drop bracket vs stock
Old 08-12-2009, 10:28 AM   #1
rab89 [OP] rab89 is offline
rab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shed
rab89's Avatar
rab89's Tacoma Gallery
I hear drop bracket lifts are shit for wheeling, but say a 4'' drop bracket with some ome's, would it not flex just as good but be taller?
never heard this exact question asked yet..
Old 08-12-2009, 10:34 AM   #2
Sorry for party rockin'
TacticalBacon13 is one of the sharper tools in the shedTacticalBacon13 is one of the sharper tools in the shedTacticalBacon13 is one of the sharper tools in the shedTacticalBacon13 is one of the sharper tools in the shedTacticalBacon13 is one of the sharper tools in the shedTacticalBacon13 is one of the sharper tools in the shedTacticalBacon13 is one of the sharper tools in the shedTacticalBacon13 is one of the sharper tools in the shedTacticalBacon13 is one of the sharper tools in the shedTacticalBacon13 is one of the sharper tools in the shedTacticalBacon13 is one of the sharper tools in the shed
TacticalBacon13's Avatar
TacticalBacon13's Tacoma Gallery
dude you can wheel a drop bracket lift. why does everyone hate on us 6 inchers?
Old 08-12-2009, 10:53 AM   #3
rab89's Avatar
thats what I'm asking.... how could it be worse than just an ome lift if you put a db lift and ome's?
Old 08-12-2009, 10:55 AM   #4
Ban Pending
HBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shed
HBMurphy's Avatar
HBMurphy's Tacoma Gallery
Old 08-12-2009, 10:59 AM   #6
rab89's Avatar
ok, but you can fit a larger tire, which brings it up higher than your dif would be with only a 2.5'' lift...
how bout for the 01-04's for skids?
also, it wouldn't cost much to get any average fab shop to make a skid...
Old 08-12-2009, 11:09 AM   #7
rab89's Avatar
it's no solid axle, but nowhere near the price either
Old 08-12-2009, 11:10 AM   #8
Originally Posted by HBMurphy View Post
Victim? Must work in some crowds.
yes i am always the victim.
Originally Posted by johnecon2001 View Post
Because the drop bracket hangs down lower than anything else.
Imagine taking a hit right in the center of it. Only one company makes a skid for 05+ trucks with a 6".
its a real beefy kit thought. imagine hitting dead center with a stock frame and then with the beefy drop bracket. but hey its what ever floats your boat.
yeah it looks something like this.
Old 08-12-2009, 11:13 AM   #9
rab89's Avatar
looks sooo much better with the skid.
Old 08-12-2009, 11:17 AM   #10
that why i got the skid. i figured worse comes to worse i cant hit something to bend the bracket back it will at least slide up the skid plate.
Old 08-12-2009, 11:21 AM   #11
rab89's Avatar
yea of course. so how is the flex? can you stuff the tire?
Old 08-12-2009, 11:26 AM   #12
Old 08-12-2009, 11:26 AM   #13
Ban Pending
HBMurphy's Avatar
Old 08-12-2009, 11:27 AM   #14
rab89's Avatar
well, a "3 inch lift" is usually only about 2.5, go to a true 6inches, and from a 33 to a 35
your getting 4.5'' of lift over the regular 3 inch with 33's
Old 08-12-2009, 11:28 AM   #15
rab89's Avatar
Originally Posted by oakleyTRD View Post
My clearance is probably exactly the same as shown in that picture
this is with the tires at 17PSI
at the dif you do, but your breakover angle is not even close!
his truck is much taller other than the bracket
Old 08-12-2009, 11:30 AM   #16
rab89's Avatar
oakleytrd, measure the hight to the lowest point at your front suspension.
and bcgredneck do the same.
Old 08-12-2009, 11:33 AM   #17
but if you saw how many hits that IFS skid has taken compared to the rest, its the most vulnerable part of the truck and (no offence BG) but i wouldnt trust it to an 1/8" stamped pro comp skid if you paid me.
none taken. but the aftermarket bracket is alot thicker than stock so it should hold its own.
Old 08-12-2009, 11:36 AM   #18
rab89's Avatar
I've never heard of any issues with it breaking, have you?
Old 08-12-2009, 11:37 AM   #19
rab89's Avatar
true, I didnt know they were that expensive, how much does an sas run?
Old 08-12-2009, 11:39 AM   #20
Ban Pending
HBMurphy's Avatar
Drop Bracket lifts? Stillfly199 Suspension 32 01-02-2015 11:56 AM
HELP - Drop Bracket Blues SeaPig173 Technical Chat 1 09-28-2011 11:37 AM
Drop bracket kit good, but Diff drop kit bad? ZenkaiTaco 2nd Gen. Tacomas 1 12-07-2010 11:04 AM
Drop bracket lift question Unknown Suspension 38 12-05-2010 07:34 AM
Most Miles on a Drop Bracket Lift HuntnTruk 2nd Gen. Tacomas 4 11-12-2010 09:19 AM
