5100's w/ Eibach springs
Old 09-20-2009, 10:34 PM   #1
aww1970 [OP] aww1970 is offline
aww1970 is a splendid one to beholdaww1970 is a splendid one to beholdaww1970 is a splendid one to beholdaww1970 is a splendid one to beholdaww1970 is a splendid one to beholdaww1970 is a splendid one to beholdaww1970 is a splendid one to behold
aww1970's Tacoma Gallery
So after a ton of reading on here I think this is the leveling lift that I am going with.
From all I can gather these are the springs that are on the Toytec coil-overs.
I have read that with an aftermarket spring you should keep the 5100's @ "0", but the Toytec coilovers are preloading these springs so I see no difference?
Setting the 5100's @ 0" and these springs give 1.6" of lift
Setting the 5100"s @ .85" should give me approx 2.4" of lift
I am I on the right track here, anyone else preloading the Eibach springs with 5100's? Seems that this would be a way to build a coilover very similar to the Toytec on the cheap, with less adjustability.
Old 09-20-2009, 10:38 PM   #2
jwhelan is a glorious beacon of lightjwhelan is a glorious beacon of lightjwhelan is a glorious beacon of lightjwhelan is a glorious beacon of lightjwhelan is a glorious beacon of lightjwhelan is a glorious beacon of light
jwhelan's Avatar
jwhelan's Tacoma Gallery
Man, you have been reading my mind..patiently waiting for a response here.....
Old 09-20-2009, 10:44 PM   #3
chris4x4's Avatar
chris4x4's Tacoma Gallery
I dont think it would be an issue, as long as you were staying at the .85 setting. Keep in mind, your gonna be adding Preload to a 600# spring. The ride will be more firm.
Old 09-20-2009, 11:01 PM   #4
Almost there
08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed
08pretaco's Avatar
08pretaco's Tacoma Gallery
so does this mean, i got the silver eibach springs, that when i put my 5100 in this and set my collars to no lift im gonna have 1.6" of lift?
woaw not what i was hoping for
leads me to another quick question also, iv never had coilovers that a computer didnt adjust for me. for no lift the collars are cranked all the way down im assuming
Old 09-20-2009, 11:05 PM   #5
Yes the way I understand it the eibach springs will give 1.6" of lift with the Stock billy, or the 5100 @ 0" setting
Old 09-21-2009, 09:09 AM   #6
Almost there
08pretaco's Avatar
so im gonna have a 5.6" lift with my spindles
thats more than i was hoping for. i still have my stock springs maybe ill just use those with the 5100's
Old 09-21-2009, 09:18 AM   #7
SoI talked to Eibach and they said no problem with putting a bit of preload w/ the 5100's @ .85".
He said they are a progressive spring so preloading will change the ride a bit, but not that much at this setting.
No different than the springs on any adjustable coil-over.
Old 09-24-2009, 09:07 PM   #8
comajoe has a spectacular aura aboutcomajoe has a spectacular aura aboutcomajoe has a spectacular aura about
comajoe's Tacoma Gallery
progressive? i believe OME and stock are lineiar (sp) for a reason.
Old 09-24-2009, 09:17 PM   #9
Eibach told me the spring they sell for the Tacoma is progressive.
Old 09-24-2009, 09:23 PM   #10
the oem/stocker?
Old 09-24-2009, 09:30 PM   #11
the oem/stocker?
I believe the OEM spring in the TRD is progressive as well. The spring rate increases when they are loaded.
Old 09-26-2009, 06:49 PM   #12
OK i'm straight on this.
BTW what the cost of the springs???
Old 09-26-2009, 07:02 PM   #13
I 've seen them online for as low as $127.00
I was able to get them up here in Alberta for $152.00 from a local supplier.
Old 09-26-2009, 10:34 PM   #14
jwhelan's Avatar
So, summarize what you are going with
Old 09-30-2009, 02:26 PM   #15
Almost there
08pretaco's Avatar
so i got my eibach springs and my 5100 billys. the ring is on the 2.5 on the billys. i put my collars on the shocks, then put the springs just to see what they looked like.
on the collars the adjustable part was all the way down and the billys were set at 2.5".
i was able to screw the top plate on the assembly without a spring compressor...
thats doesnt seem right does it?
Old 09-30-2009, 07:33 PM   #16
Talking
no no no, you dont want the c-clip at the 2.5 setting.....you want one of the lower 2 settings. with the higher rate and that much preload you could bust the shock.
on second hand run it at 2.5 for a while and give us an update.
Old 09-30-2009, 11:12 PM   #17
Almost there
08pretaco's Avatar
Ill post a picture up soon also, but if that's the case what do I need to put between the springs and the top plate in order close that huge gap that I would have?
Old 09-30-2009, 11:14 PM   #18
chris4x4's Avatar
Nothing should go between the springs and the top plate. Post a pic of what they look like so we can further help.
Old 09-30-2009, 11:44 PM   #19
Almost there
08pretaco's Avatar
sorry they are so big
should that screw on the top just go right on? i dont think so i thought that the spring needed to be compressed in order to get that top screw on.
Old 09-30-2009, 11:47 PM   #20
Almost there
08pretaco's Avatar
i wanna run these at no lift so idk how high the collar needs to go up, maybe thats the problem??
Eibach springs w/ 5100's SKULLY Downsouth Motorsports 13 08-28-2011 10:48 AM
Running billy 5100's and eibach springs Madams 1st Gen. Tacomas 44 04-30-2011 10:56 AM
Airbag Lift, Eibach Springs with 5100 Krewblink Suspension 2 10-05-2010 08:49 AM
**NEED HELP PLEASE** Installing front 5100's with Eibach Springs aspen432 2nd Gen. Tacomas 9 03-01-2010 11:45 PM
5100 and Eibach springs? Burgman Suspension 2 06-11-2009 06:52 PM
