4 inch lift kit?
Old 07-16-2009, 09:58 PM   #1
lennythetaco is on a distinguished road
lennythetaco's Avatar
lennythetaco's Tacoma Gallery
4 inch lift kit?
does any one know a good 4 inch lift kit for an 09 tacoma 4x4 double cab trd off road
Old 07-16-2009, 10:53 PM   #3
Kenny650 has a brilliant futureKenny650 has a brilliant futureKenny650 has a brilliant futureKenny650 has a brilliant futureKenny650 has a brilliant futureKenny650 has a brilliant futureKenny650 has a brilliant futureKenny650 has a brilliant futureKenny650 has a brilliant futureKenny650 has a brilliant futureKenny650 has a brilliant future
Kenny650's Avatar
Kenny650's Tacoma Gallery
Your best option would be the Camburg Spindles but you wouldn't be able to run them because you have a 4x4.
Old 07-17-2009, 12:42 AM   #4
sincitytaco is a name known to allsincitytaco is a name known to allsincitytaco is a name known to allsincitytaco is a name known to allsincitytaco is a name known to allsincitytaco is a name known to all
sincitytaco's Tacoma Gallery
Originally Posted by Coastie Joe View Post
RCD Suspension makes a pretty sweet one!
So.....this appears to be the best option then. But yes if you have a prerunner the spindles are pimp shit.
Old 07-17-2009, 06:14 PM   #5
Banned
bermise will become famous soon enough
bermise's Tacoma Gallery
X1, get the Total Chaos or Camburg spindles.
Old 07-17-2009, 09:29 PM   #6
Kenny650's Avatar
Spindles FTW!
Old 07-19-2009, 04:03 PM   #7
kris219 is on a distinguished road
kris219's Tacoma Gallery
will you be straight if you just put the spindles on a stock suspension?
Old 07-20-2009, 01:09 AM   #8
Kenny650's Avatar
if your talking about alignment then yes you will need one. spindles are suppose to keep your stock configuration so you won't be needing UCA's
Old 07-20-2009, 05:48 AM   #9
shockittillyareconizeit is a name known to allshockittillyareconizeit is a name known to allshockittillyareconizeit is a name known to allshockittillyareconizeit is a name known to allshockittillyareconizeit is a name known to allshockittillyareconizeit is a name known to all
shockittillyareconizeit's Tacoma Gallery
You all just answered my questions. Camburg here i come!
Old 07-20-2009, 09:29 AM   #10
no, i mean is it alright to put the spindles on a stock suspension without having to change anything else?
Old 07-20-2009, 10:03 AM   #11
WoodsDweller
KraQr is one of the sharper tools in the shedKraQr is one of the sharper tools in the shedKraQr is one of the sharper tools in the shedKraQr is one of the sharper tools in the shedKraQr is one of the sharper tools in the shedKraQr is one of the sharper tools in the shedKraQr is one of the sharper tools in the shedKraQr is one of the sharper tools in the shedKraQr is one of the sharper tools in the shedKraQr is one of the sharper tools in the shedKraQr is one of the sharper tools in the shed
KraQr's Avatar
Air Force:
KraQr's Tacoma Gallery
As a note to the OP the RCD 4 inch lift will not work on your 4x4 if you have the VSC option. Last I checked with RCD they had not fixed this problem. It causes the onboard computer to freak out. I would verify that the VSC controls do not interfer, as they were testing it again a few months ago.
I installed Camburg Coil overs and UCAs and I was able to dial it up to 4 inches on my 09 though with no problems and my CV joints are not at extreme angles either.
Good luck with your choice.
16 inch rims with a 6 inch lift kit kinkrider101 2nd Gen. Tacomas 19 03-31-2014 07:51 AM
3 Inch TOYTEC Ultimate Lift OR RCD 4.5 Inch Lift Kit? FXHO 2nd Gen. Tacomas 17 08-08-2013 01:37 PM
Is this kit any good? 6 inch Lift Kit with ES3000 Shocks Brian1441 Suspension 6 01-25-2012 08:57 AM
3 inch lift kit on a budget JR616 Suspension 7 11-18-2010 04:43 PM
3 inch lift kit. tacomamike44 New Members 2 11-05-2010 05:13 PM
