
    Jason
    San Diego, CA
    06' DCSB 4x4
    Yes
    Great looking truck !
