what does a spindle lift do?
Discussion in 'Suspension' started by t.hornstra, Jul 22, 2009.
  1. Jul 22, 2009 at 10:37 PM
    t.hornstra
    t.hornstra [OP] Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    ChadsPride likes this.
  2. Jul 22, 2009 at 10:58 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    i was looking at these, or 5100s set at 1" and the 2.5" top plate.
    my springs have sagged a little bit so i think its really only 2 inches of lift up front right now.
    do the 5100s have more downtravel? compared to stock struts
  3. Jul 22, 2009 at 11:06 PM
    RelentlessFab
    Eric
    Sparks, NV
    well, to my knowledge: a spindle lift is just an aftermarket spindle for 2wd trucks that moves the position of where the hub mounts(lower by however much, to give a lift) in relation to the control arms. hope that makes sense. And to answer another question, I dont believe the 5100s offer more suspension droop(down travel).
    ChadsPride and Mr.PowerTrays like this.
  4. Jul 22, 2009 at 11:31 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    San Jose, CA (Nor-Cal)
    2010 SSM DCLB
    subscribing
  5. Jul 22, 2009 at 11:43 PM
    MsTRD
    MsTRD hell yes i love my truck
    Samantha
    Rohnert Park, CA
    06 White Prerunner TRD Sport
    my sister has TC spindles on her 05 tacoma. she really likes them, says the ride is a lot better. the only complaint she has is that the stock 17s on the 05 don't fit with them so she had to get wheel spacers and her alignment is way off. since you have an 02 i don't know if you would have the same problem...
    if what you want is the front end higher, you will definitely get that. her tacoma has a pretty big lean to it. these pictures aren't good and you can't really tell, but hers is the white one.
  6. Jul 22, 2009 at 11:46 PM
    RelentlessFab
    Eric
    Sparks, NV
    off topic, but.... What kind of grille is on her truck? Grillecraft?
    PS.
    tell her she needs the BHLM:)
  7. Jul 22, 2009 at 11:50 PM
    MsTRD
    Samantha
    Rohnert Park, CA
    yepp the grillcraft mx grille, same one i have. i tried telling her to do the BHLM but she thinks it will make her HIDs pointless....she doesn't listen to me
  8. Jul 23, 2009 at 12:08 AM
    Kenny650
    Kenny650 Well-Known Member
    Wow..sisters with Tacomas..never heard such a thing!
    edit: do you have any side views of the white Tacoma?
  9. Jul 23, 2009 at 12:10 AM
    RelentlessFab
    Eric
    Sparks, NV
    must be an older sister;)
  10. Jul 23, 2009 at 8:18 AM
    MsTRD
    Samantha
    Rohnert Park, CA
    haha yepp :rolleyes:
  11. Jul 23, 2009 at 9:06 AM
    Kenny650
    ^ That is a fat lean...does she have any sort of lift in the rear?
  12. Jul 23, 2009 at 9:41 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    If you are 2wd and want over 2.5" of lift total chaos or camburg spindles are the best way to do it. They are pricey but you will get the best results.
  13. Jul 23, 2009 at 10:10 AM
    MsTRD
    Samantha
    Rohnert Park, CA
    nope not yet, she's planning on dakars in the rear i believe.
  14. Jul 23, 2009 at 11:21 AM
    jacob_wood
    Jacob
    2010 SSM DCLB
    would you need to get new UCA's with these or would the stock ones work?
  15. Jul 23, 2009 at 11:42 AM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    im not a big fan of the front tires sticking out so far and the back ones tucked in.... just doesnt look right, two very nice trucks though
  16. Jul 23, 2009 at 4:03 PM
    RelentlessFab
    Eric
    Sparks, NV
    thats one of the benefits of a spindle lift- you keep your a-arms at the same angle as stock so unless you want the extra lift of some spacers, or coilovers you wouldnt need aftermarket UCAs. So then i guess that would means it depends on whether you just do the spindle lift, or you do some suspension also.:cool:
  17. Jul 23, 2009 at 7:01 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    So would I be able to put a spindle lift and keep my 2.5inch spacer? Or is that exceeding the limit for a nondropbracket lift? Or wouldthe longer spindles allow more lift without having to do drop brackets?
    I'm thinking of getting 5100s also. Could I set them at 1" and putthe spindle lift on as well? And take off my spacer lift.
  18. Jul 23, 2009 at 7:04 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    so with spindles to get the back as high as the front would i do aal?
    and how much lift is it?
  19. Jul 23, 2009 at 9:11 PM
    Kenny650
    4"
  20. Jul 23, 2009 at 9:13 PM
    MsTRD
    Samantha
    Rohnert Park, CA
    the only reason her front tires stick out so much is because she had to get wheel spacers for the stock wheels to fit with the new spindles. i don't like it either.
