#41 |
\m/.....\m/
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Name: Paul
So with an AAL, is there a little more hauling capacity when paired with the stock or TSB suspension? If so, anyone know what that might be?
#42 | ||
Slap Chop
![]() Quote:
No increase in capacity. |
#43 |
Can you pass the bailout please?
I thought that sounded a little high too from when I attempted this last time, but the FSM says the UBolts should only be torqued to 37 ft lbs. Or 50N*m (whatever that means...)
__________________
Texas style is no trifling, trendy thing. It is that which you would remove from Texas in order to make it Oklahoma. ![]() March TOTM My Build |
#44 |
Slap Chop
The FSM is incorrect. Its a typo. 73 ft-lbs on OEM bolts.
#46 |
\m/.....\m/
#47 | |
Slap Chop
#49 |
Hi Chris,
I noticed that you use a spacer in the brake line bracket. Is this necessary?
#50 |
Slap Chop
No. Its not nessesary at all. It was already on Packerfans truck, so I left it. Its not hurting anything being in there.
#51 | |
By the way, when do we need to use longer brake lines? When using longer shocks? Will it be necessary in 5100 rear? |
#52 | |
Slap Chop
#53 |
time travel exists
im doing this right now but with the 3 AAL pack, just a heads up, the centering pin on mine is rusted solid so i had to go buy a angle grinder to cut it off.
__________________
http://zombiedefense.org/main/index.html |
#54 |
time travel exists
I just installed my wheelers 3 AAL pack, I took out my overload leaf and the toytec AAL I had on there. Im not sure what It measured at before but Im at 49 1/2" from ground to bottom of fender now. It rides the same on road so far, Im gonna try and do some flexing to see if the are any better than my other setup
__________________
#55 | |
Slap Chop
Thats an 8" lift!
#56 |
time travel exists
__________________
#57 |
#58 |
Slap Chop
Ah...LOL...Sounds more like it....Thats what mines sitting at.
#59 |
Great info Chris, I have a couple of questions. I assume the AALs were 2". Did it give you a 2" lift? I am hear mixed stories. "Redfox" brought it up, can you use the stock U bolts? i also noticed my truck has 2 leafs (not including the overload) yours has 3? Prerunners have different suspension?
Thank you ...What is a "Sticky"? Dane |
#60 | |
Slap Chop
A "Sticky", is when the thread is "Stuck" so it stays at the top of the threads in the section in which it is posted.
| Thread Tools | Search this Thread |
| Display Modes | |
| AAL install opinion | captkrunch | Suspension | 11 | 01-25-2009 02:31 PM |
| AAL Install help... | LonghornTaco | Suspension | 2 | 12-25-2008 04:07 PM |
| AAL, Diff drop install | duckcmdr | Suspension | 17 | 12-14-2008 01:26 PM |
| AAL for a second gen? | beehunt | Suspension | 7 | 05-25-2008 12:48 PM |
| No AAL for TSB Install | surftodd | 2nd Gen. Tacomas | 2 | 03-19-2008 07:12 AM |
